Old 12-24-2016, 04:02 PM   #1
rb01
My Ride: 323i 98 208HP
Ms43 wideband/afr sensor
Hi guys,
I want to try wideband sensor for better tuning my car. Need some info and help.
Should/can i use wideband sensor with ms43 ecu?
Maybe i can use just for cheking afr as gauge?
rb01 is offline   Reply With Quote
Old 12-25-2016, 03:51 PM   #2
cwarel
My Ride: 330ci coupe
Just get innovate lc2 full kit for 160$ and you will be set
cwarel is offline   Reply With Quote
Old 12-25-2016, 04:01 PM   #3
rb01
I'm looking at this one
http://www.ebay.co.uk/itm/NEW-PLX-DM...UEvgk#shpCntId
Should i leave old pre cat liambda sensors and just weld another one for gauge? or change them?
Old 12-25-2016, 04:08 PM   #4
cwarel
Much more likely you should get this one because you will be able to log AFR with romraider
Also about the bungs It would be ideal if you weld another bung , but knowing that headers leave no room for extra sht , you could take 1 post cat sensor out and screw wideband in there and then go to the ecu tune file and click Pre-car sensors only with auto learning of post cats ( thats how I did it ) Works fine but i gotta plug in the laptop to change default settings a bit and thats where you have to buy this thing because apparently innovate doesnt provide you with this in their kit . Also make sure you do the install properly such as you gotta place a relay to power up the sensor otherwise it wont be accurate http://www.ebay.com/itm/400823961327...%3AMEBIDX%3AIT
http://www.ebay.com/itm/152253059215...%3AMEBIDX%3AIT
Old 12-25-2016, 04:11 PM   #5
rb01
I allready have only pre cat sensors, exhaust is catless and straight
Old 12-25-2016, 04:12 PM   #6
cwarel
Yeah i got the same thing only no resonators and stock muffler in the back
Well then just screw in the sensor and you be golden
Old 01-04-2017, 11:14 PM   #7
rb01
So i ordered this one
Sent from my SM-G930F using E46Fanatics mobile app
