Old 01-15-2008, 12:18 PM   #1
sbocaj55
My Ride: 330
Send a message via AIM to sbocaj55
BMW won't reflash my LCM, what to do?
Called up the stealership and said they don't do LCM reflashes. They said they haven't used the MODIC system since 1994, and that my only option to upgrade my lights to xenon is aftermarket.
What can I do/tell them?
sbocaj55 is offline   Reply With Quote
Old 01-15-2008, 12:25 PM   #2
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
You could solder in some capacitors (or is it resistors? I don't remember) so you won't have a bulb out warning. I prsume this is the reason you want to reflash your LCM. There are some posts here on how to do this. Search a little. Then again, you can just go to another dealership who has the know how.
Breyton-BMW is offline   Reply With Quote
Old 01-15-2008, 12:31 PM   #3
sbocaj55
My Ride: 330
I would be fine with the bulb-out warning...the problem is that after a day or two one light will shut off. I took everything apart, checked it, and reinstalled it. Everything worked for another few days, then one stops working. I don't know what I can do to fix that issue...
Old 01-15-2008, 12:35 PM   #4
Breyton-BMW
My Ride: Ti
I guess you have original xenons installed in your car, am I correct? I don't think a reflash would solve it. More like either the bulbs or the ballasts are going bad already
Old 01-15-2008, 03:06 PM   #5
sbocaj55
My Ride: 330
I retrofitted xenons into my halogen housings.
Old 01-15-2008, 03:29 PM   #6
Grovedale
Grovedale's Avatar
My Ride: an E46
A dealer reflash won't fix the lights going out, only the bulb out warning on your dash. Find the problem with your instalation, then find an other dealer.
I don't have OCD, I just like things a certain way.
Grovedale is offline   Reply With Quote
Old 01-15-2008, 05:06 PM   #7
paraklas
My Ride: ESS TS2 320ci
Of course they haven't used MODIC since 1994.. Are you using a 80386 PC?
They moved on with newer equipment which is perfectly cabable to recode an LCM. If they don;t know that, find another dealer
Old 01-15-2008, 06:30 PM   #8
sbocaj55
My Ride: 330
Are you SURE? The guy with the LCM Reflash thread said he has problems with his headlights going out and got a reflash and now they work, he just doesn't have bixenon now.
I checked my install twice, and it worked for a few days each time. If my install was faulty, it wouldn't work at all, correct?
Old 01-15-2008, 06:38 PM   #9
iceberq
My Ride: 02 LSB M3
Jlevisw supposedly has a device for xenon retrofits
iceberq is offline   Reply With Quote
Old 01-15-2008, 06:39 PM   #10
M0nk3y
Banned
My Ride: 2002 325xi
Your right, most of the times if you don't do a LCM reflash (if you do need one) your lights will flicker or not even turn on.
M0nk3y is offline   Reply With Quote
Old 01-16-2008, 05:14 AM   #11
sillieidiot
My Ride: '06 AW 330ci
yes it will. on the new e46's, typically 03+, the xenons will either flicker constantly, or not turn on at all.
Old 01-16-2008, 05:15 AM   #12
sillieidiot
that's not necessarily true either, if your install was bad, a number of things can and don't work. but since you've already said you have a sound install, then it's going to be something else
call the dealership again and tell them that you need your "LSZ' to be flashed to accept xenons, if that still doesn't work, find another dealer because they aren't competent enough. look into indy shops as well, as they will charge much less.
Old 01-16-2008, 02:04 PM   #13
Toubib
My Ride: 2004 330i zhp
Eyes
PM me Silliediot
Toubib is offline   Reply With Quote
Old 01-16-2008, 04:26 PM   #14
sbocaj55
My Ride: 330
Well whaddya know...they work today and no "light out" warnings.
Old 01-16-2008, 04:42 PM   #15
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
yet
BreakMyWallet is offline   Reply With Quote
Old 01-16-2008, 04:42 PM   #16
BreakMyWallet
i pulled fuse 32 to get rid of the warnings. but cant help you with the lights going out
Old 01-16-2008, 06:00 PM   #17
M0nk3y
Banned
My Ride: 2002 325xi
thank god I have an 02+
If i installed my P46s, and when i turned them on to test, i wouldn't be too happy to see them flicker or not turn on at all
but i don't have to deal with that
Old 01-16-2008, 06:40 PM   #18
sillieidiot
it happens on 02+ sedans. 03+ coupes. but there are very few instances where you get lucky, for awhile.
Old 01-16-2008, 06:54 PM   #19
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & ///M3
Send a message via AIM to BMWPower06
my dealer reflashed mine, after i hand printed directions on EXACTLY what they needed to do. bunch of idiots there
Current: E60 M5 6MT; E46 M3 6MT
Sold: E46 330CiA; E36 M3/2/5; E60 M5 SMG
DD: B8.5 Audi S4 6MT
BMWPower06 is offline   Reply With Quote
Old 01-19-2008, 11:57 AM   #20
dpav02
My Ride: n/a
Create a electrolytic capacitor harness. Read my post, http://forum.e46fanatics.com/showthr...43#post7256043
dpav02 is offline   Reply With Quote
