Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Thread Tools Search this Thread Rating: Thread Rating: 210 votes, 4.96 average.
Old 02-19-2013, 07:39 PM   #2841
JonathanL
My Ride: 325iT
Originally Posted by 330i ZHP View Post
very cool Jon
Thanks. I've been a big fan of yours for a while. I contemplated the S54 transplant, but couldn't rationalize the budget. Very awesome car, though.
JonathanL is offline   Reply With Quote
Old 02-19-2013, 07:46 PM   #2842
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
Originally Posted by Visor328i View Post
Curious to know how much you would sell it for?
I regretfully am married to this car financially - maybe 11tymillion
/_________\
O==[][]==O
Old 02-20-2013, 05:17 AM   #2843
Imola.ZHP
My Ride: Imola ZHP
You can always pony up for mine...
HA!
It's not in my budget...
11tymillion
Yup, my budget is just shy of that...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 02-24-2013, 11:12 PM   #2844
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
had some fun today
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 02-25-2013, 05:09 AM   #2845
tiagolopes96
My Ride: BMW e46 touring
Portugal
tiagolopes96 is offline   Reply With Quote
Old 02-25-2013, 08:14 AM   #2846
dedo
My Ride: e36 323i coupe
not fan of those ambers, but anyway very nice car.
dedo is offline   Reply With Quote
Old 02-25-2013, 10:44 AM   #2847
GGray
My Ride: 01 325it Wagonator
Thumbs Up
I had fun this week end..
Instructed at VIR took the newly modified Wagonator!
Upgrades done last week before heading to VIR
1.E36M3 front brakes with LTW/GT floating rotors, light machining BOLT right on for a cheap HUGE improvement in braking! Brass Guide pins front/rear PFC 01 pads all around.
2. Converted Koni SA to coilover front with camber plates, and rear ride height adjusters 450Front, 600rear
3. Hotchkiss sway bars front and rear
4. Toyo R888 on 17x8.5 wheels for track.
Handled great brakes were amazing! Not to bad on the straights. needs more power!
It might be the ultimate drive to the track car.. Took me 5 minutes to unload all my stuff and open back doors and hatch, load her up! Four 17's fit perfect in back!
No pictures or video.. I forgot...
If anyone wants pictures of the brake set up or how to do it I can post it.
Gary
Need parts, or a race shop?
email us - [email]info@simod.net[/emaill
Follow us on facebook
If you can take it apart you can make it faster
GGray is offline   Reply With Quote
Old 02-25-2013, 11:26 AM   #2848
jwm5
My Ride: station wagon
Info on brake upgrade would be nice
jwm5 is offline   Reply With Quote
Old 02-25-2013, 11:41 AM   #2849
JHalleck
My Ride: 2000 323it
Info on the brakes and pics!
JHalleck is offline   Reply With Quote
Old 02-25-2013, 09:12 PM   #2850
alpine003
My Ride: BMW
What pads were you using?
alpine003 is offline   Reply With Quote
Old 02-26-2013, 11:32 AM   #2851
GGray
Thumbs Up
Well I cannot get the dam camera to download pictures..
SO until I can. I can tell you how to do it..
You need to take the E36M3 caliper carrier and machine 285thousandths off the surface that goes against the mounting point.
Pull the OEM stuff out of the way, I just zip tied my old ones tot he control arm while I did the test fit. Clean the M3 carrier off with brake clean, then lightly bolt up and mark with a sharpie marker so you know how much to machine off. I machined slightly more for some extra room.
THAT'S IT!
Suckers literally bolt right on, rotor, lines and calipers all go on perfect!
On track I used Performance Friction 01 compound pads. On the street I just have whatever was in the caliper from one of my M3's. When they go bad I am going to use Hawk Ceramic or HPS pads.
I also put brass guide pins in front and rear since I track the car and the pins REALLY help keep pads from getting the pad taper you normally see on slider calipers.
Next upgrade will be a BBK after I add more power.
On track the M3 set up was AWSOME! I could brake on the back straight from 115-120, then on the front from 110-115 every lap with ZERO issues. On Friday we had Instructor day and one hour sessions. I stayed out 45minutes.. until fuel starvation kicked in .. ZERO brake issues.
Overall the E36M3 brake upgrade is nice! Have to run 17 inch wheels a few 16inch wheels fit.
I will pull them all off and apart and paint them red.. I like the ole RED calipers!
ALSO: I work at BimmerWorld we have the E36M3 calipers and carriers here new for less than stock. Or you can find used ones and rebuild them if needed.
Gary
Old 02-26-2013, 02:40 PM   #2852
alpine003
My Ride: BMW
I've run both Ceramic and HPS. Surprised that the Ceramic produces more dust which is counter intuitive to the naming used on it. Stopping power wasn't too different between the two on the streets. If I were to do it again, I would run HPS or Akebono Euro Ceramics on the street to keep my wheels a bit cleaner.
I'll be going with Porsche Monoblocks this spring. I have everything but I just need to find the time to install them when it gets warmer outside.
325mm f / 328mm rear so that I can retain the clearance to run 17" wheels.
Old 02-26-2013, 03:00 PM   #2853
GGray
I had Akebono on my e34 525 touring five speed. They were horrible, not much dust was the only good thing about them.
You can run 332x32 with most 17inch non OEM wheels. I will probably run 355 up front and move to 18 inch wheels for street and track. With E46M3 rear sub frame and brakes in back.
Some club racers did a test a few months ago with 17 vs. 18, same car, same tire, same brand wheel, and model. The 18's were actually slightly faster.
I have had 16, 17 and 18 inch wheels on E46's not a huge difference in performance between the three. As long as the wheel weight goes down slightly as size goes up.
Gary
Old 02-26-2013, 03:14 PM   #2854
alpine003
My Ride: BMW
Interesting. Did you have the Akebono Ceramics or regular? Akebono makes a good portion of the OEM brakes out there so really surprised you had that experience. What was horrible about them?
17's for me is purely about having some level of comfort for the streets on a daily driven car. 332 will not fit my snow setup which are OEM wheels. It's a lot harder and more expensive to get lightweight 18's that rival 17lbs or less. If I had a 330 power levels, I dont' suppose it would matter as much but I need every help I can get running the 325 motor and the 2-3mpg increase is also welcome.
Old 02-26-2013, 03:45 PM   #2855
GGray
They had to much initial bite and the pedal feel was horrible. Over the last 30 years of driving German cars, BMW, Porsche, VW, they were the worst pads I have used. Most German mfg use textar pads for OEM.
I run M&S 18's, currently have Khumo ASX's 235/40, they ride as good as the 17's I had on our silver touring. The roof rack pulled will give you 1mpg, verified on my silver touring commuting back and forth to the office...
Gary
Old 02-26-2013, 04:43 PM   #2856
alpine003
My Ride: BMW
Gotcha, for me the Euro Ceramics had slightly less bite than the OEM Textars in my experience and braking was pretty much on par with the Textars with the exception of the slightly cold initial bite.
I've had ASX's twice and agree that it is a comfortable tire(some complain sidewall is too soft) and rides nice. Potholes however are the other concern around me. Need my roof rack as I actually haul a lot of stuff in mine.
Old 02-26-2013, 04:49 PM   #2857
GGray
The ASX's seem to be a good daily driver wet and light snow tire. Luckily we have smooth roads around here!
You should buy my OEM BMW cross bars then! $100.00 bucks... plus shipping!
I have an old pick up to haul stuff and a small trailer to put on the touring hitch!
Gary
Old 02-26-2013, 04:54 PM   #2858
alpine003
My Ride: BMW
I agree. I'm running Conti DWS now which is very similiar to the ASX with better sidewall support.
Thanks but I have a set of custom aluminum crossbars that I can take off or put on in less than 5 min, that tuck neatly across my trunk when not in use. I have that and a set of bungie cords on me at all times in case I ever need to haul something(like 15ft baseboard trims. ). I've thought about a trailer hitch but I just can't bring myself to drive slow enough to use the trailer in a safe manner.
Old 02-26-2013, 09:25 PM   #2859
redbull 325is
My Ride: 325xit/6
I ran e46 m3 brakes on the front of my wagon for a while and didn't like them as the brake bias was off, now I run 330i brakes all the way around and am very happy with them for dd purposes (using cheap pbr cermaic pads atm, will pick up some hawk hp+ or ht10s depending on budget for track use)
Old 02-27-2013, 02:59 PM   #2860
GGray
Did the E46M3 brakes bolt on? I am going to put my E46M3 six speed in mine and complete rear sub frame assembly in.
The e36M3 stuff up front worked good no noticeable bias change on track or street so far.
Gary
touring
Rate This Thread
