Rating:
#61 | |
Fuel injector cleaner has been known to temporarily solve the idle problems. Buna O-rings are susceptible to many harsh chemicals. These chemicals will cause the O-rings to swell. This swelling will initially act beneficially. The vanos Buna O-rings have significant compression set, flat top and bottom surfaces, and shrinkage. The swelling will increase their size and cause them to provide better support and seal to the Teflon seals. But this is all temporary. The presence of the fuel injector cleaner will diminish, and the O-rings will lose their swell. The injector cleaner will have acted determinately on the O-rings. It will have dissolved from them the components that give them their elasticity. Thus although there is temporary improvement, the end result will be the hastening of the O-ring demise. The DME utilizes the vanos to help heat up the cats faster on cold engine starts. It is at this time that the idle problems occur due to the failing vanos. The DME does not perform this vanos maneuver immediately at startup. It waits until the engine warms sufficiently to handle the vanos (timing) maneuvers. Thus the colder the temperature, the colder the engine, and the longer the engine needs to warm up before the DME performs the vanos maneuvers. It might be that you are not waiting long enough to allow the engine to warm up to the point where the vanos is used to heat up the cats. When the car is driven the idle problems don’t occur, unless the car soon comes to a stop and idles again. |
#62 |
Anyone from this site installed this yet on their E46?
- Bruce
#63 |
Car is in the shop for a few different things as we speak... the new and improved rattle-proof VANOS with the new Viton seals from Dr. Vanos is on the list. I should have some first impressions later today, and I'll be posting updates in this thread as I go through the break-in period for the seals.
#64 |
#65 |
Watching this topic for feedback, will have to do this after I'm done with my diff bushings
![]() Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust 2DIN touchscreen carputer, Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK, 2-way Compustar Clear turn signals, LED license plate lights, LED tails, 3000k HID fogs, angel eyes, matte grills, CF Emblems etc |
#66 | |
Regional Sponsor
My Ride: 2000 E46 with 254K
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. |
#67 |
Rajaie, the check engine light is not on. i was going to get the engine code read but then i though to myself, if the check engine light is not on then is there a code? Since its not really cold here in miami, i have no had the car stall, just last night that it was 59 degrees. the RMPs usually dont bounce around as much but the car does shake a lot when i turn the steering wheel in reverse only especially towards the maximum "turnage" of the steering wheel. also it almost always vibrates when the car is in drive, warm or cold and i am stopped. as soon as i accelerate it goes away. i have no idea what it could be. there are so many things it could be and most of them are only guesses. I know im probably no the only one but i cant find a definitive answer as to what it could be.
![]() Pictures by boligrafo123 & ///OSS |
#68 |
Gaby
you're problem doesn't sound like vanos to me if you're experiencing bogging when turning the wheel at a stand still or low speeds i would check to see what color your steering fluid is (atf). it may be brown or smell slightly burnt. i would flush that first to see if it helps, but it sounds like your steering pump is starting to go. but i suppose a failing or worn steering rack may load the pump and cause the same symptoms. |
#69 |
roy, thanks how about the problem when im stopped in drive and the car vibrates, it happens at all temperatures. the steering problem agitates the rpms more, when im stopped at a light or something in drive the car vibrates and sometimes the rpms fluctuate. could it be the vanos?
steering wheel doesnt feel sluggish, it just makes the rpms fluctuate.
#70 |
Well, my first impression of new VANOS from Dr. Vanos with the improved Viton seals is that the car definitely feels a bit zippier than before, even though I'm nowhere near the 500 miles of city driving needed to break the seals in. Acceleration is definitely much smoother throughout the rpm range and the idling problems are of course gone. Seems like money well spent so far.
#71 |
^ Where did you have it installed and how much did it cost ya?
- Bruce
#72 |
Banned
Now I need to find a really good installer/mechanic who knows how and what he's doing in the New York and New Jersey area
#73 |
I got quoted $450 for the Dr. Vanos install. Does that sound right to you guys?
- Bruce
#74 |
I had it done at a local independent shop... was 4.6 hours of labor, presumably because the guy also did the timing adjustments which apparently aren't actually necessary. The car seems a little bit faster every time I drive it, dunno if that's because of the seals wearing in more or if it's all in my head but I like it.
Edit: $450 is about right. The guy I went to charged me $414... he usually knocks his labor rate down a bit but I guess he charged me damn near his usual rate, probably because I was supplying the parts myself. Really makes me wish I had the tools to do all of this stuff myself. Might have to invest in some the next time I need something done. Last edited by TX; 12-18-2007 at 10:06 PM. |
#75 |
^ Looks like I might do this then. So no more rattle/shake/rpm dip?
- Bruce
#76 |
Correct, though my VANOS never rattled in the first place. As far as I know, the rattle only occurs due to the more aggressive cams which come with the ZHP package. The extra machining cited on the Dr. Vanos site is supposed to prevent it from ever developing such a rattle in the case that I end up with higher profile cams in the future, though.
#77 |
please answer this! lol : So no more rattle/shake/rpm dip?[/QUOTE]
#78 |
mine rattles, i have no idea what it could be but i guess its this, or the MAF sensor or the idle control valve, the rattle disappears when i accelerate, could it be the seals then? the car doesnt really feel sluggish, its a 2001 sports 330ci and it rattles, so its not just the zhp
#79 |
After 7 years, your VANOS seals are more than likely shot. Replace it if you can afford it.
#80 |
i can, but would it fix the vibration i have during idle and ONLY in drive or reverse at a stop, not when im rolling.
| Tags |
| vanos |
| Rate This Thread | |
