Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 5.00 average. Display Modes
Old 01-19-2011, 06:34 PM   #121
BlueDropT
My Ride: 2000 323 CIC
I am resurecting this thread Because I am about to change my belts!
Awesome write-up!
BlueDropT is offline   Reply With Quote
Old 01-19-2011, 08:26 PM   #122
kredden
My Ride: '03 330xi & Alfa's
Great, hope it helps you out!
Kevin
kredden is offline   Reply With Quote
Old 01-21-2011, 06:42 PM   #123
BlueDropT
Kevin
Hey Kevin, Instructions were pretty much spot on aside from 2 differences
My fan is detached from the shroud held on with 3 T-30's (a royal Pain to say the least!) shroud will not come out till fan is detached,so with some finagelling I was able to squeeze my hand in to get them.
Second difference was the serpentine's adjuster was also a t-50. No problems with the install.
Now, every thing back together but still getting a whir sound coming from the serpentine side so gonna go back in and change out the adjuster I did notice an abundence of dust inside them.
Thank you for the great write up
and do you concur about the whir I'm getting being the adjuster?
Old 01-21-2011, 07:00 PM   #124
kredden
Hard to tell without hearing it but worth a look anyway.
Kevin
Old 02-19-2011, 12:30 PM   #125
brandonwish
My Ride: 02 325i 5MT
Awesome write-up. I literally just finished this and it took me about 25 minutes checking other components on the way. Thanks
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 02-22-2011, 11:09 AM   #126
kredden
Glad it continues to help even over 3 years later!
Kevin
Old 05-04-2011, 06:29 PM   #127
genes330ci
My Ride: 330ci
is this how a 330ci looks? and is the tensioners called the AC belt tensioner and the alternator tensioner? HOW hard is that job to do? thx
genes330ci is offline   Reply With Quote
Old 05-20-2012, 07:02 PM   #128
kredden
Well it's been about 4.5 years since I originally wrote up the DIY and was time to change the belts again (actually by the look of them, a little past time to do it!). Glad I wrote this up as a reminder of the steps. This time I wasn't able to get the tensioner to detention as the allen head bolt stripped. Ended up having to take the hydraulic tensioner out, drill out the allen bolt, bought a new Grade 12.9 allen bolt at ACE and a new pulley at Advance Auto (twice the price of Bav Auto, had I only known as I was there yesterday :bang head and got everything back together.
Kevin
Old 07-23-2012, 04:50 PM   #129
warmasice
My Ride: E46 Coupe
This may be a 5 year old thread but it came in useful today. Very straight forward and didn't take too long either. Thanks again. :o)
E46 M-Sport Coupe, Titan Silver, Straight 6, Full Leather, Bluetooth Prep, Lowered on Eibach Pro-Kit Springs,
Febi-Bilstein Front Bushes, Lemforder Control Arms
warmasice is offline   Reply With Quote
Old 07-23-2012, 07:50 PM   #130
kredden
Glad it helped you out.
Kevin
Old 07-23-2012, 09:09 PM   #131
VG1134
Old City Bimmer
My Ride: Classifieds
That why after all these years this forums is still helping out fellow BMW owners........
VG1134 is offline   Reply With Quote
Old 07-30-2012, 02:16 PM   #132
3rdmd
My Ride: 2003 330xi & 535xi
I have to say this explination is priceless. Thanks for an OUTSTANDING description.
3rdmd is offline   Reply With Quote
Old 06-24-2013, 03:48 PM   #133
Riverbmr3
My Ride: MB E350 & BMW 325i
what kind of tool do you use to remove the fan shroud?
Riverbmr3 is offline   Reply With Quote
Old 06-24-2013, 04:25 PM   #134
kredden
Depends on what model car you have. Mine was held in with a T25 Torx (star like end instead of hex) head bolt. Some other model cars have the fan separate from the shroud and need a slightly different procedure. If you read through the whole thread you will see what some folks with a different setup from mine did.
Kevin
Old 08-28-2013, 08:55 AM   #135
jwoolsey
My Ride: 02' 325xi 5spd.
Just changed both belts last night, awesome post man. Thanks alot.
John
jwoolsey is offline   Reply With Quote
Old 03-08-2014, 05:04 PM   #136
nickk3
My Ride: 2002 325xit
Still works great!, thanks everyone.
BTW the proper belt routing to print out if you want is here:
http://www.pelicanparts.com/BMW/tech...Drive_Belt.htm_nr_
nickk3 is offline   Reply With Quote
Old 03-09-2014, 08:35 PM   #137
bobhobnob
My Ride: 98 E46 328i
Just to add my (limited) experience... I have auto 328i with fan separate from shroud and was going to try and find a fan clutch removal tool.
I phoned the BMW mechanic to ask to borrow his snd he says just hit it with a big hammer on a 32mm wrench. I was sceptical to say the least. Did a you tube search... looked possible...
So after protecting the expansion tank and hose with bubble wrap thats whst I did.
Took 4 or 5 big hits and im not a small guy. Worked well and nothing broken. So the ghetto method does work on the auto..
bobhobnob is offline   Reply With Quote
Old 08-02-2014, 04:25 PM   #138
Crew Coach
My Ride: 2002 330CI (3002tii)
Bump for a Super DIY. Well done.
The best tool I have found for the 32mm fan clutch nut is a headset tool for bicycles. The Park Tool Co makes a very good one and widely available. A good bike shop (or vintage bike nerd) should have one.
The rubber mallet method works, and it doesn't hurt put some rags in place to catch the wrench when the nut breaks loose.
Crew Coach is offline   Reply With Quote
Old 03-09-2015, 09:49 PM   #139
kwake330xi
My Ride: 03 330xi
fan clutch nut
I have found the easiest way to break loose the fan clutch nut is to hold the nut with a 32MM wrench (I actually used a big adjustable) and tap the opposite way on the water pump pulley nuts with a hammer and long screwdriver.
On another note, I could not get my alternator belt back on for anything. No matter how I tried I could not get enough tension to slip it over the last pulley. I had to loosen the alternator bolts (which I had just tightened after replacing the OFHG) and put the belt on, and then tighten the alternator bolts and all was good. I still have no idea why I had to do that. Maybe the bolts weren't seated correctly, who knows.
kwake330xi is offline   Reply With Quote
Old 03-14-2016, 07:17 PM   #140
GabeB
My Ride: 2002 325ci
That's a good note to remember next time. I used a 32MM wrench to knock it loose. Only took about 4 tries this time. The first time it took almost half an hour. I used the bolt below the tensioners to move them over enough to get the belts on.
GabeB is offline   Reply With Quote
