Old 06-10-2010, 01:16 PM   #61
JimmyOberg
My Ride: BMW 330Ci 2001
These Alcon-kits looks great! Since I'll be starting to upgrade my chassie soon, these will definately be an option!
JimmyOberg is offline   Reply With Quote
Old 06-10-2010, 01:33 PM   #62
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
thanks for clearing that up rob... you learn something new everyday
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 06-10-2010, 02:10 PM   #63
georgiev
My Ride: E46 M3 Individual
Originally Posted by Rob Levinson * UUC Motorwerks View Post
I'll put one thing quite simply; all of our Alcon-based kits have the correct bias for whichever car we are offering them for. Rotor size is not the only factor that determines bias; brake torque (and then the comparison of front:rear brake torque) of a particular brake package is determined by a calculation using multiple factors including pad height, piston size, pad , blp, and rotor diameter.
In a nutshell, don't worry about it - if there's one thing you can be sure of, the UUC engineering on these systems is very, very thorough.
Now, as to why the E46 M3 has bigger rear rotors... it's not a question of brake bias. It has to do with DSC (Dynamic Stability Control) and traction control. This system actuates the rear brakes to control wheelspin, so the components are larger than previous 3-series to retain component longevity, affected by their more frequent use.
thanks for the helpful answer indeed
georgiev is offline   Reply With Quote
Old 06-10-2010, 02:55 PM   #64
FTWeisse
My Ride: has no hip-hop rimz
Old 06-10-2010, 09:25 PM   #65
cnotesdip
My Ride: 330ci
i got the front bbk wilwood they are really good a lil nosiey but the breaking power is phenomenal i love to stop quickly rob did the rear sway bar come in for the m3 and the motor mounts >?
cnotesdip is offline   Reply With Quote
Old 06-11-2010, 06:14 AM   #66
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
How much of an upgrade are the alcon kits over the wilwood kits?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-25-2010, 02:25 PM   #67
UUC Motorwerks, *******
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
The Alcon calipers are at the top of the "professional" list of calipers. That means the ultimate in strength/stiffness.
What you also get is a larger pad area; that means longer pad life, lower pad temps, or the ability to use a milder pad with the same results. While I do not recommend it, we had one of our track junkie customers use his street pads in the Alcon setup for a track weekend... he noted a little less "bite" than the track pads, but they held up perfectly fine.
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
Old 06-25-2010, 02:42 PM   #68
drivrswntd
My Ride: 330ci
Rob, dont the alcon's use the thinner 16mm pads though, vs if you have the wilwood 4 piston fronts which are 20mm? And I think the wilwood pads are cheaper. I absolutly love my wilwood kit and cant wait to get the matching rears.
And on a different note, Rob how about you shed some more light on the new 2 piece rotors you have coming out?
Jay
Boston BMWCCA chapter
drivrswntd is offline   Reply With Quote
Old 06-25-2010, 03:23 PM   #69
Correct and correct, but the Alcon has more surface area, but temperature also affects lifespan is the point... the larger Alcon pad will run cooler.
Awesome, glad to hear it!
Ssssshhhh!!! It's-ay a ecret-say. Details very soon.
-[ CLICK HERE ]
Old 06-25-2010, 08:09 PM   #70
bigjae1976
bigjae1976's Avatar
So does upgrading from the Wilwoods tot he Alcons make sense for someone doing HPDEs and doesn't run more than 25-30 minutes at a time.
Different from the PFC DDs? Maybe a little cheaper?
