Old 11-21-2007, 03:17 PM   #1
ssm1991
My Ride: 2004 325i
Sucking jet pump?
Anyone knows what the "SUCKING JET PUMP" in the RealOEM image below does?
I'm trying to diagnose a lean mixture problem on acceleration, possibly caused by a vacuum leak or a defective fuel regulator/filter (had it changed 9 months ago).
The "SUPPORT" connector is actually F-shaped:
- the bottom connects to the intake elbow right after the MAF
- the top goes to the "SUCKING JET PUMP"
- a third narrower one connects to the fuel regulator/filter, presumably to adjust the fuel pressure depending on the intake pressure. The SUPPORT is however connected between the throttle and the MAF, so I'm not sure how much it affects fuel pressure.
ssm1991 is offline   Reply With Quote
Old 11-21-2007, 06:18 PM   #2
S716A
My Ride: 2004 330Ci ZHP
Sure thing. The "Sucking Jet Pump" is just a poor translation. It's actually the vacuum check valve for the power brake booster.
Ted
2004 BMW 330Ci ZHP
2000 BMW 323i Wagon
1990 BMW 325i Coupe
1999 Porsche 996 Carrera
1960 Austin Healey Sprite
S716A is offline   Reply With Quote
Old 11-21-2007, 06:58 PM   #3
Commander FAT
Network Analyst
My Ride: 2002 330Ci
^ Hot damn I was just about to say pretty much the same thing.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 11-21-2007, 10:10 PM   #4
ssm1991
My Ride: 2004 325i
Thanks, makes sense for the brake booster.
Although I'm still wondering why the fuel regulator/filter vacuum hose is connected to the F-shaped joint (support) which is before the throttle. I actually tested it by disconnecting it from the F-joint and connecting a syringe to it. Increasing the air pressure also increases the fuel pressure.
But the location (before the throttle) makes me wonder if the air pressure variations at that point affect it substantially to make a difference, compared to putting it in the intake manifold after the throttle where the pressures are very different between idle and WOT.
