Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 01-04-2008, 08:49 AM   #1
Poorboyz
My Ride: 2001 330Ci
Diy -- Coupe C-pillar Removal
*** DIY Ė COUPE C-PILLAR REMOVAL ***
TOOLS NEEDED
-- Small flat head screw driver
-- T-25 Torx ( I used my small flat head screw driver as it fir perfect )
Step 1. Take the small flat head screw driver and from the underneath of the light push it in between the light and the panel. This is a very tight fit. Also be careful as to not brake the clear light cover as you pry up. These are the 2 points I used to pry up on the light (see picture). Unclip the wires from the back and youíre now ready for step 2.
Step 2. Use the T-25 Torx and take screw out.
Step 3. Pull the panel out by using the hole in the panel that the light came out of and your other hand at the very top of the panel. There is 2 clips at the very top that hold this panel in. Look at picture for location of clips. Youíre going to have to pull out very hard so donít be afraid to break it. Once you get the top out then all you need to do is pull the bottom out. There are no clips or screws and the bottom so just pull on it.
THATíS IT YOUíRE DONE
Name:	COUPE C PILLAR REMOVAL 1.jpg
ID:	254848   Click image for larger version
Name:	COUPE C PILLAR REMOVAL 2.jpg
ID:	254849   Click image for larger version
Name:	COUPE C PILLAR REMOVAL 3.jpg
ID:	254850   Click image for larger version
Name:	COUPE C PILLAR REMOVAL 4.jpg
Poorboyz is offline   Reply With Quote
Old 08-18-2008, 10:54 PM   #2
TopasBlau46
My Ride: 2001 E46 325ci ZSP
thanks this is very helpful man
TopasBlau46 is offline   Reply With Quote
Old 10-26-2008, 03:54 PM   #3
mkodama
mkodama's Avatar
I broke a plastic clip on reinstallation. Make sure everything is lined up when reinstalling.
Old 10-27-2008, 01:18 PM   #4
HELLAS NC
My Ride: 03 320Diesel Tractor
I took out the c-pillar on the sedan without removing the light first. just took out the bulbbracket from the back
I don't have a solution, but I admire the problem.
HELLAS NC is offline   Reply With Quote
Old 10-30-2008, 01:57 AM   #5
GatorHawk
My Ride: 01 330ci M/T
Thanks for the info.
Here in Florida, the heat makes all of the fabric separate from all of the the A/B/C-Pillars.
Roof starting to as well.
GatorHawk is offline   Reply With Quote
Old 12-22-2008, 02:03 AM   #6
danGIMP
My Ride: '99 328i, '03 X5
What do you do to glue back the fabric?
danGIMP is offline   Reply With Quote
Old 05-14-2009, 10:51 PM   #7
Poorboyz
My Ride: 2001 330Ci
My mother owns a upholstery business and she had one of her workers do all my panels for me. A, B and C.
I have not a clue what he used but will ask and post it back on here.
Chuck
Old 09-14-2009, 12:09 PM   #8
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
subscribed
Devious1 is offline   Reply With Quote
Old 08-06-2010, 06:18 PM   #9
tls5219
My Ride: BMW 2002 325CI
Hey I am doing my pillars as we speak and for anyone who comes across this thread can send me a message for help on any of the pillars. To glue the pillars back o down to Michael's and buy Aleene's Fast Grab Tacky Spray this is what I recommend to everyone especially for lighter interior cars. 3M is good too but can cause some discoloration. This spray does not cause discoloration, bleeding of glue, or wrinkles after time.
tls5219 is offline   Reply With Quote
Old 08-06-2010, 06:21 PM   #10
Devious1
Invalid User
My Ride: 330ci
i did my pillars not too long ago. the front was probably the hardest because 2/3 of the screws were a pita to unscrew. everything else was easily accessible.
Old 08-26-2010, 11:19 AM   #11
TX_Bullet
My Ride: 2001 325Xi
How easy would it be to re wrap the pillars. The A's have already been replaced but the B and C or done.
If this fairly easy just let me know what adhesive and fabric to use
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 08-30-2010, 02:47 PM   #12
CHFBrian
My Ride: 2001 330i
I need to do this as well, as the fabric on my c-pillars is coming off. Anyone know what the correct adhesive to use would be?
Silly me, I didn't read the previous posts carefully enough.
Aleene's Fast Grab Tacky Spray it is.
CHFBrian is offline   Reply With Quote
Old 01-18-2011, 03:16 PM   #13
kbsport
My Ride: e46, e36, e30
Just completed C-Pillar reglue. It looks like 3M is going to leave a film, appears to soak through thin cloth. My C-Pillar were attached w/ common door clips (2 at top), as stated this piece should be removed carefully and up & out (after release of clips), not at an angle. I believe the 3rd tail light was redesigned at 9/99, so the same may apply to the C pillars. Both appear to attach w/ door clips now.
kbsport is offline   Reply With Quote
Old 02-18-2011, 12:55 AM   #14
SW222
Banned User
My Ride: is silver and slow.
Yeah I just did the same thing too and the 3M was really sticky, it soaked through the cloth so I only did the edges. I have some stains on there from the spray soaking through. Not the best result but it's better than seeing it hang. Definitely a sticky, messy diy and would not want to have to do it again.
Anyone know what I can use to remove stains on the cloth?
SW222 is offline   Reply With Quote
Old 02-18-2011, 11:05 AM   #15
wikolipr
My Ride: 01' E46 M3
Good Job Poorboyz,
Just a few days ago I noticed my C-Pillar fabric hanging and was wondering how to take these out to repair them.
For Sale:
Fan Clutch Holding Tool
PM for details...
wikolipr is offline   Reply With Quote
Old 04-17-2011, 05:23 PM   #16
rkneeshaw
My Ride: 330i ZHP
Great DIY, thank you for the pics. I would definitely have broken that map light into a ton of pieces without seeing the pics and knowing exactly where to pry it out.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 04-17-2011, 06:47 PM   #17
KohbraxE46
My Ride: E46 328i
Need to do all my pillars. I have a face lift sedan. Anything too
Different?
How do I remove the A pillar and B pillar? Also where Can I buy the adhesive ?
KohbraxE46 is offline   Reply With Quote
Old 05-23-2011, 07:04 PM   #18
Poorboyz
My Ride: 2001 330Ci
Different?
A pillars are pretty straight forward, just pry up the little piece in the middle of the A-pillar and remove the torx screws.
The B-pillar DIY is below.
http://forum.e46fanatics.com/showthr...064&highlight=
Old 05-28-2011, 08:38 PM   #19
Custom3
My Ride: HellRot 330CI
niceeee....i was looking for this
Old 06-17-2011, 10:11 AM   #20
My1stBimmer17
My Ride: SlvrGry/Imola '05 M3
I tried a couple of other glues on my old 328i and they all tend to bleed through/get hard. THE BEST adhesive that I've found is the Krylon Spray Adhesive - available at your local hobby/craft/art store. Peel the fabric back (or take it completely off if it's real bad), spray the mounting surface (careful with overspray), leave it for a couple of seconds to get tacky, then smooth the fabric back on. Looks just like it came from the factory; nice and soft and uniform without any hardness!
Be careful not to spray too much as it will pool and bleed through as well, leaving it looking like it was dipped in salt water or something. Use the same 'form' as you would for a can of spray paint. You'll see the area get covered in what looks like a 'frost' and that will be enough. Hope that helps...
My1stBimmer17 is offline   Reply With Quote
