Old 01-01-2008, 07:11 PM   #1
dastrix
My Ride: BMW E46 325 Ti Sport
Do i need to change any wiring?
Hi Guys
My car has self leveling, auto halogen headlights. I am fitting OEM Bixenons that my car came with if you ordered the option.
Does anyone know if the wiring is a straight plug/play between the Halogen/Xenon ?
The Xenons I ordered are complete, all the bulbs, ballast and so on (All OEM BMW stuff)
Thanks!
dastrix is offline   Reply With Quote
Old 01-02-2008, 04:24 PM   #2
sillieidiot
My Ride: '06 AW 330ci
glad you finally got yourself a set. no change in wiring should be needed.
Old 01-02-2008, 04:52 PM   #3
dastrix
Not complete yet champ, still TRYING to find a RH side light Just preparing myself...
Old 01-03-2008, 06:20 AM   #4
sillieidiot
oh. well you should be fine. there should not be any new change in wiring involved. unless your car is some special fluke lol
Old 01-04-2008, 10:38 AM   #5
paraklas
My Ride: ESS TS2 320ci
The bi-xenon wiring is different than the halogen one. You will need to either:
Mod the existing wiring to operate the bi-xenons & get rid of the bulb failure warning. Bi-xenons have a 3rd plug that triggers the flap when you turn on the high beams.
or
run new wires from the headlights up to the LCM. I haven't seen a bi-xenon wiring loom for sale so you will probably have to make your own. Then you will have to find out which pins on the LCM correspond to the bi- feature. After you finish with the wiring, you must take your car to the dealer to recode the LCM for bi-xenons.
The only plug and play thing are the headlight screws, low/high beam plugs and autoleveling plugs
Old 01-04-2008, 02:12 PM   #6
sillieidiot
or
yea, so in essence, it's the same. he doesn't need to change anything unless he wants to make the bixenon function work.
Old 01-08-2008, 08:41 PM   #7
dastrix
****, well yes I want to use the bixenon function... So I need a wiring harness, oh god! That will be impossible to find or work out how to get it working. Will I need to recode the LCM to get Xenon low beam working only without warnings?
Old 01-08-2008, 09:46 PM   #8
dastrix
Ok, found a few DIY guides, all very complex but maybe a smart electrical guru can do it here locally.
Seems its a straight fit for a low beam xenon only. And if they flicker, ill get my LCM coded to BiXenon and do the retrofit/DIY project
If i buy a local LCM for biXenon can I just swap it over? I heard there are milage tamper issues with swapping over LCM's?
