Old 12-05-2007, 08:46 AM   #1
fly325
My Ride: bugmobeel
Send a message via AIM to fly325
mtech front bumper install to 04' coupe
i am installing a mtech front bumper to my 04' coupe and encountered some problems.
when screwing in the two 4" bolts that attach the aluminum carrier to the car are there suppose to be access holes near the top of the mesh grill to screw in these bolts? my stock bumper had these access holes but my oem euro spec mtech bumper only has four small rectangles and none line up with the bolt holes.
fly325 is offline   Reply With Quote
Old 12-05-2007, 10:18 AM   #2
325myAZ
My Ride: 2001 325i
My OEM (non-eurospec) mtech bumper had the holes.
I have no idea why they'd be missing on your bumper... wierd. Is this bumper intended to have the carrier mounted first and then the cover clipped on afterwards?
325myAZ is offline   Reply With Quote
Old 12-05-2007, 05:29 PM   #3
mechanicalmadness
My Ride: e46 323CI
Could it be because It's Euro spec? Just a shot in the dark.
mechanicalmadness is offline   Reply With Quote
Old 12-05-2007, 05:32 PM   #4
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
possibly just another aftermarket setback... u have to keep in mind that with non-oem products, regardless of where you get them, quality will just not be all there...
Timeless Motor Group
Old 12-05-2007, 09:16 PM   #5
fly325
My Ride: bugmobeel
its odd that theres no hole in the same location. its an oem euro spec bumper. i see holes on the bottom on where the cs splitters would attach. i will need a long extension for my ratchet if i make a hole through my arqray. although i might be able to slide my hand through the brake duct opening and install the brake duct from the wheel well
Old 12-05-2007, 09:38 PM   #6
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
those are the holes that you need to use... i don't understand what you're questioning. no mtech bumpers have the holes up by the grill.
hi its me alec is offline   Reply With Quote
Old 12-05-2007, 11:50 PM   #7
325myAZ
My Ride: 2001 325i
Damn!
Good catch Alec! The access holes are down below the grill...
Old 12-06-2007, 12:28 AM   #8
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Yeah, there should be two giant holes in the bottom of the bumper. You'll need a 10" socket extension. These are a true pain in the ass to screw in too. Make sure to get your car as high off the ground as you can to make it easier. And I take it you mean OEM Euro Mtech bumper, not a bumper from the company Euro Spec?
-Gary
DiscoStu is offline   Reply With Quote
