///M3 Forum
Old 01-18-2008, 07:27 PM   #1
gpasky
My Ride: e36 ///M3,e46 ///M3
front turn signal replacement
Ok i am having the hardest time replacing my Turn signal bulb in the front. The instructions state to insert screw driver to an upper hook? where is it? Everyone says its easy, all i see is this flat piece of metal that i am kind of bending but im not sure if thats it? Its not coming out either
HELP? i am getting frustrated!!
gpasky is offline   Reply With Quote
Old 01-18-2008, 07:46 PM   #2
RJSe46m3
My Ride: 2001 M3
http://m3.madrussian.net/diy_front_turnsignal.shtml
if you haven't already found a diy,
01 have push in type corner lenses, 02-06 have screw in, i have an 01 so i'm only familiar with those. But you u look in the hole, push a screw driver down on the plastic tab, and kind of push it towards the front of the car, and the corner lense should come right out, maybe get a flashlight so you can more easily see what down in the hole?
i can see how it could be tricky if you haven't done it, maybe some of that helps?
RJSe46m3 is offline   Reply With Quote
Old 01-18-2008, 08:24 PM   #3
TM3Vert
My Ride: M3 Convertible 6spee
^^^^ thats were i got my info from easy install when you put it back on look dead on and youll see two holes that are closest to your headlights line those holes up and the two clips from your corner lense will go right in and it will snap back in.
2001 M3 6speed Vert= K&N fipk, Magnaflow catback, Agency Power strut bar, BF Goodrich Gforce T/A KDW 2, Ebay headers and tune, H&R springs, Autosolutions SSK, Tranny mounts and clutch stop, 310.7 rwhp 7259 rpms & 249.7 rwtq 4505 rpms, sold.
TM3Vert is offline   Reply With Quote
Old 01-18-2008, 08:33 PM   #4
CJPatel
My Ride: Audi A7, LP550-2
just look down through the hole right above your corner light inside your engine bay. its a screw hidden in a biege plastic peice. AND DO NOT UNSCREW THE WHOLE THING. Just part of it, cause if you loose it, and dont replace it well enough with a subsitute, you're corner light housing will fly away...
I know from experience
DD -
Audi A7
Weekend -
LP550-2
Gone:
Ferrari F430 Spider - F1, Aston Martin V8 Vantage 6spd, E46 Mystic Blue M3 6spd :(, E92 335i, MSport, 6spd, F10 550i X - MSport
CJPatel is offline   Reply With Quote
Old 02-21-2008, 05:12 PM   #5
ohio99328i
My Ride: 1999 328
Thanks, RJSe46m3 for the link. The manual does a bad job of decribing the procedure. Your efforts saved me alot of time. Took 2 minutes once the fixture was out.
ohio99328i is offline   Reply With Quote
Old 02-22-2008, 08:56 AM   #6
gpasky
Thanks everyone
Sorry i haven't responded in awhile. But i want to thank you guys for helping me out! i had to unscrew it and it popped out.
Thanks again!
Old 05-06-2009, 07:11 PM   #7
FUGA325i
My Ride: 2001 325i
WOW, I was getting really frustrated too. Thank you guys for the help.
If you have to ask, you don't need to know!!
FUGA325i is offline   Reply With Quote
Old 02-18-2010, 09:16 PM   #8
BimmerFerret
My Ride: 08 G37S, 07 Sky RL
Bump for newbs... I need to do this now. VERY helpful link in post #2!!
2008 Infiniti G37S - Big Brakes, Limited Slip, etc.
2007 Sky Redline
1998 Honda Civic EX Sedan
Originally Posted by Roxlo View Post
Class of '03, yet you're still an idiot. Whats your point? Do you really think that you're somehow a god because you joined a site before someone else? ****ing nerd.
BimmerFerret is offline   Reply With Quote
Old 02-19-2010, 06:42 AM   #9
sick.boy1986
My Ride: ///M3
Yeah me too, but on my E36. I was driving down the autobahn and heard a weird clunk type of noise, when I got to my girl's house, she was like wtf, this is your "new" car?
E46 M3
FZJ80
sick.boy1986 is offline   Reply With Quote
Old 10-03-2010, 09:44 PM   #10
laxman
My Ride: 03 325i
Thanks to RJSe46m3 for the link. The Bentley manual describes the procedure for the E46 through 2002 models. Mine is a 2003. After so much frustration trying to figure the manual out with what I had, I resorted to the internet. This forum has been a time and sanity saver.
GOOD JOB GUYS!!!!!
laxman is offline   Reply With Quote
Old 12-12-2010, 10:02 AM   #11
richierich46
My Ride: 330ci
Great link! very helpful.......
Just wanted to add here that in the UK we call this part 'Indictor'.
Have been searching on here for indicator change on an e46 2001 coupe. Then discovered you guys call it 'Turn Signal'. Dough!!
The strong rule the weak but the wise rule the strong!
richierich46 is offline   Reply With Quote
Old 10-12-2016, 09:02 AM   #12
Razz617
My Ride: 2004 330Ci
Hi. Is the beige piece that you mention is your reply a LONG beige piece that the bulb goes into? If so, do you know the name of that piece?
Razz617 is offline   Reply With Quote
