Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 01-01-2010, 11:37 PM   #41
iansanderson
My Ride: 2001 330CiC
you can definitely hear the difference open/closed in a convertible.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 01-01-2010, 11:50 PM   #42
Gheybe
Gheybe's Avatar
My Ride: F80 M3
To everyone that thinks their flap is broken: Your flap will stay open when your car is off.
Gheybe is offline   Reply With Quote
Old 01-02-2010, 03:46 AM   #43
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
my 2002 330i has it.. I am probably just going to leave it alone.. but i may change my mind an experiment in the spring..
now i know why one exhaust tip gets dirtier quicker
scott0482 is offline   Reply With Quote
Old 01-02-2010, 09:56 AM   #44
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
mine stays open at all times. i don't see the point in this "mod"
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 01-02-2010, 08:15 PM   #45
GCoop
My Ride: '04 325xi
Originally Posted by GoingNuts View Post
Mine doesn't close when idling. Anyone has a mod to get this closed ? Call it a reverse golf tee mod.
If everything is hooked up properly.....
It's called WD-40. Use it to clean and lubricate the moving parts.. Its either that or a small peice of debris is hindering its movement. Quite common actually.
GCoop is offline   Reply With Quote
Old 01-06-2010, 05:52 PM   #46
msb046
My Ride: 2001 330xi
I tried this on my 2001 330xi - the valve wasn't opening up before when the car was off. Now after putting the golf tee in I can open the valve, but it will close very slowly and then begin to rattle. Just tried spraying some wd40 on it, but what could be causing this? If I can't fix it, sadly I'll have to remove tee, because I cannot stand the rattle.
msb046 is offline   Reply With Quote
Old 01-16-2010, 12:50 AM   #47
Luv2xlr8
My Ride: E46 Convertible
lmao!!!
Originally Posted by LouisBailey View Post
I have wondered why my 2003 330i sounded deeper in tone, after reading this thread I found for some reason my flapper stays open when stopped. I am having problems finding anyone who will keep running and bending over to find out if it closes at any given RPM. BTW could I have a vacuum leak as I can find no golf tee........
I'll run behind yours and check if you run behind mine and check after!
Luv2xlr8 is offline   Reply With Quote
Old 01-16-2010, 12:54 AM   #48
E46330iguy
My Ride: Supercharged 330i
its called "Take a flat head screw driver and jam it closed mod"
Over time the soot /carbon builds up around the valve and sticks it open/closed dosent hurt anything if its stuck open
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 01-16-2010, 05:22 AM   #49
kalifornia
My Ride: 325ci
can you remove plug with 325ci??
im looking and my 325ci-03 has this flap (butterfly) but it looks to be adjusted by a mechanical arm vs. a tube for suction. Can someone verify for me that 325ci has a tube that can be disconnected?
kalifornia is offline   Reply With Quote
Old 01-16-2010, 05:55 AM   #50
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Yes, look further upwards, it'll be connected to a vacuum controlled solenoid .. that solenoid is connected to the mech arm that then connects to the flap
E46 Coupe is offline   Reply With Quote
Old 02-15-2010, 01:46 PM   #51
Chris911SC
My Ride: '04 330xi 6sp Sport
did mine yesterday. definatly noticed a difference, the lower frequency of the exhaust note is more pronounced, but not more aggresive. If i had to pay for this mod, and it cost more than the free phillips head screw i had laying in my toolbox, i probably would pass. But hey, it took me literally 90 seconds to do, so i'll give it a shot for a week or so.
Chris911SC is offline   Reply With Quote
Old 11-16-2010, 09:57 AM   #52
H1RSCHY
My Ride: 328i 1999
just get rid of the stock exhaust. then you dont gotta worry about it.
H1RSCHY is offline   Reply With Quote
Old 11-16-2010, 10:08 AM   #53
BimmerFerret
My Ride: 08 G37S, 07 Sky RL
Holy thread bump
2008 Infiniti G37S - Big Brakes, Limited Slip, etc.
2007 Sky Redline
1998 Honda Civic EX Sedan
Originally Posted by Roxlo View Post
Class of '03, yet you're still an idiot. Whats your point? Do you really think that you're somehow a god because you joined a site before someone else? ****ing nerd.
BimmerFerret is offline   Reply With Quote
Old 11-16-2010, 10:47 AM   #54
H1RSCHY
My Ride: 328i 1999
lol oops i was finding an old thread for a different person to look at on how to do it.
Old 12-11-2010, 07:52 PM   #55
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
I did this the other day to stop the rattling flap. But I have also noticed a drop in MPG since doing it. Could this effect MPG or do I maybe have something else going on?
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 12-11-2010, 08:11 PM   #56
ICONIKE46
My Ride: Horse & Buggy
ICONIKE46 is offline   Reply With Quote
Old 12-11-2010, 08:51 PM   #57
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Originally Posted by ICONIKE46 View Post
Are you giving me the face palm? Blow me class of 2010. I had a honest question. That did not say my car is loud. I was curious if this does affect gas mileage.
*NWS GIF REMOVED*
*GIF REMOVED*
Old 12-11-2010, 09:16 PM   #58
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Newbie should know that on topic thread bump is what youre supposed to do instead of starting new threads
Drew@Swift Motorworks is offline   Reply With Quote
Old 12-11-2010, 09:17 PM   #59
Past Site Sponsor
Somehow I dont see it affecting mileage. Maybe theres just something else going on or youve been driving differently
Old 12-11-2010, 09:30 PM   #60
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
I could be driving different and just not noticing. I do like the fact that the flap doesn't rattle on cold mornings. I guess I just need to to watch it. I filled up with gas tonight and it dropped 3 miles off the counter, before I left the parking lot.
*NWS GIF REMOVED*
*GIF REMOVED*
