Old 11-07-2007, 08:35 PM   #1
FrontlinexBMW
My Ride: 2003 BMW 330i
Umnitza Predator Chromiums Help!!!
I ordered my P46's from Umnitza last Monday and he told me that it was going to arrive Friday. However, it reached my door on Thursday so for Umnitza for quick responses and shipment. After installing the headlights I tested out the projectors first since I didn't know where to wire the trigger wire at first. To this point, everything looks great!!! But after putting in the trigger wire, the Predator Chromiums came on and were awesome but one was out. The lights out indicator in my car showed the same side as the angel eye that wasn't working. The other side is perfectly fine. I'm hearing from other fanatics that this is the cause of the ballast for the angel eyes. Matt has told me that it's the ring and might have been damaged because of shipping. Anyone with a diagnostic for this or what I should do? Please help!!! I personally don't think changing a ring from a pre-installed unit would be a good idea unless I send it back to Matt.
Under Construction
FrontlinexBMW is offline   Reply With Quote
Old 11-07-2007, 08:50 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You can confirm by swapping the angel eye ballast inside the headlight. It's the little black box that you can reach through the high beam and is attached to the white wires for the rings. Swap it with the working side and see if the problem switches sides. If not, it's a ring issue.
You can just have Matt send out a replacement ring and install it yourself, it's not too bad.
Old 11-07-2007, 11:54 PM   #3
M3R1
My Ride: Silver 04 M3
That happened to me I diagnosed it to be the ring and sure enough the ring was cracked from the manufacturer. It was covered under warranty, but I still had to pay $10 for shipping plus had to buy heat resistant glue So far they look great
M3R1 is offline   Reply With Quote
Old 11-08-2007, 07:56 PM   #4
C M3 FLY
Banned
My Ride: 2002 Alpine White M3
Same, i had a problem angel eye as well (possibly 2 as i am getting one replaced as well) but i got them fixed for free from the the shop that put em in!
Good luck, and they do look good when they are working right!
C M3 FLY is offline   Reply With Quote
Old 11-08-2007, 10:37 PM   #5
FrontlinexBMW
think Matt and I found what the prob was and gonna try fixing it tomorrow...hopefully get some pix...btw..I got ur setup C M3 FLY!!!
Under Construction
Old 01-10-2008, 05:26 PM   #6
vit325
smooth criminal
My Ride: 2001 325i
Send a message via AIM to vit325
i also narrowed down my problem to a ring issue, and umnitza sent me 2 replacements...problem is i dont have a clue how to swap them out
please help!
vit325 is offline   Reply With Quote
Old 01-10-2008, 07:26 PM   #7
M0nk3y
Banned
My Ride: 2002 325xi
Search.........DIYs
http://www.fastm.com/m3/angeleyes.html
M0nk3y is offline   Reply With Quote
