Old 11-01-2007, 03:34 AM   #1
DwrdSpyrl
My Ride: 2001 ///M3
Send a message via AIM to DwrdSpyrl
Water Pump
So I replaced my water pump after it failed at about 100k miles (About 6 months ago). Earlier today, it failed again in the same way, with the impeller breaking off of the shaft. The pump probably only had about 5000 miles on it. It was an off-the-shelf Advance Auto Parts water pump, but it seems unreasonable for it to have failed so soon. What other problems could I have that would cause this premature failure? Or could it have just been bad luck?
On the bright side, it only took me about half an hour to replace the pump and bleed the coolant. It's a little sad that I have the process down so well.
It is no more...
New Ride: 2001 LSB ///M3
Updated Sig Coming Soon
DwrdSpyrl is offline   Reply With Quote
Old 11-01-2007, 04:57 AM   #2
wiggy123
My Ride: 2001 bmw 330ci
the pumps from advance have a limited lifetime warranty. dude you should of used the one with the meter impellers insted of the plastic
wiggy123 is offline   Reply With Quote
Old 11-01-2007, 06:47 AM   #3
Poorboyz
My Ride: 2001 330Ci
Yes, buythe water pump with the metal impelers. it might cost a little more but it won't break on you in 5000 miles.
Poorboyz is offline   Reply With Quote
Old 11-01-2007, 06:52 AM   #4
tommy_g
My Ride: 1999 328i
Try www.KOPerformance.com they have great prices on OE and OEM stuff. I just did my water pump along with my whole cooling system. You can check out what I did if you search, cooling system overhaul. I also listed out prices that I paid for everything.
1999 328i, Automatic, Premium Package, Xenon, K&N, OEM Clears, 157,000 Miles and Still Kicking!
tommy_g is offline   Reply With Quote
Old 11-01-2007, 08:30 AM   #5
Lemonsqr
My Ride: 2001 TiAg 330i
Just get the better waterpump. I am about to put in one with a metal impeller just for the peace of mind....
Lemonsqr is offline   Reply With Quote
Old 11-01-2007, 09:00 AM   #6
jpr
My Ride: '99 323i
FWIW, here's the short history of E36/E46 water pumps:
* The E36 started with a reddish-brown plastic impeller which would self destruct
* The E36 then switched to metal impeller, but that proved too heavy for the existing bearings causing a high failure rate
* Late model E36's and E46's finally went to the current black/grey "composite" impeller design, which basically solved the problem, or has at least made the water pump no more prone to failure than any other OEM pump.
Extended discussion on water pump options here - http://forum.e46fanatics.com/showthread.php?t=393726
jpr is offline   Reply With Quote
Old 11-01-2007, 12:41 PM   #7
DwrdSpyrl
My Ride: 2001 ///M3
Metal impeller doesn't mean a whole lot. The first one was metal, and failed catastrophically. While I'm sure its far more durable than the cheap Advance pump, I think the OE style pump is gonna be far more destructive when it does fail. Regardless, I'll be replacing it again with something that will last a little longer, I just wanted to hear that I didn't have any other problem that might cause premature failure.
It is no more...
Old 11-01-2007, 01:35 PM   #8
Lemonsqr
Go with one of these with lifetime warranty and better performance:
http://www.stewartcomponents.net/Mer...y_Code=BMWHPWP
Old 11-01-2007, 02:15 PM   #9
DwrdSpyrl
My Ride: 2001 ///M3
I'll probably end up gong that route for peace of mind. I haven't heard anything bad about those pumps. On the other hand, the Advance pump has a lifetime warranty too... haha
It is no more...
