The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 167 votes, 4.98 average.
Old 12-06-2007, 04:32 PM   #261
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
NOOOO - at least with the strut bar - you can put spacers in to make it clear - i had to do the same after the SC install (the bigger injectors make the engine cover sit higher)
what is in the s package - what motor do you have? Do you have the M56 or the M54 like me? Contact ESS and see what they can do for you. They offer NA ECU upgrades
/_________\
O==[][]==O
Old 12-06-2007, 04:42 PM   #262
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
^ DINAN isn't all its cracked up to be anyway, you can do better, I think SOMEONE has software for SULEV motors. Try Samir @ Technik, maybe he knows, as they are based in CA
-Brendan
Old 12-06-2007, 04:44 PM   #263
TRP
My Ride: e46
I am seriously bummed. Damn this M56 motor.
The S Package was:
ECU/DME
Transmission ECU
Intake
Exhaust
Strut Tie bar
pedal covers (I swapped those for new floor mats, because who really needs pedal covers?)
- DME won't update as it's incompatible.
- Tranny ecu update is kind of pointless without the ecu update
- Intake - I guess it can stay... but I suspect it is what is causing the motor to run like a tractor.
- Exhaust can most likely stay but needs to be adjusted because it's hitting the bumper when the motor vibrates (due to items listed above) sounds like a wood pecker in the back seat... datdatdatdatdatdat.. burnt paint, etc.
- Strut tie bar hits the engine cover - would need to shim the strut tie bar a good 3/8ths of an inch. Which would put all the stress on the strut bolts - not the lip of the front clip / strut towers; = That's bad... mmmkay?
- Floor mats - yeah.. not paying for them individually. If they were a freebee with the S package, fine - but seriously I'm not paying $150.00 for them.
What a bummer. What a HUGE waste of time. Kind of an embarrassment too, I posted all about it, how cool it was, etc. Now I'm *that* f'n guy.
The shop who installed it all has been pretty helpful. I can't fault them, they installed what DINAN sent them. Someone in Morgan Hill over looked the M56 part of my vehicle description. *THAT* guy needs a kick in the nuts.
TRP is offline   Reply With Quote
Old 12-06-2007, 04:45 PM   #264
330i ZHP
330i ZHP's Avatar
agreed on the dinan comment...even though i just traded a stock 330 tb for a dinan tb
/_________\
O==[][]==O
Old 12-06-2007, 04:47 PM   #265
330i ZHP
330i ZHP's Avatar
can you run a bar meant for an M3 instead? I know they work on regular e46 - and they have more clearance
/_________\
O==[][]==O
Old 12-06-2007, 04:48 PM   #266
ACS Rob
pinoyfanatic
My Ride: This --->
sorry to hear the bad news ted...
ACS Rob is offline   Reply With Quote
Old 12-06-2007, 04:50 PM   #267
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & ///M3
Send a message via AIM to BMWPower06
Originally Posted by TRP View Post
BMWPower06 - which BBS wheels do you have on your car? CH? They don't look the same as the ones on 330's Touring...
is that good or bad? But yea they are the same, staggered 19s
his are CHs as well - they are the same size as well
Current: E60 M5 6MT; E46 M3 6MT
Sold: E46 330CiA; E36 M3/2/5; E60 M5 SMG
DD: B8.5 Audi S4 6MT
BMWPower06 is offline   Reply With Quote
Old 12-06-2007, 04:52 PM   #268
BMWPower06
BMWPower06's Avatar
Damn Stewie u mod fast, cant believe you've already done all that
Old 12-06-2007, 04:55 PM   #269
TRP
My Ride: e46
Does the M3 bar fit on a sedan? the touring is a sedan forward of the b-billar. I wonder...
I'll look into the ECU stuff later, for now I'm just burnt out on it. A LOT of time, money, and energy went into this and what I have left to show is kind of a steaming pile of dung.
Again - it could be worse I suppose.
Old 12-06-2007, 04:57 PM   #270
330i ZHP
330i ZHP's Avatar
yea, now that I can start the zhp again i might be tempted to pull it out of the garage and pull the wagon in and lower the rear...
(although I need to lower the rear of the sedan as well)
/_________\
O==[][]==O
Old 12-06-2007, 04:58 PM   #271
330i ZHP
330i ZHP's Avatar
I would hope that Dinan supplier would be glad to re-imburse your money and maybe compensate your losses to the installer
/_________\
O==[][]==O
Old 12-06-2007, 06:18 PM   #272
TRP
My Ride: e46
The install shop said they will do what ever I want. If I want to return the car to stock - they will, no issue at all. INCLUDING an OEM exhaust. They have been very supportive. They said they'd refund the money tomorrow. I just need to tell them how far I want to roll the car back. I may want to keep the Exhaust and Intake if we can get the car to run right (lots of vibrations right now...)
The strut tie bar serves no real purpose - so it's gone - imho.
Old 12-06-2007, 06:40 PM   #273
330i ZHP
330i ZHP's Avatar
cool - Paul at eurospec has the CF front bar for 99
can i see a picture of your motor to try to get a better idea
/_________\
O==[][]==O
Old 12-06-2007, 07:31 PM   #274
UncleDon
My Ride: '05 325iT '86 911
I have an OEM M3 strut bar on my Touring, it fits great and it does add some extra stiffness that you can feel. The bar fits so close to the hood that it leaves a faint indent in the under hood insulation just in the center leaving more clearance between the engine and the bar.
Also the rubber hangers that support the rear muffler are easy to adjust down by putting spacers like nuts or washers between the hangers and the underbody.
UncleDon is offline   Reply With Quote
Old 12-06-2007, 07:33 PM   #275
UncleDon
The M3 bar is about $250 to $300 new so this is a better deal if it fits.
Old 12-06-2007, 07:40 PM   #276
southpaw
My Ride: E36 M3 and E36 318ti
I WANT A TOURING!!!!!!!!!
LETS TRADE..
hot damn....i just jizzed a little...
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 12-06-2007, 07:43 PM   #277
TRP
My Ride: e46
Reeeheeehheeelllly?
Interesting. So.. I'm not going to close my hood and put a huge whonk in it from the perches from an M3 strut tie bar?
Unc'Don - do you have sway bars? If so which ones? (size, etc.)
Regarding the adjustment of the muffler - I'll most likely build some shims out of sheet steel stock and shim it down. If I can do that I'll keep it on there. Do you have an intake on your touring?
Things may be looking up.
Old 12-06-2007, 08:15 PM   #278
UncleDon
Reeeheeehheeelllly?
Other than the Bekkers lowering cups in the front, my suspension is all stock Sports Package. I tried Eibach Pro springs but the ride quality got a little too bouncy. I like the balance between ride and handling that BMW has engineered into the car. I love the look of the lowered cars with 19's but I don't want the stiff ride... that's what my 911 is for.
I suggested nuts or washers to shim down the exhaust hangers because it's very easy to put them on the studs between the hanger and the underbody. You'll see when you look under there.
My intake is also stock, but my rear muffler is a ZHP.
Old 12-06-2007, 08:17 PM   #279
330i ZHP
330i ZHP's Avatar
when i installed teh SS on the sedan it hit the diffuser...i had to trim the diffuser slightly and adjust the rear hangers - now, no more rattle
I now wish I hadnt sold my ZHP full exhaust...sad
/_________\
O==[][]==O
Old 12-06-2007, 08:20 PM   #280
BMWPower06
BMWPower06's Avatar
time to update teh sig
Rate This Thread
