Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Melted Clear Corners (DEPO) and Michiba Silver coated 12V 21W bulbs
Well it seems my DEPO clear corners have melted from the chrome bulbs. In searching these forums I have found that a number of Silver colored bulbs (including Solaris) cause melting in OEM clear corners and DEPOs.
See here for that thread: http://forum.e46fanatics.com/showthr...melted+corners In case anyone is wondering, I purchased the kit from ebay seller http://stores.ebay.com/fishcake321 Ebay auction (enter this in the search query) : BMW E46 4D CLEAR CORNERS SIDE MARKER 4 CHROME BULBS Interesting fact : these silver colour bulbs are rated at 21W, just like the OEMs ![]() I am curious because the corners are always on when I start the car due to the DLRs (no I do not wish to defeat the DLRs feature as it is illegal in Canada ) This is normal right? Sponsors, what's my best bet at this point? I've seen the LED corners but they look kinda weird... no? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Yanni
3M or Avery Tape? http://forum.e46fanatics.com/showthread.php?t=518716 Angel Eyes Wiring Harness questions/aftermarket etc http://forum.e46fanatics.com/showthr...94#post6941294 See my M E L T E D DEPOS !!!! http://forum.e46fanatics.com/showthread.php?t=525961 Last edited by thefys; 11-29-2007 at 11:10 PM. |
#2 |
What brand of bulb did you get from the ebay seller?
Sorry, didn't read the title. I just got a set of those brands and thinking about replacing it. Better not? Last edited by t_amo_bimmer; 11-29-2007 at 11:57 PM. |
#3 |
1.888.JLEVISW
Yikes! I've only seen that happen with the cheaper brand bulbs that overheat and cause melting problems. I'd recommend you either go with our LED based bulbs or one of our mirror coated bulbs like you had before. Here are a few options for you:
LED Front Turn Signals Umnitza Predator Titanium Bulbs Stealth Mirror Coated Bulbs Bimmian Solaris Invisibulbs |
#4 | |
Yanni
3M or Avery Tape? http://forum.e46fanatics.com/showthread.php?t=518716 Angel Eyes Wiring Harness questions/aftermarket etc http://forum.e46fanatics.com/showthr...94#post6941294 See my M E L T E D DEPOS !!!! http://forum.e46fanatics.com/showthread.php?t=525961 |
#5 | |
The Solaris are documented on these very forums to melt DEPOs and OEM Clear Corners. I'm very leary to buy chrome colored bulbs again. BTW, what's the warranty of any of these clears ? Can you post a picture of the LEDs [off, not flashing] inside the Clear Corner housing ? Thanks In advance !
Yanni
#6 |
To the OP, did it happen to your side marker too? or only to your front corner?
#7 |
Side markers are fine.
Yanni
#8 |
1.888.JLEVISW
The issue seems to stem from the bulb so I'm not sure if you can claim warranty with DEPO on the corners themselves.
Come to think of it, I don't think I have a picture of our LEDs off inside the housing. You can't really see them so I have never thought to take a picture. I will try to get one for you |
#9 |
I purchased my DEPO clear corner lenses from European Auto Source and got their Invisilite stealth bulbs. Mine melted exactly as thefys said. This thread is from 2007 and its been 2 years and the issue is still occuring. sucks that they haven't corrected this. I even treid going with the Solaris bulbs and they melted the housing interior as well.
#10 |
then buy leds
Jet Black 2003 325i
#11 |
I wish I had searched for this problem before buying my Depo clear corners and mirror bulbs. I am having the exact same problem. I initially bought mirror bulbs with my Depos, and the right front burned out after two months. I then replaced them with Solaris Invisibulb Ultrabright Editions, and after one week, the right front burned out again. When I pulled it out, I found that the plastic around the bulb had melted and fused onto the glass part of the bulb. The inside reflective part of the housing is rippled and melted. I checked the other side and found the same thing with the reflector. The LED solution seems like too much work and more money, so I guess I'll just replace the bulbs with ambers.
#12 |
I just had this happen to BOTH of my corners. I purchased new ones from JLeviSW and solaris bulbs. I thought it was an issue with the oem socket. Now I'm a little pissed that there has been no warning posted on JLeviSW website that this may occur! Regardless if it's the bulbs or the corner, it is a known fact. Any idea of how to fix this??? Is there another bulb I can purchase after returning my Solaris bulbs? JLeviSW, any ideas?
#13 |
Past Site Sponsor
If you want silver bulbs I would suggest sticking with OEM or convert to LED. You can get them from TischerBMW:
http://forum.e46fanatics.com/showthread.php?t=610587 |
#14 |
it doesn't matter that the bulb is rated the same. the mirror coating that they use is what's causing the corners to melt. it tends to hold in heat more than a regular bulb. i'd rather use LEDs than those bulbs. the OEM ones would be just as good because they have a thinner coating (hence why you can kind of see through the bulb)
Have a lighting problem? Read this first: Lighting-related Troubleshooting Guide |
#15 |
I now use standard clear BMW bulbs (non mirror coated, or amber bulbs) It's just not worth the hassle...
Sounds like we ALL got screwed on this one.
Yanni
3M or Avery Tape? http://forum.e46fanatics.com/showthread.php?t=518716 Angel Eyes Wiring Harness questions/aftermarket etc http://forum.e46fanatics.com/showthr...94#post6941294 See my M E L T E D DEPOS !!!! http://forum.e46fanatics.com/showthread.php?t=525961 Last edited by thefys; 05-20-2010 at 02:15 AM. |
#16 |
i have two sets of clear depos that melted by this solaris bulbs, what a waste!
Mods: Vmr VB3 staggered wheels, H&R sport cup kit, P46 with Orion V2 with Canbus xenon, Magnaflow exhaust, Aluminum pedals. Roque RSM, Interior xenon lights, Oem alarms, M3 steering wheel, carbon fiber wrap interior, K&N intake, Mtec II bumper, Kenwood with Pandora and 2x12's sub and amp, RCR tails, OEM clear sides and front, black kidneys and roof spoiler.Last edited by pinoybmr3; 05-20-2010 at 11:25 AM. |
#17 |
yep happened to me too. and even the OEM ones start to bubble after awhile.
#18 | |
1.888.JLEVISW
We did just release the Version 3 LED Turn Signal Bulbs which are very efficient and do not emit any heat. ![]() |
#19 |
I hate those resistors or else i would get LED's
#20 |
So i checked my Depos and sure enough they are starting to melt too, After only 20 days of use, Purchased from Khoalty.
