Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 5.00 average. Display Modes
Old 09-02-2009, 12:55 PM   #81
X-vert
My Ride: 01 330i & 04 Tahoe
Just changed both belts, all the pulleys, tensioners and converted one to hydraulic last weekend. Hardest part was the fan (not too bad really) and tensioner conversion.
I took my time but it was not too bad at all.
Big props to all the E46 members for this DIY and keeping another car out of the stealerships!
X-vert is offline   Reply With Quote
Old 09-02-2009, 07:34 PM   #82
n2Bimmer
My Ride: Loves Corners
Is there a pic or diagram of how the belt should go onto the pulley?, in the correct order. tnx.
Old 09-02-2009, 10:48 PM   #83
Blocked Out
My Ride: Imola 330i M-Sport
great post
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 09-24-2009, 09:36 PM   #84
oney1
My Ride: 323i 2000
My power belt broke at about 119K miles. Without any belt friction on the water pump pulley removing the fan was very tough. Eventually had to rent a "fan clutch holder", but still was tough to get the fan lose. Once the fan was off the belts were simple. Both tensioners have attachments for a 5/8 socket.
oney1 is offline   Reply With Quote
Old 09-25-2009, 03:36 PM   #85
NikolaiD
My Ride: 2002 M3C
Send a message via AIM to NikolaiD Send a message via MSN to NikolaiD Send a message via Yahoo to NikolaiD
It's a lot easier to to do it from the bottom. You do not need to take any fans off to change belts. I don't know why everyone is going through so much trouble.
The biggest trouble is that on an M3 you need to unscrew 2 extra bolts that hold the oil cooler, so you can get extra clearance.
From post #76 picture #1 - on my tensioner that hole actually went through, I just used a screw driver to pull down, then pushed it in and it jams it open, so you can work with no pressure on the line. (I don't remember if it was the same on an M54, but it was the same on an M43...
10 minutes at most for this job if you just jack one corner of the car and do it from the bottom.
Edit:
Here's an excellent picture of the belts:
_______________________________________
My Ride: 2002 M3C
NikolaiD is offline   Reply With Quote
Old 11-03-2009, 11:28 PM   #86
blarf
My Ride: 323i, 325iT, 540iT
Did the belts on my '00 323i (built July 00) manual this morning. Probably worth mentioning:
- There were four rivets on the intake muffler, not three. Not hard to spot, but it's worth looking if you're doing this job for the first time
- My water pump / ps / alt belt tensioner took ~9mm hex drive, not 8mm. I used an 8mm without damage, but the proper size is always better. If you're unsure, buy the sockets from Sears and return the ones you don't use.
- My A/C tensioner was indeed a T-50 (not T-55/T-60/T-65)
blarf is offline   Reply With Quote
Old 11-04-2009, 09:40 AM   #87
CHFBrian
My Ride: 2001 330i
Just changed both belts this weekend. I got myself the fan clutch holder tool, but not the open-ended wrench. I figured I'd be able to find one locally. What ended up happened is that I borrowed a 32mm wrench, but it was too fat for the holder tool to fit in at the same time. I just used the mallet method instead, which worked great.
The rest of the belt replacement went off without a hitch. A local mechanic wanted a few hundred dollars to do it - I got better parts at half the price and saved a couple of hundred on labor. It felt great
CHFBrian is offline   Reply With Quote
Old 11-04-2009, 09:59 AM   #88
jabela
My Ride: 2002 325ci
I took the belt off my 325ci and checked the waterpump by spinning it with my hand. It basically spun about a quarter turn fairly easily, but after that it becomes noticeably harder to turn (I'm guessing because now it's starting to pump coolant).
Is that normal? I'm not sure what it should feel like and I'm trying to figure out if it needs replacing.
Any thoughts?
thanks.
Also, on a side note, everyone seems to be sold out of the Graf metal impeller water pump. 11 51 7 527 910 GRAF
Do they make them anymore?
What's a good alternative?
2002 BMW 325ci /// Sport Pkg /// 5 spd
Modern Apothecary
jabela is offline   Reply With Quote
Old 11-07-2009, 04:47 PM   #89
queezy1
My Ride: '04 BMW 325 SMG
Thanks for the Thorough DIY!
Just took me about 30 minutes, most of which was given to the serpentine belt tensioner. It is tough, but very doable.
The fan shroud was actually super easy on my car, and the wiring harness was simple to release.
Parts at the Stealership: Both belts = under $40
Quote at my Indie Shop for Install Only = $168
So a savings of $168+ parts markup was saved here!
Thanks!
2004 325i SMG
Mods: BMW Performance Intake, Carbon Fiber Strut Bar, LED Angel Eyes, Xenesis Head/Fog Lights, Xexon Interiors, Clears all around, Matte Black Grille, M3 Trunk Lip Spoiler, Rear Tint, Black/White Roundels, Silver Trim/Knob, Silver Gauges/Rings, Aluminum Pedals, Alpine MP3 Changer, XM, GPS & Parrot Bluetooth all Hardwired, Alpine Speakers, Sub & Amps wired with Monster Connectors/Wires, Custom Sub Enclosure & Amp Rack
queezy1 is offline   Reply With Quote
Old 11-07-2009, 05:34 PM   #90
mujjuman
My Ride: not an E46
Thanks!
do u have an smg trans in your 325?
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 11-08-2009, 02:07 PM   #91
queezy1
Yes, was an option on the '04's.
2004 325i SMG
Old 11-08-2009, 04:02 PM   #92
mujjuman
My Ride: not an E46
Oh cool. I def did not know that. I knew it was an option for the 330i tho
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 11-13-2009, 10:08 AM   #93
Whammy
My Ride: ZHP
Could someone answer this question for me:
If belts are removed from the engine to replace the tensioners or the pullies, should the existing belts be placed back on the engine as long as they are not serverly worn? Or should new belts be placed on?
Whammy is offline   Reply With Quote
Old 11-13-2009, 10:08 AM   #94
Whammy
My Ride: ZHP
Duplicate post FTL.
Old 11-13-2009, 10:51 AM   #95
kredden
My Ride: '03 330xi & Alfa's
Unless they are new I'd just replace them, cheap insurance. You've already done all of the work by that point.
Kevin
kredden is offline   Reply With Quote
Old 11-13-2009, 11:16 AM   #96
spennI
My Ride: 2004 330i
My vote: Replace belts while you have them off.
spennI is offline   Reply With Quote
Old 11-13-2009, 01:07 PM   #97
Whammy
My Ride: ZHP
Kevin
That's what i thought. Thanks guys!
Old 11-19-2009, 10:02 PM   #98
Countdownbmw
Account Under Review
My Ride: 330i ZHP 6 MT, 525i
awesome diy
Countdownbmw is offline   Reply With Quote
Old 01-10-2010, 03:49 AM   #99
mcr_driver
My Ride: my favorite two feet
If you click on picture #7 in posting #2 you can see the belt routing if you look closely (at least for a 2003 330xi, I'd assume they are all pretty close if not the same). Here is a really bad sketch of the routing.
Kevin
question how different would the diagram be if you have a s/c on it? need to do mine and i'm not sure how much more different it is from your diagram, anyone with a s/c done this before?
mcr_driver is offline   Reply With Quote
Old 01-10-2010, 04:37 AM   #100
sillieidiot
My Ride: '06 AW 330ci
take a picture of your car before undoing the belt. that is what i do for my sister's car as she has an m56 so no one has pictures of the engine on here (nor the bentley manual either for some reason)
