Old 01-06-2003, 02:59 AM   #1
WKC369
My Ride: 330i
HELP!!! (Concerning UUC Swaybars)
I'm getting some MAJOR squeaking from the font (some from the rear) after i installed the UUCs...
WHY???
any solutions???
Thanks.
WKC369 is offline   Reply With Quote
Old 01-06-2003, 03:11 AM   #2
carguy84
Banned
My Ride: 330i
You need to put on (more?) grease. Be liberal about it too.
Chip-
carguy84 is offline   Reply With Quote
Old 01-06-2003, 03:43 AM   #3
GhostRider
...and I'd be all shiny..
My Ride: 2001 Dinan 3, 5sp
kind of a clunking noise huh? others have had something similar, but be as descriptive as you can about your specific problem to get better answers.
Here's a link I found by a quick search, hope it helps:
http://forum.e46fanatics.com/showthr...sway+and+clunk
GhostRider is offline   Reply With Quote
Old 01-06-2003, 09:00 AM   #4
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
You need to make sure your sway bar bushings are properly lubed.
vinnymac is offline   Reply With Quote
Old 01-06-2003, 11:42 AM   #5
GunMoto
My Ride: EG8 | E46 | W211
Send a message via AIM to GunMoto
Definitely sounds like you need to grease the bushings. I've greased mine once after installing them the first time. I liberally applied a heavier weight (wheel bearing) grease after lithium grease which I used initially.
GunMoto is offline   Reply With Quote
Old 01-06-2003, 12:38 PM   #6
Sean@ECIS
Past Site Sponsor
My Ride: ?
greasing the bars is only temporary, you'll be doing it every year...wrap the bar(s) with plumbing tape (just where the bushings are) and you'll never have to do it again. Trust me, it works.
Sean@ECIS is offline   Reply With Quote
Old 01-06-2003, 07:03 PM   #7
WKC369
My Ride: 330i
Thank god there's a solution! was worried that it was symptomatic of having harder bushings...
will grease them up real good... and also try the plumbing tape.
cheers.
Old 01-06-2003, 07:07 PM   #8
GhostRider
Are you talking about the white kevlar type plumbers tape that you use to keep a shower head from leaking out the sides?
Old 01-06-2003, 07:19 PM   #9
lilherc79
"DPErt-ASchnizA-*****"
My Ride: ASA ACS 3.0 Cabrio
make sure all the bushings are properly lubed. (USE A LOT!!!) plus, make sure all the connecting bolts are tight, especially the rear end links they have to be adjusted when the car is on the ground. Make sure they are tight and they are adjusted equal length to prevent premature breakage.
lilherc79 is offline   Reply With Quote
