Miscellaneous
Old 01-16-2008, 10:07 PM   #1
csunflip
My Ride: 2005 330i ZHP
Send a message via AIM to csunflip
MUGEN SEIKI 1/10 MTX-4 Chassis Kit MUGT0050
Asking $900 for everything. Pictures upon request.....
MUGEN SEIKI 1/10 MTX-4: $450 *BRAND NEW* Never been raced once.
ALSO INCLUDED:
O.S. 12TZ (P)-T 3 Port Engine: $299.99 *BRAND NEW Never been used*
Airtronics M8 3-channel FM radio w spektrum module: $300
Brand New Spektrum but used M8
This is the 1/10 scale glow powered, radio controlled,
Mugen MTX4-R On-Road Car Chassis Kit.
FEATURES: Chassis: A70-75 T6 aluminum natural finish 1/8" (3mm) thick Drive: Four wheel belt drive with belt tensioner Fuel Tank: 2.5oz (75cc) low profile with flip top cap Clutch: 4-shoe Transmission: Two-speed Ball Bearings: Full set included Shocks: Four oil-filled with coil-over spring, aluminum bodied with carbon shock stays Main Gear: 59 tooth and 53 tooth Gearbox: Open, front and rear Differentials: Planetary geared Brakes: Dual ventilated disk Tires: GRP Foam rubber touring slicks, 1" (26mm) front, 1.2" (30mm) wide rear mounted on 12 spoke white wheels Bumper: Front, foam Suspension: Front double wishbone, pillow ball front and rear adjustable front bump stop/rebound stop, adjustable rear rebound stop Caster: Adjustable, caster/toe-in refers to the angle of the front suspension when viewed from the side of the car in relation to the chassis Camber: Adjustable, camber refers to the angle of the tops of the tires from vertical when viewed from front or behind vehicle Steering: Ball bearing supported bellcrank Servo Saver: Included
INCLUDES: Mugen MTX4-R On-Road Car Chassis, 12 spoke wheels, slick tires, 53 & 59 tooth main gear, 17 & 23 tooth clutch bell, illustrated instructions, decal sheet
Image Hosted by ImageShack.us
csunflip is offline   Reply With Quote
