Old 04-15-2008, 09:30 PM   #101
fmzip
My Ride: '08 328xi / '01 530i
Replaced the ICV, thermostat housing, and water pump tonight.
Interesting comparison of the water pumps, the old one is on the left.......the internals look like something I made in shop class!
Super easy DIY....gotta love the O-rings, it makes life very easy!
fmzip is offline   Reply With Quote
Old 04-15-2008, 09:37 PM   #102
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
Originally Posted by fmzip View Post
Congrats Stuart!! Is the TS3 going to be a DIY??
yes - hopefully it wont take too long
what brand is the new pump?
/_________\
O==[][]==O
Old 04-16-2008, 12:09 AM   #103
fmzip
Stuart.....the Brand is GEBA, Made in Germany, bought it from Bavarian Autosport under the BMW part number.
Thinking ahead, I need to tap in for a boost gauge. The labels on the intake for the vacuum lines say "orig fuel pump reg" and on the other it is "T"'d and is labeled "EGR and exhuast flap". I have something to plug into each of those connections already.
Can I just add another "T" on the one that says "fuel pressure regulator" and pick up vaccum for the boost gauge there?
Old 04-16-2008, 05:21 PM   #104
fmzip
HELP!!!
I am stuck....I have too many vaccum lines and not enough connections.
The first pic I circled a hose which leads up around back of the firewall and used to plug into my intake. Where it is to connect to now, I do not know. The second picture, I believe is the EGR valve as pictured in the ESS install manual. This connects to the TS2. The third pic is for the fuel pressure regulator which is clearly labeled on the TS2. The four pic is for the exhaust flap which is clearly labeled on the TS2. I also need to hook up a boost gauge.
So I have 5 vaccum lines with only three connections....HELP!!! I am stuck.
Old 04-16-2008, 05:45 PM   #105
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
For the gauge, you'll just have to T into something. Probably the FPR, but don't quote me on that. I've only worked on turbo'd cars, not S/Cd.
As for the first picture, if it just went into the intake, it can PROBABLY just T in somewhere as well.
Old 04-16-2008, 09:58 PM   #106
fmzip
Gotta love this forum! DKE46T "Dave" saw I was in need of some help. He stopped over and we managed to get it in!
Thanks again Dave! It's looking good! It amazes me how this thing "just" fits in there!
Thanks Stuart for pointing out to make certain to connect that lower hose "first" before you actually seat the manifold! It's real tight back there!
Old 04-16-2008, 10:02 PM   #107
330i ZHP
330i ZHP's Avatar
moving right along - did you figure out the vacuum lines? I dont remember touching any lines on the exhaust side of the motor
/_________\
O==[][]==O
Old 04-16-2008, 10:17 PM   #108
fmzip
Stuart, that picture of the unit on the exhaust side was to show where the vaccum line begins. It connected to the bottom side of the OEM intake.
Dave and I went to Autozone and picked up some vaccum fittings. They obviously need to connect somewhere, we're assuming the vacuum fitting on the TS2 labeled "EGR and exhaust flap", leaving the vaccum line for the fuel pressure regulator independant of everything.
Hopefully ESS can chime in for a defintive answer
Old 04-16-2008, 10:19 PM   #109
dke46T
My Ride: 330CI
Thanks Fran i'm glad to be a part of this, the unit fits nice and snugg as it should. A few more little things and your ready to go..... Dont forget about the silicone coupler ill have to stop by and grab that so I can fab up what we talked about.
Talk to you soon.
Dave
dke46T is offline   Reply With Quote
Old 04-16-2008, 10:28 PM   #110
fmzip
Dave and I were trying to brain storm on a way to dress up/replace the silcone sleeve. It's an eyesore!
Old 04-16-2008, 10:43 PM   #111
dke46T
My Ride: 330CI
Dont worry we will def get that taken care of. I think I have all the material for it if not ill order some up tommorrow. I think the sleeve will match nicely with the lip of the SSR GT3's after a little polishing.
Old 04-16-2008, 10:56 PM   #112
fmzip
A polished sleeve would be awesome if you can pull it off....
Old 04-16-2008, 11:01 PM   #113
dke46T
My Ride: 330CI
Ohh oh is this a challenge ??? Hmmmm... I know I have some heavy duty aluminum foil somewhere. LOL ... Dont worry its all Under Control.
Old 04-16-2008, 11:14 PM   #114
fmzip
Aluminum foil may look better than that silicone sleeve!! I'll take it!
Old 04-16-2008, 11:20 PM   #115
dke46T
My Ride: 330CI
Give me a call tom sometime... Hope to hear from you soon.
Old 04-16-2008, 11:22 PM   #116
elite53
My Ride: Twin Screwed 325Ci
The vacuum line in picture #1 connects to the electric valve in picture #2. I think its called the Exhaust Gas Recirculation valve.
The black and white checkvalve in picture #2 connects to the lower vacuum line coming off the back of the intake manifold. The one with the T-fitting in it. One side of the T-fitting is for the check valve and the other is for your exhaust flap valve shown in picture #4
The hose in picture #3 goes to the upper vacuum hose on the intake manifold marked Original Fuel Pressure Regulator.
elite53 is offline   Reply With Quote
Old 04-16-2008, 11:26 PM   #117
dke46T
My Ride: 330CI
There you go Fran just like we had stated about the vacum lines.... Thanks for the help elite53....
Old 04-17-2008, 10:38 AM   #118
330i ZHP
330i ZHP's Avatar
you go elite53 - i remember now that i had to block off the flapper valve thing - since i didnt have one
/_________\
O==[][]==O
Old 04-18-2008, 11:51 AM   #119
dke46T
My Ride: 330CI
Hope all is well Fran lets get this thing finished up you know you would have rather had the top down driving to work today ??? Its like 80 Deg outside and not a cloud in the sky......
Dave
Old 04-18-2008, 04:20 PM   #120
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
Also, I believe the black "tank" is your charcoal filter and should be connected to the fuel vent purge valve which then connects the vacuum side of the TS on the bottom of the intake elbow so it sees vacuum.
MarvelPhx is offline   Reply With Quote
