Old 04-21-2008, 08:33 PM   #141
HighBoostin330
My Ride: 2002 Stock 330Ci
Originally Posted by fmzip View Post
I sent you his email via PM.... thanks for the photo, I am headed to the garage to rip that hole!
I was contemplating the BMW Performance Intake myself, it is too much money.....
Great minds think alike.
HighBoostin330 is offline   Reply With Quote
Old 04-21-2008, 08:40 PM   #142
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
I didnt have to remove that panel (didnt even know it could come out)
/_________\
O==[][]==O
Old 04-21-2008, 09:35 PM   #143
fmzip
My Ride: '08 328xi / '01 530i
Something doesn't look right....looks like the intercooler needs to go up a few inches since this shroud doesn't reach it's mounting point.
fmzip is offline   Reply With Quote
Old 04-21-2008, 09:48 PM   #144
TxZHP04
My Ride: ESS TS2+ ZHP
I think most of us just ditch the shroud. I think Todd cut his to fit, you might check his DIY. I didn't reinstall mine... maybe if I'm feeling ambitious one weekend and have nothing else to do.
Old 04-22-2008, 03:47 AM   #145
HighBoostin330
I just wanted to update you about AJ notifying me of a European Air Filter for our cars which does not have the foam piece on the paper intake filter. The below picture shows the new air filter without the foam on the left and the old air filter with the foam removed with leftover adhesive foam residue. The second picture is of the box the new paper intake filter came in. I used a Mahle LX343 filter. I hope this helps.
Old 04-22-2008, 08:15 AM   #146
fmzip
Thanks for the heads up.....but what does this mean to me?
I think I just put a Mann filter in if I am not mistaken; I swear it looks like the one on the left.......
Old 04-22-2008, 08:21 AM   #147
fmzip
I noticed in the ESS instructions they have theirs reinstalled but make no mention of how they did it.....Thanks for the heads up on Todd's site, looks like he cut the lower half off.
Old 04-22-2008, 09:10 AM   #148
330i ZHP
330i ZHP's Avatar
I had to dremel mine to fit - you will have to cut a notch in the lower shroud to make it fit properly - I also cut small notches for the hoses to pass through
/_________\
O==[][]==O
Old 04-22-2008, 10:45 AM   #149
fmzip
Just curious, did everyone use "distilled" water to mix 50/50 with the coolant as per the instructions for the intercooler? What's the reasoning behind this?
Old 04-22-2008, 11:22 AM   #150
TxZHP04
Same reason you do this with your radiator - tap water contains impurities that can be harmful to your cooling system. And yes, I always mix with distilled water.
Old 04-22-2008, 11:30 AM   #151
330i ZHP
330i ZHP's Avatar
+1
/_________\
O==[][]==O
Old 04-22-2008, 12:03 PM   #152
fmzip
As you can see, I haven't been under the hood in 20 years, used to use a garden hose and Prestone II in the old'n day!
They carry distilled water at the grocery store, right??
Old 04-22-2008, 12:46 PM   #153
330i ZHP
330i ZHP's Avatar
yes
/_________\
O==[][]==O
Old 04-22-2008, 08:09 PM   #154
fmzip
Well, I modified the shroud, more work than it's worth I think....
Old 04-22-2008, 08:11 PM   #155
fmzip
Installed a new fuel filter too.....
It's starting to look like it's ready to run!
Old 04-23-2008, 06:20 PM   #156
Minnoe07
My Ride: 2004 BMW 330Ci
Yea, I definitely just ditched the shroud. It definitely didn't seem functional enough for me to spend the time to dremel it to keep.
Install is looking good.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 04-23-2008, 06:57 PM   #157
fmzip
Thanks.....
Got the gauges installed today, UPS delivered the Redline power steering fluid and oil filter.....might be able to start it up tomorrow!
Old 04-23-2008, 08:56 PM   #158
330i ZHP
330i ZHP's Avatar
lookin good
/_________\
O==[][]==O
Old 04-24-2008, 09:24 AM   #159
fmzip
YES!!!!!!! Started her up....purrs like a kitten!!
Couple minor issues, the low oil light stays on, (just did an oil change 7 qts oil Mobil1 0w40) the vdo oil pressure gauge is pinned, boost gauge blips slightly revving it up (is this normal on boost or is mine line kinked?)
Not really sure where I went wrong.....the VDO dual sending unit, does it matter which terminal is used for the factory connection and the oil pressure gauge??? That is the only thing I can think of......
Never the less, I can't wait til tonight to take it for a spin!!
Old 04-24-2008, 09:48 AM   #160
330i ZHP
330i ZHP's Avatar
sounds like you have a ground issue for one...that would explain the oil light and gauge issues.
and if you rev it enough at idle the boost will start to build
/_________\
O==[][]==O
