Old 01-06-2008, 11:40 PM   #1
vit325
smooth criminal
My Ride: 2001 325i
Send a message via AIM to vit325
i think i need to get into my angel eyes' relay
ok. so my p46s were working fine, angel eyes checked out after tapping the ECU accessories wire. when i went into the glove box with the remote wire and tapped the footwell light (which was a little more trouble than i was hoping for) i found i had a runt. the passenger side high beam halo was wayyy weaker than the rest, it looked barely on and flickering. i tested all the connections and swapped igniters and things like that to try to get to the root of the problem. at some point while switching the igniters back to their original setup i heard a buzzing and suddenly all the halos went dead (shorted out).
current theory: in feeding the brown wire through into the glovebox i may have yanked it, creating a loose connection in the relay which eventually blew.
is there a safe/clean way to get into the relay to see if everything in there is connected securely? another thing to do is obviously to replace the fuse and see if i get power again.
IM FRUSTRATED - there have been many complications. any help/thoughts/prayers/words of encouragement would be greatly appreciated
vit325 is offline   Reply With Quote
Old 01-06-2008, 11:51 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Sorry to hear about all the issues with your P46. You can pull apart your relay by using a flat head to wedge in between the plastic outer housing and inner piece. It will require some force but you can then pull it apart.
Old 01-07-2008, 01:05 AM   #3
vit325
smooth criminal
My Ride: 2001 325i
can it then be snapped back after that? if everything looks ok in there would your conclusion be a bad ring? keep in mind it was working when i originally checked it out.
Old 01-07-2008, 04:02 PM   #4
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Yep, you can just press it back together. It could be a bad ring if the relay turns out to be okay, could also be a ballast issue.
Old 01-07-2008, 05:41 PM   #5
vit325
smooth criminal
My Ride: 2001 325i
the weird thing is they were both working, then went out...then today i was testing connections and got the drivers side working, then both went out again...im lost
Old 01-07-2008, 05:45 PM   #6
Kris325xi
My Ride: 2001 325xi
Hopefully you are able to get it figured out...
I know it can be frustrating... im going to pick mine up now and see how it went... I guess I have a ring out though...
issues and more issues...
Photo Sharing and Video Hosting at Photobucket
Kris325xi is offline   Reply With Quote
