General Off-Topic
Old 12-10-2007, 11:57 AM   #1
inzideurhead
My Ride: ///M3
Send a message via Yahoo to inzideurhead
Probability of winning Lotto using same numbers over n over n over... BS
Just had a discussion with some co=-workers. They believe that if you play the same numbers for a long time (talking about 10-30 years) you have a better probability of winning.
My thoughts are that ...choosing the same numbers over and over will not improve your odds of winning , however, picking a set of completely random numbers every time you play does IMPROVE your odds of winning.
My backup for this is the center limit theorem and randomization method (says as you increase randomization you reduce error).
Can someone tell me if I am making sense... at least more so than my coworkers!!
inzideurhead is offline   Reply With Quote
Old 12-10-2007, 11:59 AM   #2
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
yeah, but the lotto in NY its actually worth it.
Here in florida, its worthless
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 12-10-2007, 11:59 AM   #3
koven
My Ride: 330Ci
you're right but either way.. you both won't win!
koven is offline   Reply With Quote
Old 12-10-2007, 12:16 PM   #4
DylloS
My Ride: nothing
I'm sure there is some ridiculous formula someone knows that can answer your question.
I would agree with you though.
DylloS is offline   Reply With Quote
Old 12-10-2007, 12:19 PM   #5
BIZ323
My Ride: Miyagi
Send a message via AIM to BIZ323
Odds and probability are diff.
BIZ323 is offline   Reply With Quote
Old 12-10-2007, 12:25 PM   #6
inzideurhead
My Ride: ///M3
Doesn't answer my question but let's talk about probability.
Old 12-10-2007, 12:26 PM   #7
ATB24
My Ride: '03 330i
It doesn't make a difference. Every time the same # of balls are in the spinny cube thing.
You have just as much chances of winning as they do. The only thing that would skew the odds is if they took out certain numbers from the drawings
ATB24 is offline   Reply With Quote
Old 12-10-2007, 12:30 PM   #8
brew
My Ride: F150 X5 MR2
You're both wrong. If the lotto is truly random (assumes that the extra ink on double digit balls doesn't make them heavier, etc.), then playing random numbers every time should be the same as playing the same numbers over and over.
brew is offline   Reply With Quote
Old 12-10-2007, 12:34 PM   #9
marvintheandroid
My Ride: The Heart of Gold
It's the same thing, because each time lotto numbers are drawn - they are independent from the last time they were chosen. If you draw numbers for this months lotto, it doesn't change what they're using for next months lotto right?
The central limit theorem will just tell you that it's coming from a normal distribution being that it's coming from such a large set of numbers you can normalize it.
marvintheandroid is offline   Reply With Quote
Old 12-10-2007, 12:34 PM   #10
MFarrZHP
My Ride: Has 6 speeds
1, 2, 3, 4, 5, 6 has the same probability as an other set of numbers. And the is no "memory" in this type of probability, playing the same numbers does not increase the odds.
MFarrZHP is offline   Reply With Quote
Old 12-10-2007, 12:39 PM   #11
inzideurhead
My Ride: ///M3
So you are saying that playing the same numbers over and over and over
is exactly the same as playing a comepletely random (different) set of numbers over and over?
Old 12-10-2007, 12:40 PM   #12
MFarrZHP
Yes. Assuming that the lotto game is not biased in any way.
Old 12-10-2007, 12:42 PM   #13
marvintheandroid
Yep, here's an example that'll clear it up. If I have die that's numbered 1 through 6. If you bet 1 every time versus someone who changed their number everytime. It wouldn't really make a difference because the events of rolling are independent from each other. One roll has no bearing on the next. The probability remains the same, 1/6 for each event.
Old 12-10-2007, 12:44 PM   #14
inzideurhead
My Ride: ///M3
Thanks....
I just feel that there is a better success rate to change the numbers.
Old 12-10-2007, 12:55 PM   #15
marvintheandroid
Intuiting and statistics don't blend well, how many numbers are there in the lottery like 6 right? number 1-99.
(99 !) / ((8 !) * (91 !)) = 171 200 862 756
That means you have 171,862,756 unique combinations
So, if this time you chose 1 2 3 4 5 6 your probability of winning would be 1/176,862,756. Say you lose and you play again the next time you chose 6 5 4 3 2 1 your probability of winning? You guessed it 1/176,862,756. But wait, what if you chose the same set of numbers as before 1 2 3 4 5 6? The probability remains untouched, the only thing that would increase you chances of winning would be buying more unique tickets.
Old 12-10-2007, 01:01 PM   #16
marvintheandroid
You want to hear something even more mindblowing? Even if you buy more tickets and thus increasing your odds - your expected value decreases until a certain point (that point may be so expensive you would no longer like to play the lottery). Not only that in small amounts you are also @ a negative expected value.
Some more statistical nonsense, say the jackpot is 150 million - even there since more people are playing, there's a 57% chance that no one will win.
Old 12-10-2007, 01:04 PM   #17
inzideurhead
My Ride: ///M3
YOU ARE THE MAN!
Thanks!!
Old 12-10-2007, 01:04 PM   #18
ItalianSaint
My Ride: 2004 325Ci
Even though the probability remains consistant wouldn't the chances of a match increase due to deterioration in the final location(number of tries to get a match)? That's the way I remember it.
"Just another freak in the freak kingdom." -HST
ItalianSaint is offline   Reply With Quote
Old 12-10-2007, 01:09 PM   #19
marvintheandroid
Nope, each unique number has an equal chance of being chose. What I think you're talking about is say the winning number is 1 2 3 4 5 6 and the winning number is 1 2 3 4 5 8, well once it's rolled 1 2 3 4 5 - since they come out sequentially. You would have a higher probability of winning against say someone who has 1 2 3 43 32 34. But you can't really look at it that way since the game's already begun, your number and the other guy's number had the same probability of being chosen from the start.
Old 12-10-2007, 01:12 PM   #20
AVSmitty
Location: Alexandria, Andalucia, Austin, Baltimore, Bangalore, Bangkok, Beijing, Cairo, Istanbul, Paris, Tokyo, Tucson, Washington DC, Xiamen, Xian
My Ride: German
Expected value being:
(1/176,862,756) X ($1,000,000-$1) + (176,862,755/176,862,756) X -$1 = -$0.9943
The word is ridiculous. With an "i," not an "e." Most misspelled word on this site.
AVSmitty is offline   Reply With Quote
