Old 12-03-2007, 06:41 PM   #1
Ratty
My Ride: Alpine E46
Where Should the Temperature Gauge be at?
It seems like the temperature gauge on my car is a lil pass the halfway mark. To me I think that doesn't look right. My engine is running too hot. What could be the problem? The coolant or water pump?
Ratty is offline   Reply With Quote
Old 12-03-2007, 06:45 PM   #2
Ervin87
My Ride: E92 M3 | S4 | E30
Send a message via AIM to Ervin87
It should always be @ 1/2 way.
EUROPROJEKTZ - NorCal Chapter
Ervin (Bay Area Detailer)
Ervin87 is offline   Reply With Quote
Old 12-03-2007, 06:52 PM   #3
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
yeah, if it's going over half, then you're overheating. We have buffered gauges that wont change at all until something's absolutely going wrong, or after something's gone wrong, usually. When the pump went out on me, the pulley got really cocked and made loud noises, it probably doesn't have to do that to go out though. The thermostat could be stuck. Or you might have a leak out of the plastic-housed thermostat or the often replaced expansion tank. Mine blew up though, i'm not sure how common it is to have a slow leak from it.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 12-03-2007, 07:46 PM   #4
MJRMatt330
My Ride: 2002 330Ci
Send a message via AIM to MJRMatt330
my temp guage sometimes randomly goes up and down from normal half way back down to like 1/2 of the normal... even when my car seems to be heated up. its really weird. Not to thread jack but does anyone know what this is?
MJRMatt330 is offline   Reply With Quote
Old 12-03-2007, 07:49 PM   #5
Ratty
My Ride: Alpine E46
I changed the thermostat recently and expansion tank b/c it had a crack in it. The gauge is only a little bit past halfway, not much at all. Not sure if that means anything. Also, the tech that changed my expasion tank put in reg coolant instead of BMW coolant. Would that cause the problem?
Old 12-03-2007, 08:00 PM   #6
zeshon
My Ride: S/C 2000 328Ci
No, same thing happened when I put a new thermostat in, and I use OEM coolant. I figured it had something to do with a change in the position of the metal on the sensor.
- Austin
Favorite sponsors
Bavarian Soundwerks | Euro Spec
Mods : Performance : Active Autowerkes Stage 1 C38 New Subframe and TMS Rear Re-Enforcements Upgraded VANOS seals M3 Fuel Baffle KW V2 ZHP Control Arms E60 Short Shifter Sound : Bavarian Soundwereks Stage 2 DICE iPod Link Looks : Replica M3 Mirrors Replica M3 Front Bumper Matte Black Grillz LED Signals
zeshon is offline   Reply With Quote
Old 12-03-2007, 11:26 PM   #7
Ratty
My Ride: Alpine E46
So I have nothing to worry bout? Ur car hasn't had any problems?
Old 12-04-2007, 01:11 AM   #8
jmctype4
My Ride: 330i TiAg ZHP
This may be somewhat relevant to the topic at hand:
http://forum.e90fanatics.com/e90-e91...html#post23519
If what this tierfreund1 is saying is correct, then it really doesn't matter where the needle is pointing as long as it's somewhere near the middle (unless it bothers you aesthetically).
M.
If you didn't earn it, you don't own it.
jmctype4 is offline   Reply With Quote
Old 12-04-2007, 01:49 AM   #9
silentak1
Banned
My Ride: '03 330ci cabrio
Yesterday I changed the both upper and lower radiator hoses, thermostat, expansion tank, and poured new BMW coolant. The temp gauge used to read at exactly 12 o'clock, now it's about 1mm to the right of 12 o'clock (I suppose more like 12:30 now). I've read many posts and find that this is normal and that the needle may not indicate the exact temperature after replacement. For example (and I have NO idea what temperature is normal), the middle might have been 100 degrees before at 12 o'clock and now that it's at around 12:30 it might actually be still 100 degrees. I wouldn't worry about it, just make sure that you bled air out of the system.
silentak1 is offline   Reply With Quote
Old 12-04-2007, 05:46 PM   #10
Ratty
My Ride: Alpine E46
Thanks for the info. U save me $$$ b/c I didn't want to have the dealership take a look.
