Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Thread Tools Search this Thread Rating: Thread Rating: 210 votes, 4.96 average.
Old 10-01-2011, 09:00 AM   #1921
Fuxxo
My Ride: E46 330D Mpaket tour
Send a message via ICQ to Fuxxo
thanks.. :-)
30d is great engine, love it, dreamed about it from first time I tried it :-)
Fuxxo is offline   Reply With Quote
Old 10-03-2011, 10:24 PM   #1922
cm_weiand
My Ride: BMW 330i; BMW 325it
Hey guys i found one awesome solution. have you guys ever thought or seen this??
Up-side down Rear Strut Mounts!!
After installing my KW V3s i need these, where can i buy these?
found it on http://www.bimmerfest.com/forums/showthread.php?t=16582
-Christopher
style 269's, nitto invos, turner blacked out grills, thule mnt bike rack, bimmerbrakes.com stop-tech premium drilled and slotted rotors, stop-tech street performace pads
cm_weiand is offline   Reply With Quote
Old 10-03-2011, 10:34 PM   #1923
z3couper
My Ride: M Coupe
http://www.rogueengineering.com/rogue/RSM.html
z3couper is offline   Reply With Quote
Old 10-03-2011, 10:49 PM   #1924
cm_weiand
Question: I just bought a pair from VAC Motorsports with additional reinforcement, can i flip these upside down?
http://store.vacmotorsports.com/vac-...kit-p2536.aspx
Thanks z3couper for the link.
Answer: I believe it is No. Damnit wasted money (i installed them). :/
"Additionally, the reinforcement has its hardware welded to it, allowing for the rear shock mount to become a bottom-mount design. This means that if the rear shocks need to be removed, it only requires removing the two nuts and the single bolt at the bottom of the shock. Once installed, there is no need to completely disassemble the trunk area to gain access. If being used with a rear strut tower brace, the reinforcement assembly may be mounted from the bottom, so that the rear shock mount can be secured in the traditional manner." -RE
O.. and here is a sneak peak of my install.
-Christopher
Last edited by cm_weiand; 10-04-2011 at 01:37 AM. Reason: Found the information on RougeEngineering.com
Old 10-04-2011, 01:44 AM   #1925
cm_weiand
Originally Posted by SexualChocolate View Post
I would recommend getting some Rogue RSMs, it is what I did and will not have to pull apart the interior again.
I cant believe i read right over this.
I really cant thank you guys enough for all the support.
-Christopher
Old 10-04-2011, 01:14 PM   #1926
prokot
My Ride: e46 touring
Check out my DIY: Rear shock replacement for tourings/wagons e46 FL
http://www.bmw-sport.pl/viewtopic.php?f=25&t=102874
prokot is offline   Reply With Quote
Old 10-04-2011, 02:29 PM   #1927
jwm5
My Ride: station wagon
Nice pictorial, I cant read any of it but the pics are good enough to work from.
jwm5 is offline   Reply With Quote
Old 10-04-2011, 03:44 PM   #1928
SexualChocolate
My Ride: 323iT and more
I tried to help lol
SexualChocolate is offline   Reply With Quote
Old 10-04-2011, 09:43 PM   #1929
tootall
My Ride: 2011 328iT 3 pedals
Originally Posted by MINIz guy View Post
http://www.concordmotorsport.com/det...d-7614427.html
This is my idea of perfection; it even is in wagon form! I've found it almost impossible to come by a E46 with no sunroof, manual seats, manual transmission, auto climate control, no fold-down seats (unless wagon) and xenon lights. I'd love to get rid of the X5 I drive and pick this up.
Thanks for the tip! My son is buying that car. I will drive up there with him to pick it up soon.
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 10-04-2011, 10:34 PM   #1930
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
nice pickup - hope your son enjoys it
/_________\
O==[][]==O
Old 10-05-2011, 04:36 AM   #1931
tootall
Thanks! I look forward to trying out a stick shift touring. Maybe I will be motivated to trade mine in for one someday, or maybe swap out my tranny. They are very hard to find. This will be my son's second car to his 2009 Cadillac CTS-V stick shift sedan, which he does not like to drive in bad weather.
Old 10-05-2011, 06:37 AM   #1932
330i ZHP
330i ZHP's Avatar
confised
/_________\
O==[][]==O
Old 10-05-2011, 06:56 AM   #1933
Jaundiced Outlook
My Ride: has a tailgate
Great pictures. Be sure to post over in the DIY section if you haven't already.
My search-and-remove-everything method with TIS printouts worked out okay during my rear shock replacement a few months back, but having these pictures would have been a nice bonus.
2001 325iT 5-Speed
Jaundiced Outlook is offline   Reply With Quote
Old 10-05-2011, 07:01 AM   #1934
tootall
confised
Me too. I did a little editing. Maybe that makes it clearer.
Old 10-05-2011, 07:07 AM   #1935
Jaundiced Outlook
Hatch glass poltergeist exorcised
My hatch glass had the bad habit of randomly popping open. After a bunch of troubleshooting, I narrowed the search down to a bad/shorting hatch button. Took me a while to find a new one - I think I got the last one on the planet. Tischer fortunately had a dusty one under the old superseded P/N.
You have to remove the wiper and its shaft to remove the button, which basically is a donut the shaft passes through. The entire assembly & a gasket pass through a hole cut in the glass. Well, it turned out the two wires for the button were out of position and rubbing (presumably from the factory), and the insulation had worn through. Bump in the road, wiper running = short and glass poppage.
I went ahead and installed the new button, but I'm sure the old one could be fixed with some heat shrink tubing or even electrical tape. I'm hanging on to it as a backup.
2001 325iT 5-Speed
Old 10-05-2011, 08:08 AM   #1936
330Berg
My Ride: E46 330dt/E87 130i M
Originally Posted by Fuxxo View Post
mine.. (got it for half a year)
but, this is work in progress :-) still a awful lot of work there..
Nice looking touring, and som cool pic of it to.
Rides:04 BMW e46 3,0DT 6MT/06 BMW e87 130I M sport.
Interior: Black sports leather.
Exterior:M3 CSL look front:ACS mirror:M-tech rear and sides:Costume rear window spoiler:BBS Wheels 8,5 & 9,5x19" ET25 :
330Berg is offline   Reply With Quote
Old 10-07-2011, 10:02 PM   #1937
TRUEDIABLO
My Ride: T100,323it,325xit,Z3
glass hatch popping open
My mom's 2000 323it had a similar problem, button didn't work, glass would pop open with the remote and sometimes randomly while driving.
The problem with hers turned out to be where the flat wire (that looks like tape around the perimeter of the window from the latch/button to the wire harness) had come un-soldered from where it went from 'regular' wire to the flat/tape wire. It was kind of tricky to track down, it's hidden under a black plastic coupler where the wires transition.
Thought I'd throw that out there in case someone comes across a similar problem and it's not he button (which I did try replacing first).
TRUEDIABLO is offline   Reply With Quote
Old 10-07-2011, 11:02 PM   #1938
Jaundiced Outlook
Good to know of another possible failure point. I tell ya, that whole rear wiper/button deal really is kinda Rube Goldberg.
2001 325iT 5-Speed
Old 10-07-2011, 11:37 PM   #1939
E RaK
My Ride: 2001 325xit
Tell me about it It's always fun when I'm on the highway and the glass pops its latch! Thankfully the pistons are strong enough to keep it from flying open, but it's a serious pain nonetheless. Then, when I want it to open, the button never works.
E RaK is offline   Reply With Quote
Old 10-08-2011, 05:05 AM   #1940
Fuxxo
whank you berg :-) I've noticed your touring too, it loooks awesome and the csl bumper.. I am wondering to buy one.. mainly because of the lip that you can buy on it.. :-) because on this mtech II its not much to choose from..
E46 330D Mpaket touring - Street Rocket..
Wheelslist.net: Your #1 OEM list of wheels!
My Thread..
touring
Rate This Thread
