Old 08-08-2014, 04:17 PM   #241
therealpbgamer
My Ride: 2002 330ci
Originally Posted by kpeng View Post
Thanks Tim! I picked up both diffs, and I think the new one is like 5 lbs. or so lighter than the old one.
I did swap the input flange, but since the diff dimensions are different, the stock driveshaft wouldn't reach. It wasn't a matter of not being able to bolt up, it was a matter of getting the driveshaft to even reach the input flange. To solve this, I needed a driveshaft that was longer.
Found it
therealpbgamer is offline   Reply With Quote
Old 09-05-2014, 12:10 AM   #242
therealpbgamer
My Ride: 2002 330ci
So im in the middle of this DIY for my 2002 330ci coupe and I've hit a snag...
The diff is mounted and im in the process of putting the new donor driveshaft on.
The driveshaft i bought is from a 2003 325i, and even after i stretched in from loosening the spline, it's not nearly long enough.
Can anyone confirm that I bought the wrong driveshaft, or i need one from a coupe?
It seems the shorter end of the driveshaft that mates to the tranny is much shorter on the one donated from the 325i, vs. my stock 330 one..
The diy said ANY e46 so...
Old 09-23-2014, 09:28 PM   #243
zamm333
My Ride: 2001 330ci
you still got you 3.38?
zamm333 is offline   Reply With Quote
Old 09-24-2014, 01:36 PM   #244
therealpbgamer
My Ride: 2002 330ci
I still have my my 3.38, it has a 4bolt input flange thats not tightened down all the way so anyone could use
Old 06-24-2015, 11:02 AM   #245
E46BimmerAddict
My Ride: 03 325ish
Resurrection - what year X3's can you pull for a 3.91/3.64 rear. Also the Manual or the Auto Trans. i am not trying to change drive shaft since mine is already custom made in carbon fiber from PST.
Or if anyone knows the year ranges for the Z4 3.64 rears that would be awesome
Thanks Everyone!
Mods ( Never to a shop, don't trust them )
Headers, De-Catted, full 3" to a 3.5" Hushpower, catch can, EGR delete, Secondary Air injection delete, Catch can/Oil Seperator delete, 3.46 rear diff, Stage 3 Clutch and 15lb SM Fly, UUC SSK w/ double shear, 2" Lowering springs ( soon to be Coilovers ), Powerflex bushings Everywhere. Recently Installed Innovate Water temp/Voltage, Innovate A/F and Innovate Oil Press/Temp gauges
E46BimmerAddict is offline   Reply With Quote
Old 06-24-2015, 11:09 AM   #246
therealpbgamer
My Ride: 2002 330ci
If you have a custom driveshaft this swap may not work, unless your driveshaft is adjustable in the middle like the stock ones.
I went through 3 driveshafts trying to find one that would fit, until I just got one like in the thread, one from a 323i.
I got my 3.91 from the rear of an 2005 x3 2.5L auto. Only auto 2.5L x3 have the 3.91.
Hope this helped.
Old 06-24-2015, 11:13 AM   #247
daniel_f.
My Ride: 330iC
Hope this helped.
Interesting. Mine is from a 320iA with SA204
Old 06-24-2015, 11:14 AM   #248
E46BimmerAddict
My Ride: 03 325ish
my drive shaft is exactly like the factory ( in terms of mounting and center bearing ) just stronger and lighter. this is a 325i 5spd i have the 3.46 rear out of an auto in it now just not enough a$$ for me i want more.
Old 06-24-2015, 04:37 PM   #249
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
If you're still going to run Nitrous, I would recommend Against getting a 3.91 ratio.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 06-24-2015, 04:44 PM   #250
E46BimmerAddict
My Ride: 03 325ish
i do still plan on it and have the kit mostly completed. the 3.91 will be strictly for Auto-x and daily driving. i will throw in the 3.46 when i run the tanks. its takes longer to jack the car and get ready then it does to actually take it out and in . In/out in about 45min or so.
Old 10-03-2015, 07:51 AM   #251
3.30 cabrio jim
My Ride: 3.30 cabrio
hello evryone i have a 3.38 diff in my 3.30 with six speed gearbox manual and i want it a bit shorter than now so from which bmw fits mine the ratio i want is 3.64 and more thanks in advance
ps i think its the x3 30i that has 3.64 dif fist model and the x3 diesel that has 3.91ratio correct?
3.30 cabrio jim is offline   Reply With Quote
Old 11-26-2015, 09:40 AM   #252
JoeTe
My Ride: BMW 330CiA '04
All X3 have LSD ??
JoeTe is offline   Reply With Quote
Old 02-17-2016, 04:57 PM   #253
Flop
My Ride: '04 330Ci 6MT
Bringing this back from the dead to warn people... the 3.91 X3 differential is a SMALL CASE differential, which has a 168mm ring gear. This is much smaller and weaker than the 188mm ring gear ("medium case") which came standard in E46s (M3 had "large case" 210mm ring gear). Small case differentials are usually only found in 4 cylinder BMWs, so it's surprising they put one in an X3.
I found this out last night. I was planning on switching to the 3.91 diff for my 1JZ swap... but no way will it hold 500+ hp. I'm going with the 4.44 X3 3.0si unit instead, which is a medium case unit.
Flop is offline   Reply With Quote
Old 02-17-2016, 05:09 PM   #254
therealpbgamer
My Ride: 2002 330ci
It's held up well in my 330, about 30k miles so far. I did have to do my diff bushing, but my car is full bolt on as well, so the extra torque may have contributed to that.
Old 02-17-2016, 05:23 PM   #255
Flop
Unless you are launching with sticky tires, I'm sure you will be fine.
Old 03-13-2016, 10:06 PM   #256
xfarsidex
My Ride: 2002 BMW 330Ci
I'm planning on this swap soon. I have a 330Ci AT. I want to make sure I get the right driveshaft. Say I get one off of a 325i, would the AT or MT drive shaft be the same length or different? I know in the write-up it said that a 323 shaft was used but didn't specify what trany it came from. I just didn't want to get the wrong part.
xfarsidex is offline   Reply With Quote
Old 03-13-2016, 11:29 PM   #257
therealpbgamer
My Ride: 2002 330ci
Get a 323ci auto driveshaft. That worked for me. I got a 325 auto driveshaft too but that didn't fit.
Old 03-14-2016, 01:13 AM   #258
xfarsidex
Great, thanks.
I figured while I did it I would change out the trany/diff bushings, and guibo. Is there anything else that should be looked at while back there?
Is the 0-60 noticeably faster? While the auto is not ideal, I would like the strongest launch I can. I don't have the money to build the car as I would in dream land. Making a quick and cheap NA/AT is taking the hard road.
Old 03-14-2016, 11:34 AM   #259
Flop
FYI, I have a 3.91 diff for sale if someone wants it. PM me for details.
Old 03-14-2016, 01:02 PM   #260
xfarsidex
What would it cost to ship one of those? Being in NC, I would imagine pretty high coming from OR.
