Old 11-15-2007, 12:24 PM   #1
radu2006
My Ride: e46
harman kardon retrofit
hey guys,
can i use a coupe hk amplifier to power my hk sedan speakers and subs?
thanks
radu2006 is offline   Reply With Quote
Old 11-16-2007, 06:31 AM   #2
radu2006
My Ride: e46
nobody knows?
Old 11-16-2007, 07:46 AM   #3
richkopena
My Ride: 2002 330Ci
Maybe you should try the question in the electronics forum instead of the general forum.
richkopena is offline   Reply With Quote
Old 11-16-2007, 08:38 AM   #4
Crescent_City
My Ride: 330XI
Send a message via AIM to Crescent_City Send a message via Yahoo to Crescent_City
The connectors are the same. The mounting bracket for the amp is different however. Electronically it's the exact same cross over etc. The subs and sub amp are mouted differently and those will not work with out some serious work with a dremel tool and probably fiberglass to mount them without rattle.
OEM Clears lights, OEM matte aluminum interior trim, OEM aluminum pedals,OEM Xenon's w/tit trim,UGDO.
Crescent_City is offline   Reply With Quote
Old 11-16-2007, 05:34 PM   #5
radu2006
My Ride: e46
i have the subs with the amp from a sedan i just need to know if i can use the main amp from a coupe. thanks
Old 11-16-2007, 11:18 PM   #6
logikgr
logikgr's Avatar
My Ride: 2001 BMW 325i Sedan
Send a message via AIM to logikgr
Call the dealer and ask if the PN will fit your car.
logikgr is offline   Reply With Quote
Old 11-18-2007, 11:56 AM   #7
radu2006
My Ride: e46
the dealer says it doesen't because it's from a coupe :|
i think it does cause the subs are the the same just fitted diferently...can anyone tell me for sure?
Old 11-19-2007, 12:17 PM   #8
Crescent_City
My Ride: 330XI
Did it before in a 323i
I had a 323i and bought the amp for a Coupe off of ebay to do the retrofit. As I said before it connects exactly the same. However the amp mounting bracket on the rear left side of a Coupe is different than the mounting bracket for a sedan. The subs will not fix with out getting the mounting brackets for a sedan. The Coupe subs are both connected inside of a single plastic housing then mounted under the rear deck panel. On a sedan the two subs are in seperate plastic mounting brackets and a cable connects the the two. Try going to realoem.com and looking at the diagrams.
Old 11-24-2007, 05:29 AM   #9
radu2006
My Ride: e46
i have the subs for a sedan complete with the amp...what i need to hnow is if the main amp from a coupe will work with the sedan speakers...thanks
Old 11-24-2007, 07:25 AM   #10
NOVAbimmer
My Ride: E60M
just buy an aftermarket system...You'll be much happier
NOVAbimmer is offline   Reply With Quote
Old 11-25-2007, 07:23 AM   #11
radu2006
My Ride: e46
i allready have hk...
