Old 11-08-2007, 04:00 PM   #1
OnTheGreen
My Ride: 2001 325IT "Wagon"
Rogue Power Pulley kit belt part # needed (Non-OEM)
So I have the Rogue pulley kit, and a belt for the UUC kit. They obviously use a different belt as the UUC belt slips with the Rogue pullies. I figured it would be the same, but it's not
The BMW part # is 11 28 1 469 261
What I am looking for is a part # for the same belt by say Gates, Goodyear, or another maker that I could get at the local parts store.
Thanks, bryan
OnTheGreen is offline   Reply With Quote
Old 11-08-2007, 04:12 PM   #2
tsylatac
My Ride: understeers.
Yeah, you can get them anywhere... It's as 6 rib x 1560mm long. I have the product numbers right around here somewhere, I'll post them when I find them
The belt for the Rogue Pulleys is:
BMW 11 28 1 469 261 (also from BavAuto, etc, made for the 525i)
Gatorback 4060615
Duralast 615K6
The stock air conditioner belt is:
BMW 11 28 7 512 762
Gatorback 4040340
Duralast 340K4
When you install it, don't forget that you need a rather large 8mm Torx. I got one at Sears for a few bucks that is mounted in a socket so you can easily use a breaker bar to pull the tensioners.
2 0 0 3 | 3 3 0 x i
RIP
tsylatac is offline   Reply With Quote
Old 11-08-2007, 04:19 PM   #3
tsylatac
There ya go.
2 0 0 3 | 3 3 0 x i
RIP
Old 11-08-2007, 04:33 PM   #4
OnTheGreen
Thanks man. I appreciate it.
I actaully re-used the OEM belt. It works fine, as the slack or lack there of is compenstated by the tensioner.
Not a permanent solution, but for a day or two is hould be fine.
Thanks again, Bryan
Old 11-08-2007, 04:35 PM   #5
OnTheGreen
Just to add, the belt that came with the UUC kit was 6 rib by 1616 long
Old 11-08-2007, 04:39 PM   #6
tsylatac
Oh, let's keep going with this..... The metric conversion for the Rogue kit is 1560mm for the belt.
2 0 0 3 | 3 3 0 x i
RIP
Old 11-08-2007, 04:46 PM   #7
OnTheGreen
Yes, the UUC belt had too much play in it to properly work with the Rogue pullies.
UUC belt part # from Gates is K060630 6PK1601
20mmx1616mm
