Sponsored by The Tire Rack
Old 05-10-2002, 12:43 PM   #1
s4play
Banned
My Ride: ML320, 02 M3, 01 S2K
Send a message via AIM to s4play Send a message via Yahoo to s4play
Will the 330ic spare fit the 2002 M3's? Not sure about you guys,
but I hate running around without a spare and jack in my trunk. Forget that mobility kit or roadside service, bottom line is that if you get stranded in a remote area, your $%CKed!
I have already done some research and found a titanium race jack used by some race teams...only weighs 15 lbs! Down side is the cost is over $800!
but I wanted to buy a universal spare I can use on my M3 that will clear the brakes for both front/rear. Any ideas or suggestions?
I'm sure many other M3 owners are wondering the same thing.
later,
rick
s4play is offline   Reply With Quote
Old 05-10-2002, 01:17 PM   #2
obLu
My Ride: 330cic
Aluminum jack....
30lbs only $300. Double the weight, but 30lbs is still lighter than the stock wheel and jack.
Can a 17" wheel clear the m3 caliper? When I had to put my spare it looked pretty tight, so my guess would be that it probably wouldn't.
But I kind of remember somebody saying the space saver spare from a Porsche would work?
obLu is offline   Reply With Quote
Old 05-10-2002, 02:10 PM   #3
Full Time Hit Man
Banned
My Ride: E46
Send a message via AIM to Full Time Hit Man
s4play, will you sell me your mobile kit? Thanks.
Full Time Hit Man is offline   Reply With Quote
Old 05-12-2002, 12:53 PM   #4
s4play
Banned
Sorry FTHM but I usually like to keep my stock parts
when the times comes to sell my car.
rk
Old 05-12-2002, 04:20 PM   #5
presario
My Ride: 330ci
The stock 17 330 wheel should work with a spacer to fit over the brakes. Maybe 5 mm? Just carry the spacer around with you in the car. It may work.
Sig by Jojo//Celsius One
presario is offline   Reply With Quote
