Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 11-07-2007, 04:30 PM   #1
sstainba
My Ride: 02 325Ci
antifreeze/coolant ?
My coolant light came no and I was wondering what brand of antifreeze I should use... ?
sstainba is offline   Reply With Quote
Old 11-07-2007, 04:47 PM   #2
977
My Ride: 323 SE 1999
BMW Coolant - it lubricates the water pump, and so is a little more crucial to stick to OEM here.
If your car is swallowing fluid a little fast, your pump is probably on the way out, same way mine is.
I race therefore I am. ~ In tires we trust. ~ Front Slip Angle = Rear Slip Angle
977 is offline   Reply With Quote
Old 11-07-2007, 05:24 PM   #3
sstainba
My Ride: 02 325Ci
eh... i haven't put fluid in it in over 2 years. i'm not worried about the pump.
Old 11-07-2007, 08:18 PM   #4
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
oh damn, i didn't know it lubricates the water pump.
i'm just running water and some water wetter.
SL Blak Soldier is offline   Reply With Quote
Old 11-08-2007, 11:40 AM   #5
markusmark
My Ride: 2001330Ci
Do yourself and the car a favor - flush the cooling system, including the block drain under the exhaust manifold, and refill with a 50/50 mix of BMW coolant and distilled water only.
markusmark is offline   Reply With Quote
Old 11-22-2007, 12:55 AM   #6
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
You should be, BMW water pumps are notoriously bad.
Use OEM BMW Blue coolant only with a 50/50 distilled water coolant mix. You can also add water wetter as well if you like.
Regular antifreeze is to corrosive and you will notice that the Tstat and the water pump will being to go after using it. (Not overnight but will definitely shorten the lifespan especially of the Tstat with its plastic housing).
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
