The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 167 votes, 4.98 average.
Old 01-21-2010, 12:47 AM   #1081
vtmless
My Ride: 325I
bump for 18s!!!!!!!!!!!
simply incredible Stuart
vtmless is offline   Reply With Quote
Old 01-21-2010, 09:15 AM   #1082
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
thanks - now what to do with the 17s
/_________\
O==[][]==O
Old 01-21-2010, 11:11 AM   #1083
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
*cough*
-Brendan
Old 01-24-2010, 12:36 AM   #1084
330i ZHP
330i ZHP's Avatar
so, either the tensioner was the cause or the car hiccup'ing at startup and the belt bouncing....broken tensioner, belt wasted, ac belt wasted, tensioner pulley for the ac belt wasted, water pump pulley wasted...and of course....the oil pump housing cracked where the belt tensioner bolts to it.
thanks to Chris (Phrozen) I have a possible spare...thanks to Seth I have the main tensioner (I figured it was toast as soon as it happened and called him to grab one from work...thank you....I will borrow the water pump pulley and the belts from the sedan...poor parts car...(although Ash said her car might have one in it)
I guess I will take the NOW two broken oil pump housings to the machine shop and have them weld the broken tabs to each and re-thread the hole (or heli-coil)
I am starting to wonder if the ESS supplied 1750mm belt is too tight and causes some stress to the tensioner
I have to take the front strut assemblies out of the sedan before I can go forward with the repairs on the wagon so I can put the lower threaded sleeve back on the coil-over, adjust the camber on the front and mount the headlight adjuster switch (also borrowed for the wagon - since in my haste during one of the attempts to figure out the noise in the front suspension on that car I broke it)
I also need to take the front strut assemblies apart on the wagon to swap the bearing assemblies that Vorshlag sent (again in an effort to rid that car of the front suspension rattle).
I also now have half of my kitchen torn apart waiting on new oven, new counter tops and a new section of cabinets
Oh yea, and school starts this week
/_________\
O==[][]==O
Old 01-25-2010, 02:48 PM   #1085
TRP
My Ride: e46
Damn. That's a lot of things up in the air at one time. Good luck with the multiple fixes.
Could be worse - you could live Canada. (/me ducks...)
TRP is offline   Reply With Quote
Old 01-25-2010, 09:44 PM   #1086
330i ZHP
330i ZHP's Avatar
fixes to sedan suspension complete, wagon engine stuff complete and some more remodeling demolition, and about to go put the sedan engine parts back done
/_________\
O==[][]==O
Old 01-25-2010, 10:46 PM   #1087
jreid
My Ride: a car
what size tires were you running on your ch's ????????
PS:i love your car!!
jreid is offline   Reply With Quote
Old 01-25-2010, 11:06 PM   #1088
330i ZHP
330i ZHP's Avatar
255/30 19 front and 265/30 19 rear (depending on the tire design, as in rounded sidewalls or different offset wheels, I could go up to a 285 maybe more depending on the wheel et)
The wagon and the sedan are back together, checked oil and coolant on both cars, no signs of blow-by or leakage The repairs I made to the wagon had to be redone this afternoon...we all make mistakes I guess...(this is after I left the banjo fitting on the high pressure vanos oil line loose where it connects to the oil filter housing...and lost 6 quarts of oil before I even made one exit on the beltway...had to have car towed home after wisely turning the engine off immediately when I sensed a problem). I had to take the airbox, MAF, rad fan, alt, ps, sc pulleys, and thermostat housing/upper hose off to get to the lower line fitting to tighten it...I thought I had it installed. Oh well
Spent over an hour removing panels under the engine and back to the differential, spraying down with brake cleaner, wiping everything down to remove the oil.
/_________\
O==[][]==O
Old 02-06-2010, 07:14 AM   #1089
Chad44
My Ride: 03' Imola 330i ZHP
Okay my wife hates me for ignoring her while reading this thread for 4 hours last night...
It's said every other post, but DAMN man your touring is beautiful! Great job, thank you for documenting the process.
She thinks she hates me now, but she's getting a touring soon and now it has a whole list of needed mods before I even own it. Oh well, she loved me through my jeep phase, lived with(and married me) through my truck years, so I bought her an e46 sedan to make up for it.. Now she will have to survive the touring years to come... After that I get my zhp or m3... Man I love e46's!!!
Chad44 is offline   Reply With Quote
Old 02-06-2010, 07:17 AM   #1090
330i ZHP
330i ZHP's Avatar
thank you
enjoy the touring and your future BMWs. I have found that one just isnt enough
/_________\
O==[][]==O
Old 02-06-2010, 09:48 AM   #1091
Imola.ZHP
My Ride: Imola ZHP
^ I agree, someday I'll have multiple BMW's, I've just got to get this first one paid off!
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 02-18-2010, 10:25 PM   #1092
mikeyb74
My Ride: Jet Black 01 325xit
Send a message via AIM to mikeyb74
Jet Black 325xit member here. Just talke the time to read your thread. I am impressed! Subbed
The BMW e46 3er Sport Wagen...
"The station wagon that’s finally gorgeous enough, engaging enough to drive, and sufficiently
swell to lure folks out of those cumbersome utes." -Car and Driver
It's funny... people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes. You can be an douchebag in either a Echo or an Escalade.
mikeyb74 is offline   Reply With Quote
Old 02-18-2010, 11:27 PM   #1093
rares
My Ride: 02 S54
Send a message via AIM to rares Send a message via Yahoo to rares
wow, looong read but worth it.. OP you are a beast... inspiration to me personally... thank you for documenting all this... I am never selling my e46 and now you are part of that decision...
thank for your hard work...
keep up the good work
rares is offline   Reply With Quote
Old 02-19-2010, 09:20 AM   #1094
mikeyb74
+1
Well worth the read.
Old 02-19-2010, 09:23 AM   #1095
phrozen06
phrozen06's Avatar
My Ride: E46, E92 M3, R32 VW
Send a message via Yahoo to phrozen06
I need to drive Stuarts sedan and touring the next time I stop by.
Need to feel the difference between the TS2+ and TS3.
Edit: I'll settle for driving the touring...............the ZHP Sedan is too pretty to drive.
phrozen06 is offline   Reply With Quote
Old 02-19-2010, 10:20 AM   #1096
simsima325
simsima325's Avatar
^ i like how you have stuarts driveway in your sig, Chris
-Brendan
Old 02-19-2010, 10:46 AM   #1097
Superhiro
My Ride: 2006 330ci ZHP
Originally Posted by 330i ZHP View Post
thank you
+1
At least it's the nice new driveway and not the rip your splitters off driveway I lol'd when Stu told me he drove Navin's car in for him so it wouldn't scrape
Ahh and for all those thinking how nice it looks, you should feel how hard that m'fer pulls
Real Name: Hiro (and NO, not Nakamura, I'm not the wind beneath your wings and I won't be your Hiro baby... )
Superhiro is offline   Reply With Quote
Old 02-19-2010, 10:48 AM   #1098
phrozen06
phrozen06's Avatar
Old 02-19-2010, 11:46 AM   #1099
mikeyb74
If I put splitters on my touring they would be ripped right off from all the frost heaves up here. ugh!!
Old 02-19-2010, 05:56 PM   #1100
330i ZHP
330i ZHP's Avatar
look how tall my grass was. i was very neglectful of the cutting last summer. I would often let it go a week or so.
/_________\
O==[][]==O
Rate This Thread
