Old 11-19-2007, 07:53 PM   #1
jpr
My Ride: '99 323i
DIY Camber Measurement
Here's a simple yet accurate camber gauge I put together on the cheap.
* Sears Digital Torpedo Level - Reg 34.99, On Sale for $24.99 - reads out angles to 0.1deg
* 12inch combination square - $8.99 on sale at Sears, or free if you happen to have one laying about the garage as I did
* piece of 2x6 wood, cut to about 18 1/4 inches to match the rim diameter of my wheels, also free if you happen to have it laying about already (That's for my 17inch style 119's, you may need a different length for different sized wheels)
* 3 button head screws to hold the square on the wood.
Usage is pretty quick and easy:
* hold the wood on the rim and level it out with the bubble gauge on the combination square.
* hold the digital level against the long leg of the square with your other hand and read off the camber as the difference from 90deg (although in the picture I taped the level on to the wood to free a hand for the camera)
So far I've only tested it on a level-ish driveway, but the results are close within the expected range based on the last formal alignment. Most importantly though, the results have shown themsleves to be very repeatable - I get the same thing each time each time I take a reading (for a given position of the car).
Keep in mind though that the key to true accuracy is having the surface the car is on be level. Not only will any slope affect the relative balance at each wheel, but the guage is measuring from true level.
The other important thing is to set a standard load condition for your car at which you take your measurements. I suggest stripped of loose etc's and with a full tank of gas. But it doesn't really matter what it is so much as that it is the same each time you measure it.
ID:	249808   Click image for larger version
ID:	249809   Click image for larger version
jpr is offline   Reply With Quote
Old 11-21-2007, 04:28 PM   #2
FlzRider
My Ride: AW 1M
Good info!
FlzRider is offline   Reply With Quote
Old 06-01-2008, 08:45 PM   #3
328iBMW
My Ride: C320
Nice.
So then how would one (i.e. me) go about adjusting the camber?
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 06-02-2008, 01:03 PM   #4
jpr
My Ride: '99 323i
Check out post #13 in the "Alignment" thread linked in the sig below - it's got the TIS instructions attached
Old 08-18-2010, 02:20 AM   #5
SDpnoy
My Ride: 330Ci and M3
Whoa! I was just looking at getting the torpedo last night from sears and making something like this too. Great info!
SDpnoy is offline   Reply With Quote
Old 01-15-2011, 01:11 PM   #6
Minnoe07
My Ride: 2004 BMW 330Ci
You can use the torpedo level to measure the floor. Subtract that angle from the measurement that you get off the wheel.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
