Thread Tools Search this Thread Rating: Thread Rating: 86 votes, 4.99 average. Display Modes
Old 07-05-2008, 03:43 AM   #41
refimail
My Ride: 325i
Originally Posted by Dev View Post
I don't have that little tab. Where can I ground it?
Take a multimeter and look for the strip that leads to the thick brown wire (ground).
refimail is offline   Reply With Quote
Old 08-14-2008, 11:32 PM   #42
steel330i
My Ride: E46 330i & '90 318i
so I went to a shop today and they said that the 3 prong on my harness has melted to the receptacle on the taillight assembly, so do i do the DIY shown here for both lights or do i replace the assembly and harness and receptacle(how much for these???) and then do the DIY??? So lost please help me!!!
My "Painting Your Interior Trim" DIY- http://forum.e46fanatics.com/showthread.php?t=798917
E30's FTW!!!
steel330i is offline   Reply With Quote
Old 08-14-2008, 11:52 PM   #43
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
i had a bulb warning when i got my car and i had a few people check my lights while i turned them on/off, pushed brakes, etc and said it was fine. so i took it to the dealer (honda dealer) where i got the car and they fixed it for free (since i had to get the car inspected and they "guaranteed" it would pass MD inspection) and gave me a sheet saying they replaced the tail light.
but maybe they replaced the harness. at least i know what to do if it happens again.
scott0482 is offline   Reply With Quote
Old 08-15-2008, 12:03 AM   #44
ssm1991
My Ride: 2004 325i
Do the DIY. If the problem isn't solved, you'll have to change the parts.
ssm1991 is offline   Reply With Quote
Old 08-26-2008, 11:32 AM   #45
dazzer2a
My Ride: 325i
Great post! Should this be covered under a CPO warranty?
dazzer2a is offline   Reply With Quote
Old 08-30-2008, 06:01 PM   #46
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
oh man, glad I found this. My rear lights out indicator came on this morning and all my bulbs were good, so I didn't know what to do!
e46fanatics saves the day again.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 08-31-2008, 01:36 AM   #47
robin325ci
My Ride: Helrot 325Ci
Originally Posted by M0nk3y View Post
Last time i remember, no E46 came with LED tail lights........
2004-up coupes and convertibles come with LED tail lights stock. and since his car is a convertible, his LED lights are definitely OEM since there are no aftermarket LED tails available for the convertible
robin325ci is offline   Reply With Quote
Old 08-31-2008, 10:12 AM   #48
davidwarren
Halfway to 2L
My Ride: 2010 335i
BTW- I have not tried this yet, but both sides of my rears show bulb out indicators. It just happened the other morning, but now they both come on any time I turn the lights on. Is there a common grounding point for the rear bulbs? It would seem mighty serendipitous for both sides to short at the same time.
Old 09-01-2008, 08:07 PM   #49
Alan330xi
My Ride: 330xi
Need help with tail-light indicator
2001 330xi. Just today, the tail-light indicator went on (showing fault in both lights). Of course both sides are functioning normally. How do I correct this problem?
Alan330xi is offline   Reply With Quote
Old 09-02-2008, 07:22 PM   #50
davidwarren
Halfway to 2L
My Ride: 2010 335i
This is the same problem I have, I haven't done the ground wire fix yet because I don't have the tab. Any other possible problems that could be causing this?
Old 11-01-2008, 04:02 PM   #51
Ashhong
My Ride: 2002 325i
just wanted to bump this because its so awesome. all i ever found before was the bmw bulletin, and that looked to hard. i did this in 5 minutes and no more warning light.
now if only i could figure out how to disable drl without going to the dealer...
Ashhong is offline   Reply With Quote
Old 11-02-2008, 08:59 PM   #52
sm02463
My Ride: 2001 330Ci
I have the same problem in my 2001 330ci. No tabs either. Mine has never done just one bulb...it's always both tails and they won't go out by hitting brakes, going reverse, etc... The do occasionally go on/off but it's at very strange times...like after 10 minutes of driving...but lately it's just always on.
I cleaned up the male part of the connector hoping that would do it but it didn't work. I haven't seen any signs of corrosion either. I haven't done the parallel wire fix yet because I don't have any wire on hand and I have a hard time believing it will work. I mean, the connection I'm going to make doesn't look nearly as good as the existing connector. I suspect a common connection to ground being the problem...maybe it's corroded. I wish I knew if/where those brown wires went...
sm02463 is offline   Reply With Quote
Old 11-03-2008, 06:35 PM   #53
brads2002
My Ride: 2001 325it
Thanks for posting that detailed solution.
I am out to the garage. This has been bothering me for months!
I appreciate it
brads2002 is offline   Reply With Quote
Old 12-03-2008, 04:05 PM   #54
reecewoods
My Ride: 2002 3 series
Smile thank you sir !
after 18 months of dash crazyness the indicators started to go wild so enough was enough. found your site and hey presto ! 5 mins later indicators working , no dash display, and about 100 better off . I cant thank you enough.
reecewoods is offline   Reply With Quote
Old 12-20-2008, 06:05 PM   #55
waltjr
My Ride: 2001 330i Sport Sed.
My 2001 330I sedan's tail light assembly doesn't have those tabs. What alternatives would you recommend?
waltjr is offline   Reply With Quote
Old 12-20-2008, 07:29 PM   #56
refimail
My Ride: 325i
Use a multimeter and set it to check for continuity. Take one of the meter's probes and touch the thick brown wire (exposed wire). At the same time, take the other probe and look for the corresponding ground strip on the back of the tail light assembly. Once you find the corresponding strip, solder a thick, insulated conductive wire to that strip and connect the other end of that wire to the thick brown wire. Do the same on the other tail light assembly and you're done.
Old 12-21-2008, 11:16 PM   #57
ssm1991
My Ride: 2004 325i
Or ... visually check which metal strip goes to ALL bulbs -- that's the ground strip to connect the brown wire.
Old 12-31-2008, 12:35 AM   #58
Clean_3
My Ride: E46
ok so i had this problem and did the ground fix ....now i just bought the eagle eye led's and dont know how to ground them since the led's dont have these tabs to plug a ground into it..... has anybody grounded their eagle eye led's after having the burnt out connector? where do i splice or connect the ground to?
this is urgent as i dont have working taillights until i can fix this(broke my old taillight removing it)
Originally Posted by BeRzErKaS View Post
You don't know how to spend a half day without your wife?
Try snooping through her things and finding out where she stashed your ballz...
Clean_3 is offline   Reply With Quote
Old 12-31-2008, 02:21 AM   #59
Clean_3
My Ride: E46
figured it out i was just tired lol ... connection was loose .....ground was exactly as it should have been according to the pin #'s ....brown(car plug) to black (eagle eye connector)
Old 01-05-2009, 08:56 PM   #60
EXEC45
My Ride: 2002 325i
Just got done w/the DIY mentioned in previous threads after having problems for months w/both taillights. Took me about 30min to do both. Cost me about $2 for materials at Home Depot --Thanks!
EXEC45 is offline   Reply With Quote
