Thread Tools Search this Thread Rating: Thread Rating: 132 votes, 4.97 average.
Old 02-21-2008, 04:00 PM   #221
2003330i
My Ride: SC'330izhp,09 335i,
Originally Posted by Titan3er View Post
If you click on his website and go to the vanos forum, you will see that a few people have already done the install.
I will be purchasing a modified vanos (to elinitate zhp vanos rattle) that already has the seal kit installed
from where are you going to be purchasing a modified vanos? what rattle noise are you talking about?
2003330i is offline   Reply With Quote
Old 02-21-2008, 04:07 PM   #222
jsonli
My Ride: 04 330ci TiAg
I have a 04 330ci 6 speed how do I diagnose if I have this problem or not... as I still have warranty.
jsonli is offline   Reply With Quote
Old 02-21-2008, 04:35 PM   #223
Rajaie
My Ride: 528i 06/00
Originally Posted by NicB. View Post
Rajaie, I am thinking about doing this. I realize that you wrote no gains were present on the dyno. Any reason why this might be? Is it because once the seals heat up, they start "working" again? Just wish there was some way to know if was worth taking the whole vanos apart.
I don't know why the significant performance improvements weren't showing up on the dyno. As I noted this is a sore point for me. I spent significant effort and money on this.
The vanos seal O-rings turn into plastic. There is no heating them up to work better.
The vanos seal O-rings are fully damaged in 20k miles. Numerous owners have now performed this repair and they have all noted significantly loose piston seals fit and significantly damaged O-rings. In virtually all cases the O-rings were fully plastic.
The only definitive way to diagnose the vanos is to remove it from the engine and inspect it. There is no reason to attempt a vanos diagnosis. They are all failed. This is a fact.
On the 99-00 M52TU engines with the cold weather cold start idle jolts the intake (or exhaust) vanos solenoid electrical connector can be disconnected. The idle jolts will stop. This is proof it's the failing vanos causing the problem. In every case, replacing the vanos seals solved this problem.
Repairing the vanos repairs the failing variable valve timing system. VVT is a powerful feature and will provide significant performance improvements.
Hope this helps.
Rajaie is offline   Reply With Quote
Old 02-21-2008, 04:37 PM   #224
Rajaie
My Ride: 528i 06/00
E46 ZHP cars have a rattle that comes from the vanos. Dr Vanos (drvanos.com) modifies the vanos to address the rattle. He also installs new Beisan seals.
Old 02-21-2008, 04:39 PM   #225
abeaujuin
My Ride: BMW?
My was plastic too...
When i took mine out they were plastic too. I thought they were supposed to be plastic, until I saw the one I was going to put in was rubber.
abeaujuin is offline   Reply With Quote
Old 02-21-2008, 04:44 PM   #226
Rajaie
My Ride: 528i 06/00
As noted there is no definitive way to diagnose the failing seals without removing the vanos from the engine. The seals are fully failing in 20k miles.
It will be difficult for you to convince BMW to replace your vanos. Even if they do you will get the same Buna O-rings and they will fully fail again in 20k miles.
At 60-80k miles you need to replace your valve cover gaskets. This is a good opportunity to replace the vanos seals as it is only ~1.5 hours labor extra.
Old 02-22-2008, 01:16 AM   #227
FSUmac
My Ride: 2001 330i
Rajaie,
I will be performing this procedure tomorrow night/Saturday. I can't wait to see the results.
FSUmac is offline   Reply With Quote
Old 02-22-2008, 01:18 AM   #228
FSUmac
My Ride: 2001 330i
In the 'parts needed' portion of the DIY, it lists:
If radiator overflow hose clamp original, need replacement small hose clamp.
At what step is this clamp removed and is it 100% necessary to go buy a new clamp? I do not have this clamp in my possession right now so I would have to go back to the dealer. Any idea on the part number? Thanks.
Old 02-22-2008, 07:29 AM   #229
Toxic0n
My Ride: E46 M3 6MT
Once I receive the seals, I'm going to do them and some other maintenence on the car. Does it look about right in this order? Should I seafoam after I do the seals?
Seafoam
VANOS seals
oil change
coolant flush
spark plugs
Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust
2DIN touchscreen carputer, Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK, 2-way Compustar
Clear turn signals, LED license plate lights, LED tails, 3000k HID fogs, angel eyes, matte grills, CF Emblems etc
Toxic0n is offline   Reply With Quote
Old 02-22-2008, 08:26 AM   #230
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
i would do seafoam first and then change all the other things...start fresh after the seafoam
mistrzmiasta is offline   Reply With Quote
Old 02-22-2008, 10:37 AM   #231
NicB.
My Ride: 2000 BMW 328i
Hope this helps.
Thanks for the feedback. I really want to do this. I am a little hesitant just because it seems complicated. But when I think about it, as long as the instructions are there, it's like building a lego set when I was a kid...haha.
My DIY experience: plugs, all my oils, coolant flush, steering coupling fix, fuel filter replacement, Camshaft position sensor replacement, intake disassembly (up to throttle body) and reassembly, taking apart the entire glovebox to replace the final stage resistor, fixing window regulators and vapor barriers, etc. Think I will have any issues tackling this or do you think that level of DIYness will be enough?
NicB. is offline   Reply With Quote
Old 02-22-2008, 10:45 AM   #232
Rajaie
My Ride: 528i 06/00
This clamp is on the E39 and not the E46. I need to clarify this in the procedure. Thanks for pointing it out.
Good luck on the repair and let us know.
Old 02-22-2008, 10:51 AM   #233
Rajaie
My Ride: 528i 06/00
With your experience this repair will be no problem. It looks more complicated than it is. Most owners have noted this.
Old 02-22-2008, 10:59 AM   #234
Rajaie
My Ride: 528i 06/00
Seafoam
VANOS seals
oil change
coolant flush
spark plugs
Do the seafoam first.
The oil next to flush out the seafoam in the oil.
It's best to replace the sparkplugs during the vanos repair. The coils will be removed.
It doesn't mater at what order the coolant is done.
Good luck!
Old 02-22-2008, 02:55 PM   #235
FSUmac
My Ride: 2001 330i
Thanks!
Old 02-22-2008, 10:56 PM   #236
Toxic0n
My Ride: E46 M3 6MT
Good luck!
Old 02-23-2008, 02:23 AM   #237
2003330i
are you talking about the rattle noise under heavy acceleration?
Old 02-23-2008, 11:51 PM   #238
Rajaie
My Ride: 528i 06/00
As far as I know it doesn't need to be under heavy load. The rattle usually occurs around 2k RPM.
Old 02-24-2008, 12:32 AM   #239
2003330i
if i dont have any of these codes coming up, should i do this? i have about
80k miles on a zhp. is the install done the same way if you were supercharged?
P1520 (BMW 104, 0x68): B (exhaust) Camshaft Position Actuator (faulty reference value).
P1523 (BMW 106, 0x6A): B (exhaust) Camshaft Position Actuator Tight or Jammed (mechanically stuck).
P1397 (BMW 18, 0x12): Camshaft Position Sensor B (exhaust) Circuit.
The Camshaft Position Sensor (CPS) is a common failure. But if replacing the exhaust CPS (w/ OEM CPS) doesnít work then itís likely the vanos failure.
i have about 80k miles on a zhp. is the install done the same way if you were supercharged? i do here something like its rattleling but it sound like its from my intake manifold but i could be wrong.
Old 02-24-2008, 12:50 AM   #240
Rajaie
My Ride: 528i 06/00
The vanos seals are significantly failing in 20k miles. Replacing them will provide significant performance improvements. Your seals are badly damaged.
Only a few owners end up experiencing the listed codes.
The install should be the same regardless of the mods.
vanos
Rate This Thread
