Motorsports & Track Forum by BimmerWorld
From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast Sponsored by BimmerWorld |
#21 |
My Ride: 08MiniCooperS
i think it's great that UUC is offering another alternative for E36/46 cars. by offering the alcon kit, it doesn't mean that the wilwood kit is all of a sudden obsolete. it's just an alternative like rob stated above. different technology = different price points. with that said, i think i'm going to have to order this alcon kit!!
#22 | |
...and no Rob, do not jump on my ass, it was a joke between Ashley and myself. Actually, I hate to admit it, the Alcon's look like a good kit. Never liked any of the past UUC BBKs or any other products since the orginal Rob Knob, wayyyyy back when.
#23 |
Banned
Hey Rob random question - do you know if OEM ZHP wheels will clear the 4 piston wilwood caliper? I was recently thinking with the number of road trips i go on I should start carrying a spare, and I know my 17" spare doesn't make it. Was thinking of picking up a ZHP wheel.
#24 | |
Wilwood 4-piston / 325mm front diagram for E46/E36: http://www.uucmotorwerks.com/pbc/SUP..._1_1_TEMPL.pdf Wilwood 4-piston / 325mm front diagram for E46/E36 (8mm more clearance): http://www.uucmotorwerks.com/pbc/SUP..._1_1_TEMPL.pdf Alcon 4-piston / 325mm rotor front diagram for E46/E36: http://www.uucmotorwerks.com/alcon/I...R_4POT_325.pdf - Rob |
#25 |
Do these brakes use special pads designed specifically for the kit or can they use OEM pads?
#26 | |
The 4-piston Alcon calipers use a specific pad shape as detailed on our website (you have visited our website already and learned all there is to know about the Alcon kits, riiiight? ![]() See this page for details on the pads: http://www.uucmotorwerks.com/alcon/pads.htm ![]() Pad shape cross-reference: Hawk Part # HB 105.630All of these companies make a variety of materials in this shape. - Rob |
#27 | |
#28 |
can UUC comment on how your Alcon kit compare with this...
http://forum.e46fanatics.com/showthread.php?t=496339 ..... |
#29 | |
What you're looking at in that thread is a kit built by Stasis Engineering for the E46 M3. That kit fits only the E46 M3, Stasis is not available for non-M models. However, the UUC kit for the E46 M3 is about to be released mid March '08. So let's do two comparisons for you, Stasis and the UUC M3 kit and UUC 330/325/323 kit: Stasis for E46 M3: front: 6-piston/365mm floating rotor - $3695 rear: 4-piston/343mm floating rotor - $2595 TOTAL: $6290 color options: silver only UUC/Alcon for E46 M3 (pricing published in Roundel, Bimmer magazines): Front 6-piston/345mm* floating rotor: $2895 Front 4-piston/345mm floating rotor: $2695 Rear 4-piston/328mm floating rotor: $2395 Combo price 6-piston Front and 4-piston Rear: $5100 color options: matte gray or red * soon to be available: 380mm option (requires 19" or larger wheels) UUC/Alcon for E46 330/328/325/323: Front 4-piston/325mm floating rotor: $2395 Front 4-piston/325mm solid rotor: $1999 Rear 4-piston/328mm solid rotor: $2395 Rear 4-piston/328mm solid rotor: $1999 Combo price 4-piston Front and 4-piston Rear: w/floating rotors: $4690 w/solid rotors: $3898 color options: matte gray or red So what are the differences and what do they mean? Rotor sizes: First, you will notice that the initial UUC offerings are all 4-piston calipers and only modestly oversized rotors. This was done for very specific reasons, we're designing for racecar applications. In many racing classes, the rules limit upgraded brake calipers to no more than 4 pistons and no more than 5% over original diameter. However, for those wishing larger, upgrading to the 345mm rotors for 4-piston kits is possible, as well as upgrading to the 380mm rotos for the 6-piston kits. A simple upgrade kit from UUC is available. Bracket construction: UUC is the only company offering a true mil-spec heat treated stainless steel bracket design. Multiple benefits: a) Steel brackets are "lifetime" whereas aluminum, due to accumulated fatigue, is supposed to be replaced at periodic intervals. Our heat treating process makes the steel much stronger than common aluminum brackets.Rotor costs: UUC's basic floating rotor option uses genuine BMW Motorsport floating rotors made in Germany, which are available at a replacement cost for a complete rotor (which means it includes the hat) that is less than typical 2-piece rotors for the disk only. For example, the BMW Motorsport floating rotors are approximately $215 each in the 325mm size. Complete rotors from other BBK companies run $495-$895 each. Disks alone will usually run $230-$350, and then you've got to re-assemble it with the hat. All of that is just a brief overview. For more details (it's important to do thorough research for yourself!), please see: http://www.uucmotorwerks.com/alcon Finally, realize that UUC now has an "official" development relationship with Alcon. For many of our applications, the calipers are custom-built to UUC's specifications for piston size and other details. Please let me know if you need further clarification.
#30 |
^ great reply UUC
mmm i think the maintenance and wear and tear for normal BBK is definitely a factor if there is a budget ... thanks! |
#31 | ||
FOR SALE: National Championship winning #275 JP car
![]() E36 328 JP/GTS-? | E46 M3 | Suburban 8.1L | Grand Cherokee V8 |
#32 |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
wish i could afford/justify buying a set
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#33 | ||
![]() Quote:
BMW CCA Club Racing: 2008 rules: http://www.bmwccaclubracing.com/stat...08+-+v13.2.pdf Prepared Classes Which means you can't use the 6-piston Monobloc, but the 4-piston 2-piece is legal. - Rob |
#34 | |||
i reviewed the application list and there is no mention in your post or on your site that you are using monobloc calipers in any of your kits...and the only pictures that i've seen you post on forums or your site are of 2 piece calipers... Quote:
your statement was: Quote:
![]() E36 328 JP/GTS-? | E46 M3 | Suburban 8.1L | Grand Cherokee V8 Last edited by dmwhite; 03-06-2008 at 09:11 AM. |
#35 | ||
They're not listed on the website yet because they are not available at this time... about another week. Magazine advertising has caught up with us, the 6-piston kits are listed in Roundel and Bimmer. But I was referring to the list I posted in this thread comparing the systems: http://forum.e46fanatics.com/showpos...1&postcount=29 Quote:
- Rob Last edited by Rob Levinson * UUC Motorwerks; 03-06-2008 at 09:52 AM. |
#36 | |
![]() Hall of Fame line right there. Its going in the signature. "But baby, your request for confirmation was obfuscated by insufficient clarity." PERFECT! Just PERFECT.
#37 | |
maybe your statement should have read: In many racing classes, the rules limit upgraded brake calipers to no more than 4 pistons and/or no more than 5% over original diameter. - that would have widened the scope to more than 2 race classes and since we're being picky, maybe the wording should have been clarified even further since i've never seen calipers limited to 5% over the original diameter, only brake rotors. maybe this wording would have been better- In many racing classes, the rules limit upgraded brake calipers to no more than 4 pistons and/or rotors to be no more than 5% over original diameter. take care
#38 | |
- Rob |
#39 |
you justify it by stopping and preventing a major accident that regular brake wouldn't have prevented ?
![]() so E46 M3 application is monobloc 6/4 piston but the regular is 2 piece 4 piston? |
#40 |
