Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#101 |
hi! i just tried to raise them for winter and can't seem to adjust the rears while the springs are on the car...the front are super easy to adjust for height, but on the rears, the wishbone they are sitting on and the strut are getting in the way of the adjusting wrenches that KW provides. Looks like you have to take either the springs off or the strut to adjust it.
dunno if it's the same in an m3, but it does seem that you need to take the spring and the perch it sits on off my car... more info on that later this week if what you're trying to do is adjust the rebound/compression settings, then it's pretty simple, just do what it says in your owners' manual you might find this interesting as well |
#102 |
anyone tried the Bavarian Autosport coilovers?
R.I.P."lieber Nurburgring als Ehering" (which translates to "rather Nurburgring than a wedding ring") |
#103 |
I just read this whole thread and I still am not convienced with what setup to go with, with my M3. I'm leaning towards either Ground control or TCKline but at the sametime I plan on picking up other mods for the summer and plan on buying a house soon so the more affordable setup I will probably pick over the more expensive one depending on performance.
I had a Ground Control setup a long time ago and it was for a 99 accord V6. Of course you cannot compare the car but I think I can say that Ground Control's products should live up to they reputation right? I dont hessitant with the Ground Control because when I had it on my accord it didn't ride right and was extremely stiff and would bottom out on everything. Plus the polyurethan rubber piece that sits inbetween the springs would keep getting pinched off which would cause the car to rattle over every bump. A bad experience from the past is what has stopped me from replacing my factory suspension on my M. I would be very pist if I paid more money again to have a end that is unsatisfactory. What would you guys recommend for my M3? I would like to keep it under 2 grand give or take but am open minded with everyones opinions? Thanks for reading.
![]() CF TMS cold air intake/UUC Rasp-x section I/StopTech stage II brake kit slotted rotors, SS brake lines/3 pc. AC Schnitzer rear spoiler/CF rear diffuser/Iforged Aeros 19x8.5x10/Smoked corners/Smoked EE LED tails/Matte Black kidney grills/Matte Black gills/Painted reflectors |
#104 |
year and body style: 2005 325i, non sport
setup being rated: kw variant 2 coilovers adjustments: adjustable ride height, adjustable dampening, adjustable front and rear sways Ride height: front-about 1/4 inch from the bottom, rear-about 1 inch from the bottom Shock Settings: right now i have the shocks set at 3/4 stiff and the struts set at 2/3 stiff. additional aftermarket components: hotchkis swaybars, rogue engineering RSMs, H&R (F)5mm spacers, (R) 3mm and extended lugbolts additional info: F17x8 235/40/17 falken azeni 615 R17x8 235/45/17 yokohama advan(evo 9 MR stock tires).. my other rims/tires: F19x8.5 235/35/19 R 19x9.5 245/35/19 dunlop sp sportmaxx..coilovers have about 4000 miles on them and sways have about 1000 miles on them. alignment specs: F:-2.0 degrees camber, 0.1 degrees toe in. R: -1.0 degrees camber, 0 degrees toe preferred ride style: stiff and connected to the road price paid, including installation (if applicable): coilvers-1450, sways-400, RSMs-100, alignment-150...i did all the labor myself apart from getting the alignment would you recommend this setup? yes, this setup leaves a lot of room for adjustment. the stiff setting will put a smile on your face, while the soft setting will be just as comfortable as sports suspension ride comfort: 5 handling: 9 this car is in fact my daily driver. the 5 mm spacers were for the 19's. they need the spacer to clear the strut. initially i had the shocks/struts set on full stiff. that got pretty ridiculous quickly. bumps were a LOT more pronounced and would jar through the car. i noticed that there wasn't too much roll even with the stock non sport sway bars, but there was still some understeer that i didn't think to dial out. i later set the shocks/struts at 3/4 stiffness. that made a huge difference and made daily driving it a bit more tolerable. handling was still great. the addition of the swaybars drastically improved the handling. body roll was reduced a fair bit. the sways are currently set at the stiffest setting in the rear and the middle setting in the front. even with this setup there was still a little bit of understeer at the limit. today i actually softened up the dampening on the struts to 2/3 stiffness to try kill the understeer at the limit. that seemed to do the trick. i will be experimenting with shock/strut settings before the next autox. all in all i'm very happy with this setup. it never fails to put a smile on my face when going through a long tightening corner and having the car pull through it like nothing was going on ![]() ![]() ![]() ![]()
-Azlan *I want to be like CD330*
![]() ![]() Last edited by azzy989; 03-18-2009 at 03:36 AM. |
#105 |
Year and body style: 1999 328i w/ sport package
Setup being rated: H&R Sport Cupkit, stock sways Adjustments: NA Additional aftermarket components: 18" wheels, RE Shock mount Additional info: installed over 4 yrs ago by original owner Preferred ride style: I prefer a ride that is significantly stiffer without being harsh. I didnt expect flat cornering, and it does roll quite a bit, once it rolls to a point, it stops and corner solid. Ride is great for the low drop that it is, south east VA has some ridiculous expansion joint bump, that really, sound worse than they feel with this setup. Would you recommend this setup? Absolutely. The drop is both noticable and stylish, but not over the top. I wouldnt be too keen to track it, mainly because of the body roll, but i suppose its would be much better than stock. Smoothness and comfort seem similar to the stock sport suspension, if not better, with much better handling, turn in, and better control, feels very sure footed, even when you hit the random bump mid turn, it just soaks it up and go. Body roll is def much better than stock ones ive driven. Price paid, including installation (if applicable): See additional info above. i think $650 is the going price of the kit. Ride comfort: 8, especially considering a few other setups ive ridden in Handling: 7, considering other setups ive ridden in ![]() Pics: ![]() ![]() ![]() ![]()
#106 |
Bump to revive an informative thread. Anyone running on Bilstein HD's with lowered springs?
#107 |
year and body style: 2003 325i base sedan
set-up being rated: H&R sport cup kit wheels used: style 119, 225/45/17, 245/40/17 additional info: 10mm H&R spacers all around Roque RSM total paid for install: $350 with alignment ride feel: a little stiffer ride compared with stock suspension, but handling and feel really improves highly recommended set-up practical for the price
Mods: Vmr VB3 staggered wheels, H&R sport cup kit, P46 with Orion V2 with Canbus xenon, Magnaflow exhaust, Aluminum pedals. Roque RSM, Interior xenon lights, Oem alarms, M3 steering wheel, carbon fiber wrap interior, K&N intake, Mtec II bumper, Kenwood with Pandora and 2x12's sub and amp, RCR tails, OEM clear sides and front, black kidneys and roof spoiler. |
#108 |
stuff like this is what makes e46 great
![]() euro clears, V2 LED angel eyes, m-tech II front bumper, trunk lip spoiler, chrome gauge rings, 18" m5 rims, chrome grill, K&N intake, aux input, brushed aluminum pedals, active autowerke gen. 3 exhaust, RD Sport SSK w/ Rogue WSR Bilstein sport shocks, H&R race springs |
#109 |
Great thread!
#110 |
My Ride: 2004 325i
I glanced through each page, and didn't see a thing about DDM Coilovers. What gives? I know of at least four frequent posters that run them.
Year/bodystyle: 2004 325i Setup Being Rated: DDM adjustable coilovers Adjustments: Dampening, Ride Height, Camber (?) Ride Height: They can get very low, but I'm about four inches off the ground. Shock Settings: 25 clicks front/25 clicks rear Other Info: Everything else on the car is stock, including wheels and tires. Also, bought these with 250 miles on them. Preferred Ride Style: Stiff and low. Anything better than the stock suspension would have been a huge improvement, but I didn't expect a race car. Would You Recommend? This is when I start to get confused. It's worlds ahead of the stock suspension in terms of body roll and stiffness, but the ride is fairly bouncy. What really makes me hesitate recommending these coils is the install, which I did myself. The provided instructions were useless, and there isn't a single bit of indication on the shock as to orientation. I'd recommend getting these professionally installed unless you know what you're doing. Really know what you're doing. But the suspension is good. It corners flat, and the shocks can get very stiff. Though these are not made for the track. Long story short, I'd recommend these coils as a great stepping-stone for getting low. I'm happy with them, but look forward to the day I upgrade to something of higher quality. Price Paid: $600 used Ride Comfort: I haven't finished dialing the settings in, but I'd give it a 7 or 8. Handling: Not a track-worthy setup, but it corners flat. 7/10 Pics: ![]()
#111 |
anybody with a xi
#112 |
Setup 1
year and body style: 2001 330i setup being rated: OE Sport Suspension adjustments: NA additional aftermarket components: BBS RG-R wheels additional info: Spare tire removed, various pieces of sound deadening removed preferred ride style: I aim/prefer the stiffest ride possible without being harsh over bumps and the car rocking over undulations in the road. would you recommend this setup?: Meh, it's OK. Suspension is decent over a wide range of terrain from smooth roads to dirt roads. Relatively soft linear springs with lots of suspension travel soaks up large bumps equally as well as small bumps. But during aggressive driving on smooth roads, there is a good amount of body roll and steering is a bit lazy compared to sportier options. The excessive body motions actually detract from comfort a little bit. Also the shocks feel very basic and simple. Like many stock parts, a best compromise between every driving condition and economically priced. price paid, including installation: $0 ride comfort: 6 handling: 4 Setup 2 year and body style: 2001 330i setup being rated: H&R Sport Cupkit adjustments: NA additional aftermarket components: BBS RG-R wheels additional info: Spare tire removed, various pieces of sound deadening removed preferred ride style: I aim/prefer the stiffest ride possible without being harsh over bumps and the car rocking over undulations in the road. would you recommend this setup?: Absolutely not. Shocks were stiff and harsh over bumps when new. As time went by, the shocks became softer and softer to the point they were barely doing their job and the ride was bouncing all over the place. Shocks had a didn't feel very researched and developed. Also handling became horrible and lots of body roll when they failed. price paid, including installation: $700, free installation ride comfort: 3 handling: 2 Setup 3 (current) year and body style: 2001 330i setup being rated: H&R Race springs and Bilstein Sport shocks adjustments: NA additional aftermarket components: BBS RG-R wheels additional info: Spare tire removed, lightweight battery, various pieces of sound deadening removed preferred ride style: I aim/prefer the stiffest ride possible without being harsh over bumps and the car rocking over undulations in the road. would you recommend this setup?: Oh YES! The ride was incredible from day one. The shocks feel way more sophisticated and sorted out than either OEM or H&R cupkit. Driving over smooth terrain, the handling is so sharp you expect rock hard suspension, but drive over a small pothole or undulation in the road and the suspension eats it up and it doesn't even get transferred into the cabin. Larger bumps though are obviously going to have a bigger effect on the car than OE suspension since there is so much less suspension travel. price paid, including installation: $600(used springs and wholesale pricing shocks), free installation ride comfort: 9 handling: 8 |
#113 | |
Strange how the shocks in the cup kit became mushy so quickly, especially since they are Bilstein's
![]() Dinan CAI_Stage II_3.46 Dif OEM CF Strut Bar_Eibach Sportline_GC Konis OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems 500W_RE Audio_Hertz Components House Mixes: |
#114 | |
If you get higher end H&R suspension like the coilovers and what not, you get Bilsteins, but not with the cupkit. When I had both sets of struts hand in hand, they were different in every way. The welds that attach sway bar links were different, the body of strut was different, the shaft of the strut was different, the construction of the body was different, etc... Quality was definitely higher on the Bilsteins. I think my new bilsteins are high pressure gas monotube, while the old H&Rs were low pressure gas twin tube. |
#115 | |
#116 |
#117 |
Great thread.
#118 | |
Well, I hope that's the case lol If so, it seems like the cup kit should be pretty good. That's why I'm confused when people say they turn to mush after 10,000 miles? I've had mine on my car for a LONG time, and they ride just fine; not great, but ok.
#119 |
on the bottom of the shock. there is a sticker. the shocks are silver and there is a lil Bilstein sticker at the botton, i cant recall where they are on the struts tho.
#120 |
I think I still have my old H&R shocks and struts lying around somewhere, I will check again for the Bilstein sticker. I'll also take some measurements and pictures showing how very different my bilstein sports and h&r struts are.
I'm really curious to figure out what is going on. Maybe I got some cheap chinese replica H&R cupkit instead. |
