Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 03-04-2017, 03:50 PM   #1
dan_roh
My Ride: BMW 320i Touring
New project E46 330xi Touring FL from 2002
Hi folks
i bought one month ago a new E46 Touring, with a lot to do on it but for a very fair price. It's a 330xi from 2002 with 244'000km (152'000 miles)
Many many options for this car :
S169 EU3 exhaust emissions standard
S203 4-wheel drive
S210 Dynamic stability control III
S249 Multifunction f steering wheel
S302 Alarm system
S313 Fold-in outside mirror
S338 M Sports package II
S354 Green windscreen, green shade band
S386 Roof railing
S403 Glass roof, electrical
S411 Window lifts,electric,front/rear
S431 Interior rear-view mirror with auto dip
S459 El. front seat adjustment w. memory
S473 Armrest front
S481 Sports seat
S494 Seat heating driver/passenger
S502 Headlight cleaning system
S508 Park Distance Control (PDC)
S520 Fog lights
S521 Rain sensor
S522 Xenon Light
S534 Automatic air conditioning
S548 Kilometre speedo
S550 On-board computer
S601 TV function
S609 Navigation system, Professional
S630 Car phone with cordless receiver
S672 CD changer for 6 CDs
S674 Hi-Fi system Harman Kardon
S710 M sports steering wheel, multifunction
S716 Aerodynamics package
S760 High gloss shadow line
S761 Individual sunshade glazing
S772 Interior strip strips, Alu Black Cube
S775 Headlining anthracite
S785 White direction indicator lights
S789 BMW LA wheel, Individual
S832 Battery in luggage compartment
S851 Language version German
S863 Dealer List Europe
S879 Operating instructions German
S915 Omission of outer-skin preservation
S930 BERUECKSICHTIGUNG PREISABHAENGIGK.
Here are some pictures before i started to work on it :
The engine will be fully reworked with new seals and gaskets
The doors are fully a deeply rusted on the lower part... i buyed 4 other ones with no rust or surface rust. I need to sand them and i decided to remove the plastic trims along each door... it's quite difficult and time consuming
The subframe will require a lot of work too...
Thanks for reading
Dan
dan_roh is offline   Reply With Quote
Old 03-04-2017, 07:21 PM   #2
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
Ausgezeichnet!
I look forward to reading your progress.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 03-10-2017, 09:33 AM   #3
Onizukachan
My Ride: `04 M56 Touring
I hope you welded the holes closed and didn't just bondo over them. Really like the interior
If I were to give my Touring Build a first name, I'd probably name it "Alan".
Mostly because I like puns.
E46 Touring TV Tuner Install/Mounting DIY
Wiring City Lights, Rear Fogs, and Rear Camera in a Touring
Onizukachan is offline   Reply With Quote
Old 03-12-2017, 02:45 PM   #4
dan_roh
No i have no welder, i use fiberglass filler to fill the gap and then normal and fine filler to finish it.
Old 03-18-2017, 11:54 AM   #5
dan_roh
Rust everywhere on many parts, mainly on the lower part of the body... need some sanding and new coating.
its quite time consuming and my compressor is quite weak and will blow out if I continue like this. I found a Hammerite product against rust its some kind of bath wich remove rust from pieces. I will give it a try
Removed the oil filter housing... no surprise it was leaking and need a new gasket.
Old 03-18-2017, 07:57 PM   #6
Geo31
Ironman
You could do some electrolytic rust removal.
https://www.youtube.com/results?sear...c+rust+removal
I'm restoring a couple of telescopes and I'm going to try this on one that sat outside for untold years.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 03-26-2017, 04:02 PM   #7
dan_roh
Hello
Got some bad surprise this week-end... On the driver side the floor is badly eaten by rust.
All the floor and carpet are soak, should be a leak in the roof window. I will try to repair it, if i will get to much troubles the car will be sold for parts.
The passenger side is better
Let's have "fun"
Old 03-26-2017, 04:52 PM   #8
otto99
My Ride: 2002 325iT
Damn the tin worm! Good luck!
Greg
325iT
otto99 is offline   Reply With Quote
