air wont go in my tire - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 11-13-2007, 02:16 PM   #1
Sneaky
My Ride: Fixie
Theres something wrong with one of my tires. I try to put air in but the tire is not havign it. When i connect the pump nozel to the wheel no air comes in, only air comes out.
THE OFFICIAL BLACK SEDAN THREAD because Nothing breaks necks like a Black BMW.
Sig by So Lowww
Pictures I take
OVOxo till we overdose
Sneaky is offline   Reply With Quote
Old 11-13-2007, 02:52 PM   #2
MightyY
My Ride: '05 M3, '03 M5
Get the valve stem changed??
MightyY is offline   Reply With Quote
Old 11-13-2007, 03:12 PM   #3
Sneaky
My Ride: Fixie
How much will that cost?
Sig by So Lowww
Pictures I take
Old 11-13-2007, 03:27 PM   #4
jwm5
My Ride: station wagon
Is the tire completely flat? Does the valve stem appear to be damaged? Can you If it is the valve stem it will cost you to have the tire taken off, valve stem changed and tire remounted and balanced. $20-$30?
jwm5 is offline   Reply With Quote
Old 11-13-2007, 03:30 PM   #5
Sneaky
My Ride: Fixie
The tire isnt compelety Flat but id say about 75% of the air is in thre. I wonder how safe driving will be.
I have 4 Winter tires in the car That I was supposed to put on yesterday but it didnt get done so their still in the car, going to do it tommorow morning. I wonder how long i can drive like this.
Sig by So Lowww
Pictures I take
Old 11-13-2007, 03:39 PM   #6
jmueller
My Ride: 2001 330ci
valve core.. is like 40 cents.. but you should get it rebalanced
jmueller is offline   Reply With Quote
Old 11-13-2007, 03:46 PM   #7
jwm5
the valve itself will be cheap, but it will cost him to have the tire taken off then remounted and balanced.
OP If the tire isn't flat, if you take off the valve stem cover will air come out? If air doest come out when the cap is off, the valve stem may be ok. It could be your pump connection, are you able to put air in the other tires with no problem?
Old 11-13-2007, 04:15 PM   #8
Sneaky
My Ride: Fixie
The other tires were fine when I put air in. But this one when I hooked it up no air was going it, I could just hear air coming out. I think its the valve stem
Sig by So Lowww
Pictures I take
Old 11-13-2007, 07:47 PM   #9
SteveX82
My Ride: 2001 325i
In all likelihood, it's just the valvestem core. The tip of the core is likely missing or bent so that it doesn't recede downwards and open up the valve. Slip a new core in there and you'll be good to go.
If, for some bizarre reason, the new core doesn't help, bring it to a tire shop and have them install a new stem. They will NOT have to dismount the whole tire and charge you for balancing. Just have them break the front bead, cut the old stem out, and install a new one. It'll cost you 3 bucks at BJ's, or maybe $10 tops at any other shop.
SteveX82 is offline   Reply With Quote
Old 11-13-2007, 07:54 PM   #10
grafiksguy
My Ride: 2010 328xi
+1 on the core. Aside from a cut or cracked valve stem (which would be easy to see/hear) this is a simple fix. Go to an auto parts store and get some replacement cores (they usually come in packs of a few) and a valve core removal tool. Pull the old core out, insert the new one and you'll in all likelihood be good to go. If not, follow Steve's advice and have the stem replaced, but I'd bet the core will do it.
You didn't by some chance use an fix-a-flat or slime to repair a leak, did you? That'll gunk up a valve in a hurry.
grafiksguy is offline   Reply With Quote
