Old 11-04-2007, 03:39 AM   #1
thefys
My Ride: 325XI
How to remove electrical wires from trunk lid handle?
I've removed the Trunk Lid Handle on my 2002 325xi and it's hanging by a bunch of wires. The connector and wires do not clip off!!!
Has anyone run into this? I am guessing I have to remove the trunk carpet inside and somewhere in there I hope to find a removable plug.
Anyone have some experience with this. Lots of posts about the thing just "uncliping in 5 minutes" but this one certainly does not ...
Thanks in advance...
Yanni
Name:	trink handle.jpg
thefys is offline   Reply With Quote
Old 11-04-2007, 10:46 AM   #2
redbmwm3
My Ride: 2000 323ci
Some e46 will clip right off, but some u have to remove the lid cover. When u remove it you'll see a little hole in the middle of the trunk. From there you should be able to see the plug. I think it's also cover by a little plate.
I have a 2000 323ci, and it comes off easy. My friend has a 2003 330ci and his is a pain in the butt.
redbmwm3 is offline   Reply With Quote
Old 11-13-2007, 10:03 AM   #3
thefys
My Ride: 325XI
Exclamation B U M P
Anyone that had this problem and solved it?
Old 11-13-2007, 10:59 AM   #4
e34werkz
My Ride: F30
Remove the four torx screws under the handle by the license plate lights, pull the handle off and the wiring harness will be exposed.
BMWCCA Member#395677
e34werkz is offline   Reply With Quote
Old 11-13-2007, 11:09 AM   #5
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
what ^he said. Sometimes the connector is stuck a bit between the metal sheets and you'll think it won't come out but if you try you will eventually get to the connector.
http://www.argyrides.eu/makeyourownsig.jpg
Old 11-13-2007, 11:13 AM   #6
thefys
My Ride: 325XI
Yes but it does not unclip. Anywhere !
Old 11-13-2007, 11:24 AM   #7
e34werkz
My Ride: F30
I don't know if facelifts are different but on my prefacelifft I was able yo disconnect the wiring harness when I took my handle to get painted. There's a clip that slides into the side of the box on the handle.
Old 11-13-2007, 11:55 AM   #8
thefys
My Ride: 325XI
They must be different than. Anyone with a 2002 (or later) sedan?
Old 11-16-2007, 04:07 AM   #9
thefys
My Ride: 325XI
Thumbs Up Impossible to remove Trunk Lid. Well, almost ...
So I ordered a brand new trunk lid from BMW to see what the is going on. It's impossible to remove the electrical wires without disconnecting from the inside. The detachable connector is about 6 inches in.
Here are the pictures of the relevant parts:
I also tried to see if it was possible to take the handle apart but it seems it was epoxied shut. Looking at this brand new handle, it's obvious once you close it, it ain't never gonna open !!! It's like a clam shell type attachment and even without the epoxy, I think it's impossible to pry it open without breaking some (or most) of the many many tabs:
I ended up having to destroy the original gasket in order to apply the Avery tape nice and tight. No biggie, a new gasket is last than $10 at the stealership
Final result with Avery tape applied:
Apart from the imperfections in the lid itself (no those are not bubbles but they sure look like bubbles...) I can't tell the Avery from the paintjob... Love it!
You'll notice I prefer to snap pictures than typing text works much better IMO.
Hope this helps !
Old 11-16-2007, 04:09 AM   #10
thefys
My Ride: 325XI
Click here for more info on Avery tape:
http://forum.e46fanatics.com/showthread.php?t=518716
Old 11-16-2007, 08:48 AM   #11
Krazee
My Ride: 325XI
Amazing job man.
Wow with that closeup of the pic, that does look like the perfect match for titanium silver.
Man this is going to suck... I wanted to do the trunk handle but to get the tape to tuck perfectly like how you did then I will need to buy the whole new handle so I can attach it before clamming it together forever.
Thanks a bunch for all the information!!!!!
Krazee is offline   Reply With Quote
Old 11-16-2007, 09:31 AM   #12
e34werkz
My Ride: F30
Wow, I wasn't aware that there was that big of a difference with the handles. I was able to vinyl my handle without prying it apart, just tuck and cut. It was a perfect match with TiAg but it's since been painted.
Old 11-16-2007, 11:59 AM   #13
thefys
My Ride: 325XI
Exclamation No need to pry it apart...
You don't need to Pry it apart. If I re-do the handle, I will disconnect it from the electrical. It's quite hard to do if you don't disconnect because it as it's dangling by the wire. I put a towel behind and in front of the license plate holder to rest the whole assembly, but if you don't good luck not scratching your paint job or license plate holder.
I just didn't have my trim removal tools yet so no choice...
But these are on order:
Old 11-16-2007, 01:31 PM   #14
Krazee
My Ride: 325XI
Ya I seen those that can just tuck it under but I want to clean wrap it just to make the tape secure like how you did.
Old 11-16-2007, 10:18 PM   #15
thefys
My Ride: 325XI
Those tools are not for applying the Avery tape, they are used to remove the carpet lining inside the trunk !
Old 03-03-2012, 08:22 AM   #16
BigDRick323
BigDRick323's Avatar
My Ride: 2000 323i
How do you take the handle completely off? I need to remove it from my old trunklid to apply to my new one.
-1983 Grey 528e (Given to Charity) -1995 Champagne Toyota 4Runner (Friend Totaled) -2000 Black 323i (From DD to Project Car) -2011 Black Toyota Prius III (DD)
Old 03-04-2012, 04:50 AM   #17
JS330
My Ride: '01 330Ci 3 Pedals
must have fished this thread out of the abyss?
JS330 is offline   Reply With Quote
Old 03-04-2012, 08:25 AM   #18
thefys
My Ride: 325XI
See start of this thread...
N
Check out post #2/#3 .... You might have a really hard time depending on your model. If it's a post face-lift ... Yikes!
I couldn't detach completely, but was able to work around it... What year is your car?
Yanni
3M or Avery Tape?
Angel Eyes Wiring Harness questions/aftermarket etc
http://forum.e46fanatics.com/showthr...94#post6941294
See my M E L T E D DEPOS !!!!
http://forum.e46fanatics.com/showthread.php?t=525961
Old 02-20-2013, 11:18 PM   #19
e46first
My Ride: 323i
o have a 2000 323i and i thought that you could just take the outer piece off but i have yet to get it off. i dont want to damage or have to replace anything and im having quite a time getting the piece off. i want to take it off an paint it to match the rest of my trim but can it be done?lol
e46first is offline   Reply With Quote
Old 02-20-2013, 11:46 PM   #20
thefys
My Ride: 325XI
I could not take it off at all. There was no wiring harness connector which seems impossible, but that'show my car is. You can look in the http://www.realoem.com/bmw/ website and search under E46 electrical, trunk area to see if your car has a real harness connector...
post what you find!
Mine is here: http://www.realoem.com/bmw/partgrp.d...22&hg=41&fg=60
but that still doesn't tell me anything actually ... maybe someone here knows where to look for the electrical connector ...?
Yanni
3M or Avery Tape?
