Old 12-30-2007, 05:19 PM   #1
carcus
My Ride: 2006 BMW M5
Sand pitting on windshield and headlights
Any advice on getting a little improvement on the pitted headlights and windshield from something out there? I have a mothers power ball also, just wondering what to use, especially for the headlights. Thanks all.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 12-30-2007, 06:03 PM   #2
deafboy
My Ride: 2000 323Ci
wetsand and polish....
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 12-30-2007, 07:14 PM   #3
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
To fix your headlights you can restore them with a light wet sand and polish. If you want to remove slightly deeper imperfections you should first do a little wet sanding. Typically I'll tape off the surrounding trim and paint. Then I'll use 800 grit wet/dry sandpaper and buff with light to medium pressure with a soap and water mix misted on the surface regularly. Repeat this process with 1,000 girt and 2000 grit wet/dry sandpaper. This should leave the surface very smooth but hazy so you'll want to follow it up with at least two polishes and work them in thoroughly. If you don't want to wet sand you can go right to polishing. Typically I would use a medium cutting polish (Menzerna Intensive Polish) and follow it with a light finishing polish (Menzerna Final Polish II). If you went very aggressive with the wet sanding you may need to add a heavy compounding polish before the medium cutting polish to fully remove any haze. Let me know if you have any other questions.
Greg @ Detailed Image
Old 12-30-2007, 07:39 PM   #4
silver330ciman
My Ride: TiAg 330CI TS1
Same for the windshield?
Sig by hi its me alec
silver330ciman is offline   Reply With Quote
Old 12-30-2007, 07:44 PM   #5
deafboy
My Ride: 2000 323Ci
Just get a new one....
glass can easily be ****ed up by sanding it....
Old 12-30-2007, 07:44 PM   #6
No, glass is much harder and requires a totally different set of products. Often times its cheaper and more effective to just replace windshields in my opinion. Glass polishing is not my expertise so you may want to contact a glass professional before beginning.
Greg @ @ Detailed Image
Old 12-31-2007, 12:10 AM   #7
carcus
Thanks Greg,
Will try the wetsanding on the headlights. Appreciate the info. And yes, think I am stuck with the windshield. Pitted and messed up from the sand and winter weather.
Old 12-31-2007, 02:00 AM   #8
deafboy
My Ride: 2000 323Ci
Originally Posted by carcus View Post
Thanks Greg,
Often insurance will cover a new windsheild for the price of the comprehensive deductible
Old 12-31-2007, 06:13 PM   #9
shortyb
My Ride: Has blue lights
Exactly. If it takes more effort, try polishing with the rounded end of a ball peen hammer
shortyb is offline   Reply With Quote
Old 01-03-2008, 05:26 PM   #10
Rico2000
My Ride: 323I 2000 Touring
I found toothpaste to work real well on the headlights...no lie!
Rico2000 is offline   Reply With Quote
Old 01-03-2008, 06:20 PM   #11
carcus
Thanks all for the advice. I probably will just live with the windshield since in Colorado, when it shows, they lay all the sand on the road and would just tear up a new one if I got it as well.
Now for the headlights, I used my plastic polish and mini power ball. Looks much better, still need to spend more time on it and next, hit the fog light lenses.
Old 01-08-2008, 08:00 AM   #12
scheerspeed
Banned
My Ride: BMW E90 325i black
you might want to get a clear bra or something over the front of your car to avoid getting it again...
scheerspeed is offline   Reply With Quote
