Thread Tools Search this Thread Rating: Thread Rating: 64 votes, 5.00 average. Display Modes
Old 09-13-2008, 09:24 PM   #41
iniguy
My Ride: 323i
141,000 mile clutch parts. The trans side was worn thin to a point where the disk material fell off in pieces, powder and hair. BEWARE ASBESTOS!
ID:	284772   Click image for larger version
ID:	284773   Click image for larger version
ID:	284774   Click image for larger version
iniguy is offline   Reply With Quote
Old 09-13-2008, 09:30 PM   #42
iniguy
My Ride: 323i
Rebuilding shifter too.
ID:	284776   Click image for larger version
ID:	284777   Click image for larger version
ID:	284778   Click image for larger version
ID:	284780   Click image for larger version
Old 09-13-2008, 09:35 PM   #43
iniguy
My Ride: 323i
misc. shifter clips, bushings, rods and bracket.
ID:	284785   Click image for larger version
ID:	284786   Click image for larger version
ID:	284787   Click image for larger version
ID:	284789   Click image for larger version
Old 09-13-2008, 09:40 PM   #44
iniguy
My Ride: 323i
Inside bellhousing
ID:	284791   Click image for larger version
ID:	284792   Click image for larger version
ID:	284793   Click image for larger version
Old 09-13-2008, 10:04 PM   #45
iniguy
My Ride: 323i
Forgot...here's the old worn out 323i
Old 09-17-2008, 11:08 PM   #46
vegito
My Ride: BMW 318i E46 2002
What kind of clutch will you put now??.. SAC again or something else?. BTW did you replace your flywheel aswell?
vegito is offline   Reply With Quote
Old 09-27-2008, 09:15 PM   #47
iniguy
My Ride: 323i
My car still had it's original clutch. When I examined it I found it had a LUK clutch. I found a original equipment LUK on ebay for $168.00 but the seller never got back with me to answer my question's about part #, etc. So I bought a SACH from a local parts house for $250.00. I also re-used my stock flywheel but I did have it machined.
While the trans was out I thought it would be a good idea to also replace the starter and rear main seal. I also completely rebuilt the shifter and repaced all shifter related bushings. I got that stuff from the BMW dealer and it was actually cheaper than buying online and no shipping charge.
Heres a few more PICS. I really like the feel of the new SACH cutch. Buy the way it was impossible to get the trans in using my trans jack. My daugthers boy friend and I man handled it back into position. I bought a couple of extra metric bolts cut the heads off and cut a slot in the end so I could use them as dowel/guide pins then removed them after I got a couple of bolts started.
ID:	286245   Click image for larger version
ID:	286246   Click image for larger version
ID:	286247   Click image for larger version
ID:	286249   Click image for larger version
Old 09-30-2008, 04:37 PM   #48
audiphile
My Ride: 2008GTI 1993Corrado
this is an excellent post!
Looks like you installed a clutch kit together with the pressure plate that has the self adjusting mechanism.
How does the car drive now? I wanted to get rid of SAC, but will leave it alone if it drives well.
audiphile is offline   Reply With Quote
Old 10-01-2008, 04:03 AM   #49
vegito
But a dual mass flywheel can not be machined right??..
Old 10-22-2008, 10:42 AM   #50
sidefly
My Ride: 335i Coupe
I thought the clutch smell scared me... this (awesome) post scares me. Holy crap, I don't know if I am that brave.
Anyone know a cheap Kansas City shop?
SIDEFLY
sidefly is offline   Reply With Quote
Old 02-22-2010, 11:00 AM   #51
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
Interesting write up, I may have to be doing this soon...
Did you have to drain any fluid before accessing the clutch?
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 02-22-2010, 06:54 PM   #52
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Cool write up. Sub'ing for later. Probably would be a good time change your tranny fluid.
Besides the rear main seal and starter, is there any other preventive maintenance that can be done?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 03-20-2010, 05:52 AM   #53
Cold6983
My Ride: '01 330i 5spd
well, depending on parts availability...first thing in the morning, HERE WE GO!!! I might just go a little nutty on this one...
Great write up and pics...found this in the nic of time!
"Shut up Nub!! I've spent more time taking a $hit at test depth than you've spent in the Navy!"
--My former Chief (Ret)
Cold6983 is offline   Reply With Quote
Old 03-20-2010, 06:05 AM   #54
Rayce185
Rayce185's Avatar
I have a Clutchmasters Stage 4 kit and lightweight flywheel lying around, is that all I need for the replacement? Or should I also replace any gaskets etc while I'm at it?
dun dun duuuunnnn
Old 05-06-2010, 03:46 AM   #55
kjsgadh
My Ride: 2001 330i
Could you please also put up any pics that you may have of the rear main seal replacements.
Thanks.
kjsgadh is offline   Reply With Quote
Old 06-08-2010, 05:11 PM   #56
Little Dragon
My Ride: E46s
Bump! Would also like to know if any other preventative maintenance should be done while doing this DIY.
Little Dragon is offline   Reply With Quote
Old 09-28-2010, 05:13 AM   #57
Sunnydave
My Ride: 325 M sport Touring
Hi Guys.
Great thread with loads of valuable info and pics.
Noticed after 100,000mls yesterday that my clutch is slipping. It's self adjusting so I'm guessing it's getting close to a change. Going to start getting the parts together. I want to use only stock parts for the clutch, but maybe a lightened flywheel. Also want to change all the transmission linkage bushings and bearings. It's a UK spec car, but I would think it's all much the same. realoem.com is highly recommended, and I'm thinking its going to be invaluable during the planning.
SD
Sunnydave is offline   Reply With Quote
Old 10-13-2010, 11:03 PM   #58
spellbound
My Ride: 323i Sedan 1999
Thanks for the great diy!
Sent from my iPhone using BimmerApp
Blessed be the Lord my Strength, which teacheth my hands to war, and my fingers to fight.
Psalms 144: 1
spellbound is offline   Reply With Quote
Old 11-16-2010, 01:49 PM   #59
trizzuth
My Ride: 228k, 16yr old B3AST
Posting in this so I can check it out later when I need it. EXCELLENT writeup!
trizzuth is offline   Reply With Quote
Old 12-16-2010, 12:55 AM   #60
eddiewolfgang
My Ride: 325i sharked cai
I just want to thank you for being so generous and taking your time to make such a great write up. good job
eddiewolfgang is offline   Reply With Quote
