Thread Tools Search this Thread Rating: Thread Rating: 132 votes, 4.97 average.
Old 03-22-2012, 12:03 AM   #2081
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Originally Posted by Rajaie View Post
You didn't say how many miles on the car.
Be sure you have all OEM parts, especially the sensors. Even aftermarket crankcase vent valves fail in a few days.
You didn't mention replacing the fuel filter. That could be it.
A failing camshaft position sensor would likely cause more symptoms.
The vanos seals are a good candidate.
Be sure to also install the rattle kit. The 323 is susceptible to a vanos rattle.
160,000 miles.
Yes, all parts are oem from dealer.
I'll give the fuel filter a shot. after the pressure tester giving normal readings, I initially ruled out fuel up to the rail.
Thanks for the advice.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 03-22-2012, 12:13 AM   #2082
Stinger9
My Ride: '04 330Ci
Originally Posted by TKC View Post
160,000 miles.
Just so you'll know, a complete fuel delivery system check includes a volume check, not just a static pressure check.
Don't hold me to this, but I recall that you'd expect to see a gallon in a minute.
I had an idle hiccup too, and I have a manual. I installed both vanos fixes and the hiccup decreased lots. But I still see one once in a while.
Old 03-22-2012, 01:58 AM   #2083
Rajaie
My Ride: 528i 06/00
Try slightly crimping the vanos solenoid cable connector pin receptacles.
Rajaie is offline   Reply With Quote
Old 03-22-2012, 09:16 AM   #2084
Stinger9
My Ride: '04 330Ci
Thanks for the tip.
I don't recall what this electrical connector looks like. Is this easily accessible and intuitively obvious, or would it require a bit of disassembly to properly access the receptacles?
Old 03-22-2012, 12:13 PM   #2085
Rajaie
My Ride: 528i 06/00
Thanks for the tip.
Pretty easy. You simply remove the solenoid connector and tighten the connector pin holes. Use a strait pick or such. Only slightly crimp.
You are simply tightening the connection between the cable and solenoid connectors.
Old 03-22-2012, 12:17 PM   #2086
trj
My Ride: 325Ci
I am finally going to do the vanos seals, and I have a couple of questions. Honestly, I didn't go though all 100 pages of the thread, it might have been discussed earlier but I just need to know the parts I will be needing.
Not sure if the seals has been done yet, I get no rattle and I bought the car used. But I would definitely want to get better mpg and better lower torque response.
I am getting a VCG leak so I am thinking to do the VANOS seals along with it, while I am there.
Does the double Vanos seals kit include everything I need or do I need to order: a vanos gasket, $7, and two oil hose washers, $0.50(these are mentioned in beisan systems website but doesn't say where to get them from) separately?
Any help would be great.
Might do this with a local fanatic so ordering 2 sets and doing it together. Just a little nervous since I am going to see the inside of the engine in my car for the first time and will know now how the PO treated it and I will have another car with an open engine next to me to compare with.
Old 03-22-2012, 12:39 PM   #2087
Rajaie
My Ride: 528i 06/00
You do need to get the vanos gasket and two oil hose washers.
You can buy these and other parts from your BMW dealership.
You can also buy BMW parts online.
Here's a dealership that sells online for good discounts.
www.getbmwparts.com
Here's a good retailer that specifies if a manufacturer is OEM.
www.rmeuropean.com
Good luck on the repair and let me know if you have any questions.
You are always welcome to call during the repair.
Old 03-22-2012, 01:00 PM   #2088
trj
My Ride: 325Ci
www.getbmwparts.com
www.rmeuropean.com
Do you mean I do not need the mentioned vanos gasket and the two oil hose washers for this DIY(replacing VANOS seals) at all?
Where(what/when) are these parts used?
I am asking this because I have ended up ordering wrong and unnecessary parts many times, so just wanted to make sure before I jump into it and end up short of parts.
Old 03-22-2012, 01:05 PM   #2089
Rajaie
My Ride: 528i 06/00
You do need to purchase the vanos gasket and two oil hose washers. They are needed and are not part of the Beisan seals repair kit.
The vanos gasket is used when remounting the vanos onto the engine head.
The two oil hose washers are used when remounting the oil hose onto the vanos.
Old 03-22-2012, 01:18 PM   #2090
trj
My Ride: 325Ci
Thanks Rajaje, cleared all my questions. Will get the list sorted out soon and make the purchase.
Old 03-22-2012, 02:46 PM   #2091
ummwillprince
My Ride: 2003 330i
Beisan seals to rebuild vanos and VCG was a success! Thanks Raj! Think I did notice it a little more responsive and better gas mileage.
I bought the car at 112k miles and the intake/exhaust pistons did seem really loose.
For me the hard part was getting the electrical connector on the camshaft position sensor off, my valve cover was leaking and got oil over it and hardened. I had to use a pair of vice grips to crush the tabs and yank it out, but it seems ok, nothing wrong with performance and no codes thrown.
ummwillprince is offline   Reply With Quote
Old 03-22-2012, 08:50 PM   #2092
Rajaie
My Ride: 528i 06/00
Congrats on the repair!
Thanks for the feedback!
Old 03-22-2012, 09:05 PM   #2093
e46hellrot
My Ride: e46
i just have mine done. after i got my vanos done i was gunning it and pushing it; is that bad?
e46hellrot is offline   Reply With Quote
Old 03-22-2012, 09:19 PM   #2094
Stinger9
My Ride: '04 330Ci
Not at all if you have a jump car!
Old 03-22-2012, 09:40 PM   #2095
TR4G-
My Ride: '01 325xi, '90 325iC
got this kit back in October, but I have yet to install it! I'm going to tackle it along with my VCG and possibly sparks this weekend. Just finished up changing the oil, oil filter, and oil level sender. Still have to pick up some brake cleaner and RTV sealant. When the instructions say to coat the pistons in engine oil, should i buy a quart of bmw engine oil for this?
TR4G- is offline   Reply With Quote
Old 03-22-2012, 09:48 PM   #2096
Stinger9
My Ride: '04 330Ci
When you need to oil up the pistons, you'll do fine with about a thimble full spread around with your finger.
If you have a quart of oil for your next change, just crack the cap on that. Type of oil is not critical here. Just want to avoid assembly dry.
Old 03-22-2012, 11:17 PM   #2097
Rajaie
My Ride: 528i 06/00
That's actually good for breaking in the new seals.
Old 03-23-2012, 12:08 PM   #2098
ExitBuddy
My Ride: 2008 335i Vert
I am going to do the vanos thing as PM as my completely stock '04 just turned 70k. While I am doing this, what else can I/should I do as PM? I suspect at least a new valve cover gasket.
ExitBuddy is offline   Reply With Quote
Old 03-23-2012, 12:38 PM   #2099
Rajaie
My Ride: 528i 06/00
Replace valve cover gaskets and 15 bolt grommets.
Replace sparkplugs. Use NGK Iridium.
Replace belts and tensioners and idler. If hydraulic alt belt tensioner then just replace pulley.
Old 03-23-2012, 12:54 PM   #2100
ExitBuddy
Any of the cooling system bits? Water pump? I'm doing the oil housing gasket, too (leaking).
vanos
Rate This Thread
