Thread Tools Search this Thread Rating: Thread Rating: 84 votes, 4.99 average. Display Modes
Old 05-22-2009, 04:25 PM   #101
jhk2bmw
My Ride: 2002 E46
I have been dealing with this false bulb indicator issue for several years on my 2002 330i, to the extent that I always rode with a couple of packs of 12V bulbs in the glove box. Recently it was getting worse and I started having multiple light failures and found this thread. Got all needed parts at Radioshack for under 10 bucks, repair was easy, and have had no issues since. Thanks for the DIY, awesome!
jhk2bmw is offline   Reply With Quote
Old 05-25-2009, 05:33 PM   #102
GreyBMW
My Ride: 325i
I had this problem for over 6 months and after reading this post I fixed it in 10 minutes.
The pictures were invaluable. I have to say: if I could do it, anyone can.
Thanks for posting.
GreyBMW is offline   Reply With Quote
Old 06-08-2009, 09:34 AM   #103
Denlin68
My Ride: 335i -->330i
Send a message via AIM to Denlin68
I followed the DIY and connect the brown wire to the metal tab. ALL BULBS are working fine and bright. BUT the car dash still shows bulb out in the rear passenger taillight ...... any trouble shooting option ? I drove it around for 1 day and it hasnt turned off yet
Denlin68 is offline   Reply With Quote
Old 06-11-2009, 11:40 PM   #104
refimail
My Ride: 325i
check your rear license plate bulb and connector
refimail is offline   Reply With Quote
Old 06-23-2009, 01:03 PM   #105
patdosa
My Ride: 2002 330i SportPackg
Worked perfectly for me. Great DIY! Thanks!
patdosa is offline   Reply With Quote
Old 06-30-2009, 10:58 PM   #106
Jag65
My Ride: 325xi
On my '01 325xi the rear turn signal on the driver side blinks quickly as if the bulb is out. But upon further inspection the turn signal bulb works is dimmer than the passenger side. I tried replacing the bulb with no progress. Will this DIY fix the problem? Thanks in advance!
Jag65 is offline   Reply With Quote
Old 07-07-2009, 02:15 PM   #107
odgamma15
My Ride: 2003 330 ci
Sorry to bump an old thread... but can I solder the wire to the location circled on the pic below? or would I have to try to find another ground?
Or, can I solder a tab to this location?
thanks in advance!!
Originally Posted by ssm1991 View Post
A lot of guys have PM'd me to ask where to connect the ground wire if you don't have the tab (i.e. some pre-facelift models).
You can wrap 2-3 turns of the ground wire around the spot circled below, then wrap with electrical tape. Note that that point is part of the metal strip that goes to all bulbs.
used to hate german cars... now i have 2!!!!
odgamma15 is offline   Reply With Quote
Old 07-17-2009, 06:53 PM   #108
Hogan773
My Ride: 2002 325xi
Thumbs Up
Originally Posted by dsray1969 View Post
SSM1991 thanks for the post and pics, I searched everywhere to find a solution to this problem! Did the fix and no false indications! I used a plastic wire splice connector so I didn't have to strip the brown wire or use tape.
Me too - just did this. $2.00 for both wiretaps and the little female connectors at the Menards. Oh yeah 22 cents for a foot of 14AWG wire.
The taps are easy as you don't have to try to strip the brown wire. I think this DIY took 4 minutes, maybe 5.
I love this board!
Now I need to open a fixit shop where I will only charge $200 ( 1/2 dealers price!) to fix the light on BMWs.
For those PRE-FACELIFTERS that are posting here that they don't have the right tab, etc. I thought this was only a facelift issue (ie there are now 4 bulbs on the facelift instead of 3 on the older E46s yet they still just have one puny ground wire.
Am I wrong? Perhaps extra ground helps them too, but maybe they actually have a bulb that is going out or close to it, and needs to be changed.
Hogan773 is offline   Reply With Quote
Old 07-17-2009, 06:55 PM   #109
Hogan773
My Ride: 2002 325xi
thanks in advance!!
Problem if you solder it is then every time you want to unclip the wiring harness, you've got a soldered wire going to the bulb carrier.........
Old 08-02-2009, 07:09 AM   #110
Xelo
My Ride: '01 E46 320i
If it's not the brown wire (ground problem), another cause could be represented by the brake/stop switch above the brake pedal.
But does anyone know how to adjust it ?
Xelo is offline   Reply With Quote
Old 08-09-2009, 01:02 AM   #111
steve1955
My Ride: 2004 330xi
Thumbs Up
Thanks so much for posting the how-to information.
We began having this problem a couple of weeks ago. Found this thread Wednesday evening, picked up the items to fix it Thursday after work, and applied the fix this afternoon. So simple, easy, and effective!
steve1955 is offline   Reply With Quote
Old 08-29-2009, 07:15 PM   #112
Chance_P
My Ride: 2001 325CI
From what it sounds like, the dash light will let you know specifically which side of the car has a light out correct? Because if that is the case I must have a different problem because both of my dash lights light up at the same time intermitently. Any ideas, or does it not indicate which side specifically has a bulb out?
EDIT: nevermind guys after doing a little more reading it seems my license plate lights are out. sorry about that.
Chance_P is offline   Reply With Quote
Old 09-14-2009, 11:54 PM   #113
conciseusa
My Ride: 2002 325i
Wish I had found this fix sooner
I just did this fix and the warning light went out. Much cheaper then replacing the light control unit (what the repair shop wanted to do) and I have a feeling the problem would not have gone away after them charging hundreds.
conciseusa is offline   Reply With Quote
Old 09-15-2009, 06:14 PM   #114
RangerDave
My Ride: '00 328i ZSP w/ 208k
Sticky This! It took me months of off and on searching to find this DIY, and since this is such a common problem it seems like it should be a lot easier to find.
BMW - Suzuki - Jeep
RangerDave is offline   Reply With Quote
Old 09-15-2009, 06:18 PM   #115
RangerDave
I had this problem too. It turns out that the tail light bulbs in my car had a dual-element and in one of the bulbs only one of the two elements was burnt out, so it still lit up but after looking closely you could tell that it wasn't as bright as the others. I replaced the half-burnt out bulb and the indicator on my dash went away.
BMW - Suzuki - Jeep
Old 09-19-2009, 06:52 PM   #116
shimal
My Ride: BMW 325i
Having the same problem, except in my case, the ground connector has actually melted, and the wire has separated from the housing. Since the ground wire is still intact, I was wondering if I could just go ahead and connect the brown (ground) wire directly to the ground point shown in the picture (ie skipping the step where a second wire is spliced into the original ground wire).
shimal is offline   Reply With Quote
Old 09-21-2009, 11:28 PM   #117
Hawgwild1
My Ride: e36Ti Cali,e46 325iT
Drivers brake light won't work!
i tried to ground quick with some thick a_s wire to one of the tail light mounting bolts to no result. does it have to be the board ground to work? i have no tab, it seams all of your lights work but idiot light just goes off. mine finally died and will this fix my issue as well? oh yeh, it is a 2002 325iT. the idiot light was on with all lights working and now it fails to light up on left side with pedal pressed!
Hawgwild1 is offline   Reply With Quote
Old 09-22-2009, 08:13 PM   #118
jai_c
jai_c's Avatar
My Ride: 2001 325ci
I have a similar prob but i for some reason i cant find part the part number for the melted connector. 2001 325ci. i searched but only found part # for sedan and the other part number didnt work.
jai_c is offline   Reply With Quote
Old 09-24-2009, 09:31 PM   #119
jai_c
jai_c's Avatar
My Ride: 2001 325ci
anybody?
Old 09-27-2009, 10:32 AM   #120
vicgtr
My Ride: 2001 BMW 330xi
I have this same problem, but mine looks different. Mine disconnects from the center, not the sides, I also don't have any tabs to attach to. Anybody help me out, I'm not very mechanical. I read I can attach to .... a ground screw? Any pics where I can find or do this. Both sides have lights on, but everything works. There is some melted pins, but doesn't look that bad.
Any help would really be appreciated.
VIC
vicgtr is offline   Reply With Quote
