Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 11-14-2007, 03:42 PM   #1
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
FS: 2004 330Ci (Clean. Unique. Modified.)
As some of you may already know, I have been considering selling my car for some time. I think the time has finally come and this thread, unlike the other I created last week, is NOT a feeler and I am very serious about selling the car. I would love for my car to go to someone who can fully appreciate the time and effort that has gone into it. The car has been to many regional shows and has always been well received. I have babied it since the day I picked it up and I detail the car every other month using only the best products and methods (Menzerna, Zaino, etc). This car is a complete package deal and no aspects were overlooked. Unlike some heavily modified cars out there, this car has been put together with the mindset of preserving the factory functionality, fit and finish while also introducing unique changes that improve the overall appeal of the car. The car is one of very few 330Ci's without a sunroof which only furthers the purpose-built nature of the car.
Pictures will follow this weekend when I have a chance to clean the car up and do a full walk around. In the meantime, you can easily search under my name for thread's I've started and you'll find many many pictures.
General
2004 330Ci
Silver Grey Metallic
Black Leatherette Interior
Xenon Adaptive Headlights
52,XXX Miles
Condition
Interior
~ The interior shows little to no signs of wear. The leather surfaces are not shinny and still look factory fresh. No smells. No worn seat bolsters. No ripped mats. No stained carpets. Spotless headliner. And it doesn't smell like air freshener either. I hate that smell.
~ The only evidence of wear is on underside of the passenger door armrest where the rubberized finish has come off slightly. I have no idea how this got worn but its very hard to see. You literally need to open the door, get your head under the door and look up to see it.
~ No rattles or squeaks
Exterior
~ The exterior shows little to no signs of wear. There are no signs of swirl marks anywhere on the car.
~ There are 2 small dime-sized dings on a single panel and one small ding on the roof from an acorn. All dings appear to be shallow enough to be repaired with a DIY ding repair kit or, of course, a professional could take them out with no effort at all. There is a hairline scratch under the driver side door marker which has been repaired with polish and is unable to be photographed. There is a slight rub on the driver side rear bumper which has been repaired with polish and is unable to be photographed as well.
Engine/Drivetrain
~ Oil Changes were performed every 3-6,000 miles.
~ Clutch was changed under 15,000 miles ago under warranty due to a slight rattle that was later determined to be a loose screw in the engine bay.
~ Engine runs very strong with no unusual sounds whatsoever. No cold weather start issues at all. Even in sub-freezing conditions, the car starts and settles to a normal idle with zero issue.
~ Transmission fluid was recently flushed with Red Line brand oil. Differential fluid was changed as well to Red Line brand oil.
Suspension/Braking
~ All bushings and bearings have been inspected and determined to be in good condition. The shocks/struts have under 5,000 miles on them.
~ All rotors and lines have been inspected and determined to be in good condition. Rotors show very little to no sign of lipping. Lines also show very little to no signs of wear. Brake pads were replaced under 5,000 miles ago.
~ The very best brake fluid, Motul 600, was all that has been used on this car.
Modification
The modifications performed on this car are extensive but stock functionality is preserved throughout. There are no "ghetto rigged" items and everything works exactly how it should. The exterior and interior are subtly changed and upgraded. The performance has been improved and the car is extremely responsive and peppy. The handling has been vastly improved and you would be hard-pressed to find a car that handles better with the selection of components installed. The car has been described by others as "frightfully balanced" and I couldn't put it any better than that. In case you haven't realized by now, I love this car dearly.
Exterior
Authentic AC Schnitzer Front Add-On
OEM M-Tech Side Skirts
OEM M-Tech Rear Bumper (Insert Painted Sapphire Black)
OEM M3 Mirrors (Painted Sapphire Black)
OEM M3 Lip Spoiler
Replica AC Schnitzer Roof Spoiler (Painted Sapphire Black)
Sapphire Black Roof
Sapphire Black Upper Window Trim
Sapphire Black/Silver Grey Front Grille Insert
Custom Molded Front Bumper (no seams, no reflectors, no plate holes)
Umnitza 6,000K Angel Eyes
Interior
OEM M3 Steering Wheel
UUC Motorwerks Silver Gauge Cluster
Custom Matte Silver Grey Interior Trim (Matches Exterior)
Hardwiring for Valentine 1 Radar
Suspension
TC Kline Suspension System
- Dual-Adjustable Front & Single-Adjustable Rear
- Bana Rubber Rear Shock Mounts
- Z3 Reinforcement Plate
- Spherical Bearing Front Camber Plates
- 450lb Front Spring Rate & 500lb Rear Spring Rate
UUC Motorwerks SwayBarbarians (Gen2)
- Turner Motorsports Adjustable Front Endlinks
- UUC Motorwerks Adjustable Rear Endlinks (recently re-lubricated)
UUC Motorwerks StrutBarbarian (All-Magnesium Version)
Powerflex Polyurethane Front Control Arm Bushings
Braking
UUC Motorwerks Slotted Front Rotors
UUC Motorwerks Stainless Steel Brake Lines
Ferodo DS2500 Brake Pads
Performance
UUC Motorwerks TSE3 Exhaust System
UUC Motorwerks Viper Intake System
UUC Motorwerks Transmission Bushing Reinforcement Kit
UUC Motorwerks EVO3 Short Shift Kit
UUC Motorwerks Big Boy Clutch Stop
Active Autowerkes Performance Software (93 Octane/7000RPM Redline)
OEM 3.38 Rear Differential (upgraded from 2.93)
Wheels
SSR Comp-H (19x8F&R)
Bridgestone Potenza RE-01R (245/35/19F&R)
Vorschlag 5mm Front Spacer
Vorschlag 10mm Rear Spacer
Turner Motorsports Nut/Stud Kit
JCz04Bimmer is offline   Reply With Quote
Old 11-15-2007, 02:32 AM   #2
Gucki83
Gucki83's Avatar
My Ride: E92 M3 ZCP / 635CSi
free bump
Old 11-15-2007, 03:25 AM   #3
Bomex330Ci
My Ride: '04 330ci
free bump for a sick car
Bomex330Ci is offline   Reply With Quote
Old 11-16-2007, 09:44 AM   #4
JCz04Bimmer
Thanks for the bumps! I forgot to mention, I have the OEM Alarm installed and 35% tinting.
Old 11-16-2007, 10:50 AM   #5
Straz M3
Rogue Engineering
My Ride: 2008 M3 Coupe
Send a message via AIM to Straz M3
You wont get an E46 M3 like me haha...
Whatever you do, going into a new E90 will make you miss your E46...that's why I had to come back...
2008 E92 M3 6MT
Alpine White / Fox Red/ Carbon Fiber
Straz M3 is offline   Reply With Quote
Old 11-18-2007, 08:36 AM   #6
JCz04Bimmer
And don't worry. I have no interest in an E90.
To anyone interested, I am certainly open to offers!
Old 11-18-2007, 09:49 AM   #7
Ldezoete
My Ride: M3,325ci,s,635csi
One usually posts a price??
2003 M3,coupe,AW, LSB interior SMG
all options
all Competion pkg goodies plus plus
Former cars
2001 325ci Dinan pkg
1995 M3,
1986 635Csi
Ldezoete is offline   Reply With Quote
Old 11-18-2007, 07:29 PM   #8
JCz04Bimmer
$30,000 (negotiable)
Old 11-20-2007, 03:01 PM   #9
JCz04Bimmer
Old 11-20-2007, 07:52 PM   #10
Cheese325
My Ride: 325ci
Cheese325 is offline   Reply With Quote
Old 11-27-2007, 12:31 AM   #11
JCz04Bimmer
To all those interested: The car will undergo the Inspection II service prior to sale. This is a big ticket maintenance point and will likely update my control arms and other parts. All parts not needing replacement will be inspected to ensure they are in good condition.
Old 12-06-2007, 09:30 AM   #12
JCz04Bimmer
Old 12-06-2007, 01:47 PM   #13
coolusername
My Ride: F30 335xi
you could trade me, and trade my stock car in? ehh worth a shot
bump
                   O.I.F 05-07 Veteran
coolusername is offline   Reply With Quote
Old 12-06-2007, 02:15 PM   #14
JCz04Bimmer
bump
Hmm. How much you want to give me in the trade?
Old 12-06-2007, 06:41 PM   #15
coolusername
My Ride: F30 335xi
a big hug shoot me a pm maybe
                   O.I.F 05-07 Veteran
Old 12-18-2007, 02:01 PM   #16
JCz04Bimmer
Sorry, didn't catch this reply. Shoot me a PM. I'd have to figure out what the trade-in value of your car would be first and then we can figure something out perhaps. I'm definitely not adverse to the idea. Basically, I'm trying to make a set amount of money on the transaction. If I can make it, done. If I can't, no big deal... I love my car!
Old 12-19-2007, 05:38 PM   #17
runvusofme
My Ride: 2004 Subaru Impreza
Very clean car!! Love the rims!! GL...
runvusofme is offline   Reply With Quote
Old 12-21-2007, 11:30 AM   #18
runvusofme
Drive the car down here and let's trade!
Free bump for you!
Old 12-21-2007, 11:41 AM   #19
JCz04Bimmer
Free bump for you!
If you are interested, I might be able to arrange a competitive price for shipping the car down to AL. A friend of a friend ships cars for the Ferrari dealerships in the region and has offered his services in the past...
Old 12-21-2007, 11:58 AM   #20
6MTGirl
My Ride: loves camber
Saw this car in person last year, it was in fantastic shape. Perfect color, options and mods and without any offense to anyone, you're one of the few on here who knows how to set up a suspension. I'd love to see what you would do to an M3. Whoever buys this will get a true performer. Function > form
6MTGirl is offline   Reply With Quote
