Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 5.00 average. Display Modes
Old 01-10-2010, 05:29 AM   #101
mcr_driver
My Ride: my favorite two feet
lol how'd you find this thread man? stalking me
but yea i was hoping i get some info beforehand and not have to rely on pics but blah gonna be interesting tomorrow...
mcr_driver is offline   Reply With Quote
Old 01-10-2010, 05:32 AM   #102
sillieidiot
My Ride: '06 AW 330ci
no, i just click on new posts and pretty much look at the threads on the first thread for stuff lol
Old 01-10-2010, 12:46 PM   #103
brambimmer
My Ride: 04 BMW 330i ZHP
So are these instructions applicable to a '04 330i ZHP? One of the posts on page 4 made it sound like the 330 is different from the 325 (and for sure the M3). Did I read that right?
I know it's repetitive, but great DIY write-up and fantastic photos!
brambimmer is offline   Reply With Quote
Old 01-10-2010, 01:13 PM   #104
mcr_driver
if your zhp is a manual and that rough diagram on page 3 that i quoted works the yea go to town
Old 01-10-2010, 03:35 PM   #105
brambimmer
Sorry. Auto. Just did a visual and it appears my fan is attached to the engine. Looks like I need to buy the tools from BimmerTools (32mm Fan Clutch Wrench
and Water Pump Pulley Holder). Or are these tools I can borrow from an auto parts store?
Old 01-10-2010, 07:29 PM   #106
mcr_driver
fan clutch probably borrow not sure on pulley
Old 01-10-2010, 07:38 PM   #107
sillieidiot
you can get the 32mm wrench from sears. as for the pulley holder, i never even bought one. i just made one out of sheet metal lol
Old 01-11-2010, 02:51 AM   #108
mcr_driver
lol post a pic of it hieu? was it that thing you used to get john's out when we did the thermostat stuff?
Old 01-11-2010, 04:41 AM   #109
///Mechanic
My Ride: None currently
1 1/4" wrench will work also
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 01-23-2010, 08:21 PM   #110
GZ1
My Ride: 2002 325i
Many thanks, dude! Saved me about $170. I have a 325i automatic so I had more work to do to get the fan/shroud off. Someone else had a post showing this process using a solid whack with a 32mm wrench on the fan clutch nut so you don't need the fancy clutch-holding tool. Worked great! The photos were outstanding.
GZ1 is offline   Reply With Quote
Old 02-10-2010, 10:22 AM   #111
footy786
My Ride: bmw e46 320
great diy but im having a problem at the very last stage...putting the alt belt back on!.....i cant get it on the last pulley (one with a t50 screw), just cant relieve the tension. any suggestions?
footy786 is offline   Reply With Quote
Old 03-06-2010, 08:39 PM   #112
littlegti
My Ride: 2002 330ci conv
I just finished checking my pulleys and changing my belts. I found it better to get a 16mm socket on the spot between the A/C and the tensioner pulley instead of directly on the tensioner pulley.
littlegti is offline   Reply With Quote
Old 03-13-2010, 03:13 PM   #113
328cmayi
My Ride: 328ci
Thanks for the excellent job on this DIY. Serpentine belt was in shreds - no question what the problem was! Followed your directions to a 'T' and then notice that I don't have an idler pulley! (aha! The source of the shreded belt - didnt notice that until I looked at the good pics from the article).... The bearing assembly must have failed completely - found the pulley in the engine pan...no sign of the bearing assembly anywhere! The Autozone up the street had one in stock for $38 (thank god) - rushed back, put on the new idler pulley and had both belts on in under 10 minutes. Thanks again!
328cmayi is offline   Reply With Quote
Old 03-31-2010, 01:15 PM   #114
carthageHannial
My Ride: 330CI
How much coolant did you bleed when repl. w. pump?
Hate to start a thread just for that ... searched and couldn't find it ... How much coolant did you guys have to bleed to replace the water pump? ....and while I'm at it; a little heads up ... an 01 with a production date 00 supposedly have mechanical tensioner. Mine was hydraulic!!! Go figure.
carthageHannial is offline   Reply With Quote
Old 04-23-2010, 01:35 PM   #115
msb046
My Ride: 2001 330xi
Started noticing a squealing coming from my belts/pulleys. Whats the best way to diagnose which pulleys need to be replaced (Belts are OEM and I replaced about 15k miles ago so they should be good)? In particular, what kind of "play" should I be feeling for? Btw, I have an '01 330xi w/ mechanical tensioner, and pulleys and tensioner are originals.
msb046 is offline   Reply With Quote
Old 04-26-2010, 10:50 AM   #116
Chr325is
Chr325is's Avatar
My Ride: 325i
Thanks for this, it was much easier than I thought it was going to be.
-Chris
2004 325i 5MT ZSP
Mods
KW V1, H&R F/R Swaybars, Rogue Engineering RSMs, Meyle HD FCABs,
M3 RTAB with Rogue Engineering Shims, UUC Motorwerks Evo3 SSK, ECIS Intake,
Vorsteiner CF Console, 20% Tint, VMR 18x8.5F 18x9.5R CSL Reps
MTech 2 Front Bumper, M3 Steering Wheel.
Chr325is is offline   Reply With Quote
Old 05-17-2010, 02:07 PM   #117
emjlr3
My Ride: 2004 325xi
the bottom belt (forget which it is) can be done with the car on ramps from the under the car - took about 10-15 minutes
for anyone who has the fan bolted to the engine - please post some pics/a how to on its removal
I am having a hell of a time try to get a wrench to fit around the bolt to unscrew it - i just cant seem to get it down there in good position and get it turning
some pics and a short writeup would go a long way to assuring me that I am doing the right thing, and to assist me in actually doing it
emjlr3 is offline   Reply With Quote
Old 05-20-2010, 12:17 PM   #118
Oz Striker
My Ride: '00 330Ci, '07 350Z
Originally Posted by SHICKS View Post
The proper way to relieve the tension on the belts is to put a 5/8 or metric equivalent on the hex stub on the tensioner bracket as shown in these pictures and rotate clockwise. No need to remove dust caps.
I'm going to be replacing my mechanical belt tensioner with another mechanical one, as well as the deflection pulley
I have a few questions before i proceed this weekend:
In order to release the tension to release the belt, i must turn the following hex nubbin on the mechanical tensioner clockwise. Ofcourse it wont turn cause its part of the metal mold of the tensioner body??.... but it decreases the tension enough to allow the belt to be released, correct?
The following pics show what reffering to:
Attached below is a pic of a new mechanical tensioner, showing the hex nubbin, from here it appears as though there is an outer and inner section, and so when the hex nubbin is turned clockwise IT WILL ROTATE . I'm picking the part up tomorrow so maybe it'll become clear then.
SECONDLY in order to get the belt back on, first do i tighten up bolts #3 to their corect torque specs or torque them fully later (in diagram below). Then do i ROTATE the same hex nubbin CLOCKWISE again, to decrease the tension allowing the belt to slide back on??
Name:	belt tensioner.jpg
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 10-17-2010, 01:16 PM   #119
mattbookpro
My Ride: 2003 325xi
Wow, great write up. I laughed at a few parts because the way you wrote stuff is exactly the way I thought it in my head as I was doing it. Getting the wire off the fan was the hardest part!
mattbookpro is offline   Reply With Quote
Old 10-27-2010, 11:57 AM   #120
cesarthegreat1
My Ride: 2002 330xi
great write up, now i need a diy to replace my cluch fan, it went out some time ago so i need to fix it.any one out there with a diy for the cluch fan. would be of great help.
cesarthegreat1 is offline   Reply With Quote
