Thread Tools Search this Thread Rating: Thread Rating: 132 votes, 4.97 average.
Old 02-14-2008, 01:59 PM   #201
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
i will be ordering soon,
the DIS (GT1) states that all adaptations on the ECU should be reset after a vanos replacement among other repairs it lists.. you guys might want to have your adaptations reset next time your at the dealer or find someone with the capability (im not referring to the throttle adaptaion, the entire ECU adaptaions)
SammyV is offline   Reply With Quote
Old 02-16-2008, 01:15 AM   #202
lca40
My Ride: 2002 325i
rajaie,
i just tried to order a set, already ordered valve cover gasket and it will not let me use my credit card. is there any way that you can take a credit card over the phone or something. I need these asap. I was planning on doing it next weekend.
thanks
lca40 is offline   Reply With Quote
Old 02-16-2008, 01:23 AM   #203
Rajaie
My Ride: 528i 06/00
Originally Posted by lca40 View Post
rajaie,
thanks
You can contact me on the phone number provided at the Beisan website contact page.
Rajaie is offline   Reply With Quote
Old 02-18-2008, 08:48 AM   #204
cwarner
My Ride: 2000 328ci
Well, I have been having the idle issue during warmup in cold weather. I just ordered a set and plan on starting on this in a few weeks. Thanks for all the hard work in sorting out a solution Rajaie!
cwarner is offline   Reply With Quote
Old 02-20-2008, 11:49 AM   #205
Nabil_Leb
My Ride: 328CI 2000
Talking Finally
After a long struggle, Finally with Rajaie's help, I managed to order my vanos seals, can't wait to have them...
(arriving in a couple of weeks ). Will keep posting after installation.
Again Thank you Rajaie for your work.
Nabil_Leb is offline   Reply With Quote
Old 02-20-2008, 12:25 PM   #206
adaseb
My Ride: 2002 BMW 320i
My 2002 320I has about 60K miles on the clock and is there anyway to test if you got a failing VANOS with a step transmission?
Everything seems fine. However about 2-3 times for this cars life whenever I approached a stop it had a jolt of power loss and almost stalled. That happened rarely though and at first though I though it was the transmission.
adaseb is offline   Reply With Quote
Old 02-20-2008, 01:05 PM   #207
Rajaie
My Ride: 528i 06/00
An owner recently noted that after performing the vanos seals repair this symptom went away. He also said it did not happen often. I was not aware of this symptom.
All M52TU/M54/M56 engine cars have this double vanos and have failing vanos seals. The seals are significantly failing in 20k miles. Your's are significantly damaged. Every owner that has replaced their vanos seals has reported significantly damaged seals. The O-rings are made of Buna and this material is completely not compatible with the engine environment.
Old 02-20-2008, 01:26 PM   #208
NicB.
My Ride: 2000 BMW 328i
^^yea that happens to me sometimes. wondered if it might be vanos related.
NicB. is offline   Reply With Quote
Old 02-20-2008, 02:45 PM   #209
adaseb
Do you have a step-transmission?
Old 02-20-2008, 06:07 PM   #210
M3isKing
My Ride: 323i
I have an M52TU with 140,000 on it, and I just started to notice the jolt symptoms. I need to order these SOON
M3isKing is offline   Reply With Quote
Old 02-20-2008, 10:08 PM   #211
NicB.
no i have a manual.
Old 02-21-2008, 05:56 AM   #212
Nabil_Leb
My Ride: 328CI 2000
Adaseb. I have a steptronic transmission. I don't know if your engine falls in the M52TU/M54/M56 series. I only notice the jolts and stalls on cold weather mornings, only if you let the car idle after you start it for more than 2 minutes. When it happened, i disconnected the vanos intake solenoid electrical connector, and the problem stopped right away (Turn off the engine before disconnecting). so try it.
Old 02-21-2008, 09:15 AM   #213
Polish_328Ci
My Ride: M3
Hey guys.. Are these the 15 grommets I need when replacing my Valve cover gasket?
http://www.rmeuropean.com/index.asp?...l=&strCompare=
My dealer has these for $3 a piece so these come to a hell lot cheaper even with international shipping. I have my seals laying around. It's just so cold I won't be attempting this for a while.
Polish_328Ci is offline   Reply With Quote
Old 02-21-2008, 12:34 PM   #214
vaio76109
My Ride: Race Cars
Yes those are them.
vaio76109 is offline   Reply With Quote
Old 02-21-2008, 12:57 PM   #215
ezpunkx
My Ride: '05 330Ci ZHP
Originally Posted by vaio76109 View Post
Yes those are them.
do you definitly need these gromets when replacing the valve cover? i'm planning on replacing my gasket cover but dont have new gromets.
ezpunkx is offline   Reply With Quote
Old 02-21-2008, 01:07 PM   #216
vaio76109
My Ride: Race Cars
No you don't definitely need them, but I'd recommend replacing them.
Old 02-21-2008, 01:28 PM   #217
Polish_328Ci
My Ride: M3
Yes those are them.
Sweet ,thanks
I found everything I need from that site for $54 shipped
Considering my dealership wanted $115 plus 13% tax!!!!
Old 02-21-2008, 01:55 PM   #218
BigO330xi
My Ride: 2004 330xi 6spd
ok im gonna dive into this tomorrow and get these things replaced any helpful hints besides the DIY.... im just worried that i wont get the VANOS on right which can be bad
Sold
SELLING MY MODS!! < click
MODS: AFE Stage II CAI, Ebay Headers, Custom Exhaust, UUC Underdrive Pulleys, BavAuto HP Ignition Coils, NGK Iridium plugs, Homemade Clutch Stop, Euro-Spec Strut Tower Brace, M3 illum. shift knob, LED tail lights, 20% all around tint
BigO330xi is offline   Reply With Quote
Old 02-21-2008, 02:33 PM   #219
Rajaie
My Ride: 528i 06/00
You have nothing to worry about. You can only put the vanos back together correctly. You just can't make any mistakes. No one has yet. Once the vanos is closed up the procedure has you test the piston movements.
Installing the vanos back onto the engine head is also no problem. There are dowels at the top of the head that the vanos fits onto. There is nothing to do wrong, and no one has done anything wrong before.
If you have any questions or issues, call me at the phone number on the Beisan website.
Good luck.
Old 02-21-2008, 03:03 PM   #220
NicB.
Rajaie, I am thinking about doing this. I realize that you wrote no gains were present on the dyno. Any reason why this might be? Is it because once the seals heat up, they start "working" again? Just wish there was some way to know if was worth taking the whole vanos apart.
vanos
Rate This Thread
