Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 5.00 average. Display Modes
Old 11-18-2007, 12:51 PM   #1
kredden
My Ride: '03 330xi & Alfa's
DIY: Belt Replacement 2003 330xi
Just did the belts on my '03 330xi (manual, auto may be a bit different) this weekend and figured I'd post a DIY for this very simple task that may seem like a bigger deal that it really is. Dealers charge way too much for this!
First of all, you are responsible for what you do to your car, not me. These are simply the steps I used to perform the task. (Note that for this DIY "left" and "right" are as you are standing in front of the car looking at the engine). Now that that is over with...
These are the two belts being replaced, the smaller is the AC belt and the larger is the alternator/serpentine belt. I bought the pair for about $20.
Here are the tools that I used to change the belts. You can easily get by with fewer but I do quite a bit of work on my cars so have tons of tools. The "special" tools you may not have in your collection are the following: T25 Torx bit socket, T50 Torx bit socket, and 8mm Hex bit socket. You can buy these from Sears or ACE Hardware pretty cheaply.
First you need to remove the air intake piece that sits on top of the fan shroud by pulling out the three retaining clips that the arrows point to. Carefully pry up the part that looks like a nail head with the screwdriver just enough so you can grab it with the needle nose pliers. Once you have it with the pliers just pull slowly and steadily and it will come out. Be extra careful if you are working in the cold as the plastic could be brittle. Once the three clips are removed you should be able to lift up the intake and wiggle it out of the rubber connection to the air filter housing.
Here is a pic of what you are pulling out.
Now the air intake is off.
Next remove the bolt on the left holding the fan shroud in. This is where you will use the T25 Torx bit. Interestingly enough the "bolt" on the right side is actually another of those plastic connectors similar to those that held the intake in. Carefully remove that like you did the others.
Once those are out you need to remove the two electrical connectors on the left side of the shroud. The smaller connector might be a little tough to remove, you push the tab on the top down and carefully wiggle it off. The big connector should be pretty easy to get off.
Once you have the electrical connectors off you will need to remove the wires from the retainer holding it to the shroud. I found this to be the hardest part of the DIY :-). The retainer doesn't really bend so you need to lift the shroud a bit so you can get your fingers in there to wiggle out the wires. Be careful as you don't want to break through the insulation on the wires.
Once that is done you should be able to easily (and slowly) lift the fan/shroud combo out of the car, the right side may catch a bit so be careful. Here is the fan and shroud after it has been removed.
Take a look where the shroud was in the car and note the location of the retaining clips on the car. You will need to make sure that the shroud slips into all of them properly when putting it back in.
OK, now that that is out of the way here is a pic of the belts we need to replace. Note the location of the two belt tensioners that we will need to detention to get the belts off.
Here is a closeup of the AC belt with the tensioner in the middle, the AC belt needs to come off first.
Can only post 12 pics at a time I guess so on to the next batch...
kredden is offline   Reply With Quote
Old 11-18-2007, 01:28 PM   #2
kredden
Next you need to remove the dust cap off of the AC tensioner.
Here's an somewhat fuzzy picture of what the cap looks like.
Now we need to make use of the T50 Torx bit. To detension the tensioner you turn it clockwise with the ratchet. If you have it as shown in this picture, you push down on the ratchet. This tensioner is not very stiff and should move easily. Mine looked to be in great shape so I didn't replace it.
While holding the tensioner in a detensioned state you should be able to easily remove the AC belt with your other hand.
Now we move on to the alternator (or serpentine) belt tensioner. This is where you make use of the 8mm hex bit socket. A little caution here. This tensioner is MUCH stiffer than the one for the AC belt so make sure you use a quality hex socket bit that will not round off! I used a craftsman one from Sears. You will also need a socket wrench with a longer handle as you are going to have to apply quite a bit of force to get it to move enough.
Here is a shot of the tensioner with its cap still on.
And now with the cap removed. To get these caps off you carefully pry them off with a flat bladed screw driver. They will most likely pop off and go flying. Also I should mention that you should be careful when working down here so that you don't ding your radiator with any of the tools!
At this point it would be wise to make a simple drawing of the routing that the belt uses around the various pulleys so you don't get confused when putting it back on!
Here I am about to detention the tensioner. Note that I put the reverse clicker on the socket wrench only so I could take the picture without holding it. This one also detensions in the clockwise manner, I found it more convenient to pull this one up rather than pushing down so the wrench is shown on the opposite side of the tensioner as compared the the AC one. As I mentioned, this one takes a lot more force to move so be careful and don't let it snap back as this could break the tensioner! Slow and steady is the name of the game here.
With the greater force needed this belt is a little trickier to get off but you can do it! Here it is almost off snagged on the bit. Just wiggle the bit out and the belt basically falls off. Once again my tensioner appeared to be in great shape so I didn't replace it.
Here we are with both the belts off.
Now time to get the new belts on. First we put the alt belt on. Look at the drawing you made (you did make that drawing didn't you?) and put the belt on all the pulleys except for the tensioner pulley so that it appears as in the picture below. Once that is done put the belt around the hex bit so that you will be able to slip the belt on when the tensioner is detensioned. Now pull up on the socket wrench to detension the tensioner and slip the belt onto the tensioner pulley. Let off the tension slowly. Once that is done check how the belt it situated on each of the pulleys to make sure it is on right, more than likely one of them won't be quite right so detension it a bit again and fix the belt.
Once the belt is situated on all the pulleys it should look as it did before you started .
Old 11-18-2007, 01:37 PM   #3
kredden
Now to finish up...
Now we need to get the AC belt back on. This one is much simpler. Switch back to the T50 Torx bit and place the belt onto the pulleys as shown in the pic below. Then detension the tensioner by pushing down on the ratchet.
Slip the belt over the top of the pulley and let off on the tension. Now check the belt to make sure it is on properly, if not detension a bit and fix it.
Put the dust covers back on to the tensioners and make sure they are seated all the way. Now all you need to do is put the fan/shroud assembly and intake back in. Be careful slipping the wiring back into the retainer on the shroud and make sure that when you drop the shroud in that it rests in the retainers on the radiator properly. To get the plastic clip holding the right side of the shroud to the radiator you may have to squeeze the end of it together a bit to get it to go back in. Make sure all the clips are pushed in all the way and you are good to go!
This was my first time doing this procedure on my 330 and it took about 30 minutes (including the extra time needed to get the right pictures), without the picture taking it probably would have taken me about 10-15 mins.
Hope you find this useful.
Kevin
Old 11-18-2007, 08:56 PM   #4
Krazee
My Ride: 325XI
Kevin
Very nice writeup!! Gave me a great deal of information on how to do this for the future replacement. Man first time eh... that is fast for 30 mins... this will probably take me hours since I am so afraid of breaking things and triple checking everything... haha
Thanks again!
Krazee is offline   Reply With Quote
Old 11-19-2007, 11:26 AM   #5
markusmark
My Ride: 2001330Ci
kevin,
It's good that you told the readers to draw the path of the main belt because the drawing in the Bentley manual doesn't match reality!!
markusmark is offline   Reply With Quote
Old 11-19-2007, 09:38 PM   #6
SYN3RGY
My Ride: Brought me here.
Nice writeup. Do the tensioners automatically set the proper tension?
SYN3RGY is offline   Reply With Quote
Old 11-19-2007, 09:43 PM   #7
tsylatac
My Ride: understeers.
Holy god. That writeup is way too in depth. Love it, though! DO NOT - let a dealer do this for you. It takes 15 minutes, just go to Sears and make sure you have the T50 Torx to de-tension the pulleys (and a 18" breaker bar just to make it easy). Belts are easily available at Autozone or any other place...
Some random (mostly rogue) Belt Info
2 0 0 3 | 3 3 0 x i
RIP
tsylatac is offline   Reply With Quote
Old 11-20-2007, 11:56 AM   #8
kredden
Yes.
Kevin
Old 11-20-2007, 11:57 AM   #9
kredden
Originally Posted by markusmark View Post
kevin,
Exactly , could also take a digital pic but I found a simple drawing quicker.
Kevin
Old 11-20-2007, 12:00 PM   #10
kredden
I decided to err on the side of being too detailed to show those who haven't done it before or who were hesitant about doing it that it is just about as easy as an oil change! Actually probably even easier than on my car as I don't seem to have the little access plate underneath the oil drain bolt (haven't done an oil change on this car yet).
Kevin
Old 11-27-2007, 06:06 PM   #11
Couthope
My Ride: 2001 325ci
This is an outstanding write-up. I did my belts, water pump, thermostat, coolant, fuel filter, and some other little things this past weekend on my '01 325 ci and this was very helpful in visualizing what needed to be done for the belts. The Bentley manual was not at all clear on the best way to release the tension on the tensioner and did not, as far as I could tell, specify the need for a T50 torx, which was needed on my car as well.
All of the work was fairly straightforward but the most annoying part was snapping two of those expansion rivets -- I wish they would have used something else so that clumsy asses like me could manipulate the connectors without the risk of breaking the plastic. Though it may not have been the best idea, my substitute temporary connectors to replace the rivets before I could purchase new ones comprised an expanding drywall anchor, a washer, and a machine screw.
Couthope is offline   Reply With Quote
Old 12-24-2007, 05:41 PM   #12
auteck
My Ride: 330i
belt purchase
I agree, nice write up! But where can you get both belts for $20.00 ?
My local stealership wants $35 for the a/c belt ALONE...
auteck is offline   Reply With Quote
Old 12-31-2007, 01:00 PM   #13
kredden
Sorry, just saw this. I bought my belts from KO Performance (http://www.koperformance.com/). I looked at my invoice and they were actually $22 for the pair, the alt/power steering/water pump belt was $14.81 and the A/C belt was $7.21.
Kevin
Old 01-01-2008, 11:27 PM   #14
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
at what millage do you recommend doing this?
does it depend on your geographic location depending on weather conditions and such?
wish I could take this on myself...but I have a strong feeling something won't go as planned.
nice write up!
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 01-02-2008, 06:33 AM   #15
kredden
I usually pay much closer attention to belts after about 60K miles when doing oil changes and other maintenance. You look for small cracks in the ribbing. when you start to see those then it's time to change the belts.
Kevin
Old 01-14-2008, 08:51 AM   #16
bombguy
bombguy's Avatar
My Ride: 2004 M3
Awesome write up...I will be doing this in the near future!!
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 01-17-2008, 02:17 PM   #17
BMWPLT
My Ride: 2001 325i
Great article. I think you can see the appreciation from fellow BMW owners. I plan on replacing my belts this weekend (due to squeaking noise). at 80k, its probably time.
BMWPLT is offline   Reply With Quote
Old 01-17-2008, 05:19 PM   #18
kredden
Glad you guys think it's useful.
Kevin
Old 01-19-2008, 03:34 PM   #19
richards330i
My Ride: '01 330i
great post. .. did you inspect tensioner when you changed the belts? When do tensioners tend to break down?
richards330i is offline   Reply With Quote
Old 01-19-2008, 08:11 PM   #20
kredden
My tensioners looked fine. Not sure how long they last but usually when they start going they start to squeal. I'll probably replace them around 100K if they don't start squealing before that. One of my summer cars uses one of these for the timing belt, much bigger deal if it locks up and breaks the belt as the pistons will hit the valves so that one gets replaced much more frequently.
Kevin
