Old 05-09-2002, 10:40 PM   #1
K-white330ci
My Ride: 330
ecis intake
325/330 use the same intake rite, so there is absolute no difference for 325 and 330? how bout the year difference, for example will year 02 be different than others or its the same as any others.?
K-white330ci is offline   Reply With Quote
Old 05-09-2002, 11:00 PM   #2
pix335i
Mod Junkie
pix335i's Avatar
My Ride: 2007 335i Coupe
Re: ecis intake
Just so you know, the 325 and 330 ECIS intakes are different......
pix335i is offline   Reply With Quote
Old 05-10-2002, 07:41 PM   #3
KevinJ_2k1_325ci
My Ride: 2001 325ci
Stock I believe is not difference but ECIS is
The only difference on the ECIS is the filter size. The 325 uses a 6 inch filter and 330 uses a 7 inch. I don't know why there is a difference in filter size. The old e36 325/328 used a 9 inch filter! From what I know, depending on the filter diameter, a 6 inch filter will support a car up to 280 HP and a 7 inch is like 340hp. The difference could be the 330 draws more air and requires a larger filter but again the e36 used a 9" so it makes no sense.
KevinJ_2k1_325ci is offline   Reply With Quote
