Old 01-15-2011, 06:13 AM   #1
quirino18
My Ride: 2000 323CI AUTO TIPT
P1189 code?
hello everyone!
ok here i go, a few day ago i felt my car kind of vibrating evently so i know it wasnt an injector or a missfire so i chane the plugs hoping this will go away but it didnt, about 3 to 4 day after the engine light turned on and i ran the scaner and came back with P1189 nothing else!
i was doing some seraching and all i found was 1189/1188 together and that doesnt look like its my issue because if it was an air leak both banks would of triger a code as everyone is saying here! i also replaced the intake hoses about 8 months ago i had P0042 (small leak) and it went away so i dont think thats the issue!
does anyone have any other idea?? could it be the O2 sensor itself? does anyone know what resistance it should have if its good & bad??
thanks in advance for any input!!
quirino18 is offline   Reply With Quote
Old 01-15-2011, 08:02 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
First of all, you shouldn't have changed the plugs without scanning the car first. You either wasted your money on that or you just put in new plugs because the old ones were due.
Anyways, if you were having an O2 sensor problem the car would give you a code for that. What vibration are you having? You weren't specific, such as in idle or driving, etc.
Double check the hoses again, maybe check the hoses by the secondary air pump as well and make sure to search the forum with the code that you have.
Old 01-15-2011, 10:44 AM   #3
quirino18
i didnt change the plugs because i had a code i changed them because it was time for a tune-up and i also noticed a small vibration but i didnt have any codes!
i feel it vibrating when is in idle its very little dough it feels like the normal engine vibration but a bit stronger just enough for me to know its doing it , it drives normal it doesnt missfire or anything runs really good...
Old 01-15-2011, 10:45 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Look for any vacuum leaks and
Read this
http://forum.e46fanatics.com/showthr...light=low+idle
