Old 05-27-2008, 08:32 AM   #301
fmzip
My Ride: '08 328xi / '01 530i
Originally Posted by elite53 View Post
There were two new sounds with mine also. One of them is if I accidently slip the clutch by babying it too much when I let out the clutch. It is a bit of a screech. Sort of like a set of racing brake pads on a rotor. I think this is from the new kevlar material that the clutch is made out of and the fact that it doesn't like to slip. I don't worry about it much, it just reminds me to start shifting right.
The other one is a rumble sound from the driveline when I'm lugging it in 3rd or 4th gear and try to accelerate from around 2500rpm like you stated. I think it is just from the springs in the sprung hub trying to compress as the engine pulses and tranfering the vibration to the driveline. I don't worry about this one much either and it has actually gotten better over time.
I would recommend just driving the car and not overthinking things. The clutch chatter/shutter on takeoff and the rest of the things will get better. It just takes a while. Sometimes a long while but they will get better and soon you will love it. I had all these same worries when I first installed mine and it all turned out to be nothing more than normal break-in procedure.
That makes me feel a little better.....
Back to the "noise" at 2500 RPM's, it sounds exhaust related to me. I opened the door while driving today and it seems to be coming from the muffler area. As I said, it is random and only upon load.
That little butterfly in the muffler is rattling like an SOB on idle. Maybe my muffler is on it's way out???
fmzip is offline   Reply With Quote
Old 05-27-2008, 09:23 AM   #302
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
mine rattles against the rear diffuser at times
/_________\
O==[][]==O
Old 05-27-2008, 09:12 PM   #303
330i ZHP
330i ZHP's Avatar
interesting thing to note for those of you with hopes of your engine lasting forever....the retaining nut on the oil pump was loose when I went to take the oil pump off the motor...I will definetely be welding the nut onto the shaft/gear
/_________\
O==[][]==O
Old 05-29-2008, 10:35 AM   #304
fmzip
just curious Brian..... I don't believe I have a clutch delay valve in my car, do you still have one in yours or did you remove it?
Next time I have the car up in the air, I will check to see if one is there or not. Could be a reason I feel the shudder??
http://www.zeckhausen.com/CDV.htm
Old 05-29-2008, 12:48 PM   #305
330i ZHP
330i ZHP's Avatar
i removed mine (actually I have the Zeckhausen thing) but I now have two modified CDV's that I have made myself if anyone wants to buy one
/_________\
O==[][]==O
Old 05-29-2008, 01:00 PM   #306
fmzip
I was curious if Brian removed his. If he didn't, maybe that is why he isn't expiernecing any shudder in first gear.
Might take you up on the offer to buy one if I find one in there!
Old 05-29-2008, 01:05 PM   #307
HighBoostin330
My Ride: 2002 Stock 330Ci
I have no CDV as when I did the manual conversion, I felt it was a useless part to install.
HighBoostin330 is offline   Reply With Quote
Old 05-29-2008, 01:08 PM   #308
330i ZHP
330i ZHP's Avatar
unless your car is under warranty dont bother to install a modified CDV - just remove it and move on in life
/_________\
O==[][]==O
Old 05-29-2008, 01:16 PM   #309
HighBoostin330
with Stu.
Old 06-01-2008, 09:59 PM   #310
fmzip
I just ordered this, maybe this will resolve the odd vibration problem....I ordered the black one with the enforcer cup
Old 06-01-2008, 10:03 PM   #311
TxZHP04
My Ride: ESS TS2+ ZHP
Good choice, although you had me worried there for a second with that picture - you definitely don't want the red with the TME on a street car.
Also, don't overlook your engine mounts. I'm thinking I may be replacing my engine mounts in the near future.
Old 06-01-2008, 10:10 PM   #312
330i ZHP
330i ZHP's Avatar
trans mount?
/_________\
O==[][]==O
Old 06-02-2008, 01:01 AM   #313
AntB
My Ride: MTA :(
Excellent choice, I have the black ones with the enforcers and they are awesome. Stock-like feel, without the tranny moving around like it used to.
** Tim330i waz hur **
AntB is offline   Reply With Quote
Old 06-02-2008, 05:50 AM   #314
330i ZHP
330i ZHP's Avatar
do any of these trans and engine mounts transmit the vibrations into the interior? Which ones do most folks get?
/_________\
O==[][]==O
Old 06-02-2008, 07:29 AM   #315
TxZHP04
I have the UUC black mounts with the enforcer cups. Highly recommend these. No additional noise or vibration into the cabin.
I have also experimented with the red street mounts (not the red bolt through race mounts), both with and without the TME cups. Trust me, you don't want the red mounts with the TME cups as pictured above on a street car. The red street mounts alone, which are plenty stiff to not need the TME, are actually not too bad in the way of NVH. I had them on my car for a while when it was stock and it almost sounded like an exhaust upgrade inside the car. The downside was the cabin was just a bit too buzzy for me at parking lot speeds and at high rpm. I actually really liked the exhaust like growl introduced by the red mounts but eventually grew tired of the vibration, especially at the high rpm. Interestingly, I rode in AdamBath's car a while back and his red mounts were much quieter than mine. He said they were noisy like mine until he installed his headers. Go figure.
I think new engine mounts are in my future but I have no idea what I will do for this. It looks like the M3 uses a different (presumably stiffer) but compatible mount. I may pursue this.
Old 06-02-2008, 01:16 PM   #316
AntB
My Ride: MTA :(
http://store.nexternal.com/shared/St...22&CS=uuc&All=
These are the ones you want from the UUC store. It's the ones that I have, no vibration in the interior, one thing you will notice is slight vibration in the gear lever.
Old 06-02-2008, 08:57 PM   #317
fmzip
Yep, I went wih the black ones and enforcer cups also. I also read that tightening them to the recommending 16ft lbs and no tighter is vital to avoid added vibration into the cabin
Interesting on the "cause and effect" described with the headers. I defintely think their is a certain frequency present now that the dual mass flywheel has been removed.
I also think my muffler is shot, seems awfully loud and that little butterfly flap rattles like there is no tomorrow.
Fortuantely, I picked up a ZHP muffler today from another fanatic. Has just 4000 miles on it, looking forward to having it installed!
That link to the engine mounts isn't working for me..
Old 06-03-2008, 07:39 PM   #318
fmzip
Got the mounts, they surely are beefier! Installed them, still have the shudder and the odd noise. Shifts are much tighter, car feels more solid.
Old 06-03-2008, 08:23 PM   #319
AntB
My Ride: MTA :(
Glad you like em!
Old 06-05-2008, 09:46 AM   #320
Lemonsqr
My Ride: 2001 TiAg 330i
How hard are these to install? Is there a link to a DIY....too lazy to search this time
Lemonsqr is offline   Reply With Quote
